Gumstix Upverter
Article updated at 15 Jun 2021
Upverter is a drag and drop designer tool to create carrier boards.
Highlights
  • Free Design Files and 3D Model Files On-Demand - Upverter generates EagleCAD, .BRD and .SCH files of your design on-demand, as well as instant pricing, datasheets, and .STL models.
  • Rapid Manufacturing - Carrier boards designed and ordered in Upverter reduce engineering costs and errors. Upverter automates the PCB routing, BOM, fabs, and assembly. Electronics arrive pre-tested, application-ready, and fully assembled in 15 business days.
  • Auto BSP - With the AutoBSP feature you don't need to port the Toradex BSP to your custom board, Upverter does that for you.
  • Altium Viewer - With the Altium Viewer embedded in the Upverter interface, it also provides Altium Designer project files and high-quality PDF schematics.
Get Started
In a joint-effort with Gumstix, Toradex provides the Upverter - Online Carrier Board Designer Tool directly on the Toradex website:
Upverter - Online Carrier Board Design Tool by Gumstix
Software Support on Embedded Linux
There are two major Embedded Linux offerings provided by AutoBSP:
  • An open-source custom Yocto distribution.
  • Torizon, a ready-to-use distribution maintained by Toradex.
    • Torizon has all Gumstix device drivers included.
    • The custom device tree generated by AutoBSP for your board can be easily integrated on Torizon.
    • Support of AutoBSP on Torizon is a work-in-progress, please contact us if you need it.
Webinars
Webinar with Altium: Innovative Drag and Drop Hardware Development for Embedded Devices
