Download Toradex Easy Installer
This article aims to offer a source of download links of the Toradex Easy Installer tool. If you are looking for information on how to load Tezi into Toradex SoMs, refer to Loading Toradex Easy Installer article.
For more information on Toradex Support Strategy, refer to Embedded Linux Support Strategy.
A release will be promoted to stable roughly six months after a release, only if no issues are reported or open. These timelines may vary and are not guaranteed. Otherwise, there will be another release fixing any open or reported issues.
See the revision history and roadmap for details:
The support for Colibri iMX6ULL 1GB eMMC was added to Toradex Easy Installer 5.4.0.
Latest Release
Use the latest version from the tables below:
OS Image | Version | Date | Size |
Apalis iMX6 | 6.6.0+build.6 | 2024/04/02 | 35.11 MiB |
Apalis iMX8 | 6.6.0+build.6 | 2024/04/02 | 45.13 MiB |
Colibri iMX6 | 6.6.0+build.6 | 2024/04/02 | 35.07 MiB |
Colibri iMX6ULL | 6.6.0+build.6 | 2024/04/02 | 35.86 MiB |
Colibri iMX7 | 6.6.0+build.6 | 2024/04/02 | 35.88 MiB |
Colibri iMX8X | 6.6.0+build.6 | 2024/04/02 | 44.85 MiB |
Verdin AM62 | 6.6.0+build.6 | 2024/04/02 | 53.00 MiB |
Verdin iMX8M Mini | 6.6.0+build.6 | 2024/04/02 | 44.38 MiB |
Verdin iMX8M Plus | 6.6.0+build.6 | 2024/04/02 | 45.20 MiB |
Apalis iMX6 | 5.7.6+build.21 | 2024/03/27 | 31.61 MiB |
Apalis iMX8 | 5.7.6+build.21 | 2024/03/27 | 48.11 MiB |
Apalis TK1 | 5.7.6+build.21 | 2024/03/27 | 34.70 MiB |
Colibri iMX6 | 5.7.6+build.21 | 2024/03/27 | 31.57 MiB |
Colibri iMX6ULL | 5.7.6+build.21 | 2024/03/27 | 32.47 MiB |
Colibri iMX7 | 5.7.6+build.21 | 2024/03/27 | 32.51 MiB |
Colibri iMX8X | 5.7.6+build.21 | 2024/03/27 | 47.71 MiB |
Verdin iMX8M Mini | 5.7.6+build.21 | 2024/03/27 | 47.19 MiB |
Verdin iMX8M Plus | 5.7.6+build.21 | 2024/03/27 | 47.46 MiB |
Apalis T30 | 2.4 | 2021/04/15 | 30.49 MiB |
Unzip the Zip file in a local directory on a Windows or Linux host.
Browse older releases
- Toradex Easy Installer 5.7.5+build.19
- Toradex Easy Installer 5.7.3+build.17
- Toradex Easy Installer 5.7.2+build.14
- Toradex Easy Installer 5.7.1+build.13
- Toradex Easy Installer 5.7.0+build.12
- Toradex Easy Installer 5.6.0+build.9
- Toradex Easy Installer 5.5.0+build.6
- Toradex Easy Installer 5.4.0+build.4
- Toradex Easy Installer 5.3.0+build.3
- Other older releases can be found in the legacy artifacts repository
Nightly Pre-release
Nightly builds are available from the tables below:
Apalis iMX6 | 6.6.0-devel-20240422+build.304 | 2024/04/23 | 35.11 MiB |
Apalis iMX8 | 6.6.0-devel-20240422+build.304 | 2024/04/23 | 45.13 MiB |
Colibri iMX6 | 6.6.0-devel-20240422+build.304 | 2024/04/23 | 35.08 MiB |
Colibri iMX6ULL | 6.6.0-devel-20240422+build.304 | 2024/04/23 | 35.86 MiB |
Colibri iMX7 | 6.6.0-devel-20240422+build.304 | 2024/04/23 | 35.88 MiB |
Colibri iMX8X | 6.6.0-devel-20240422+build.304 | 2024/04/23 | 44.85 MiB |
Verdin AM62 | 6.6.0-devel-20240422+build.304 | 2024/04/23 | 53.01 MiB |
Verdin iMX8M Mini | 6.6.0-devel-20240422+build.304 | 2024/04/23 | 44.38 MiB |
Verdin iMX8M Plus | 6.6.0-devel-20240422+build.304 | 2024/04/23 | 45.20 MiB |
Apalis iMX6 | 5.7.7-devel-20240421+build.534 | 2024/04/21 | 31.61 MiB |
Apalis iMX8 | 5.7.7-devel-20240421+build.534 | 2024/04/21 | 48.11 MiB |
Apalis TK1 | 5.7.7-devel-20240421+build.534 | 2024/04/21 | 34.70 MiB |
Colibri iMX6 | 5.7.7-devel-20240421+build.534 | 2024/04/21 | 31.58 MiB |
Colibri iMX6ULL | 5.7.7-devel-20240421+build.534 | 2024/04/21 | 32.47 MiB |
Colibri iMX7 | 5.7.7-devel-20240421+build.534 | 2024/04/21 | 32.51 MiB |
Colibri iMX8X | 5.7.7-devel-20240421+build.534 | 2024/04/21 | 47.71 MiB |
Verdin iMX8M Mini | 5.7.7-devel-20240421+build.534 | 2024/04/21 | 47.19 MiB |
Verdin iMX8M Plus | 5.7.7-devel-20240421+build.534 | 2024/04/21 | 47.46 MiB |
Manufacturing Pre-loaded Version
The manufacturing pre-loaded version (or production version) of Toradex Easy Installer in our modules are available from the table below:
Module | Product | Toradex Easy Installer Version |
Colibri iMX8 | All products | Toradex Easy Installer - 5.6.0 |
Colibri iMX6 | All products | Toradex Easy Installer - 5.3.0 |
Colibri iMX7 (eMMC flash memory) | 00391101 (eMMC flash memory) | Toradex Easy Installer 5.3.0+build.3 |
Colibri iMX7 | All except 00391101 | Colibri-iMX7_ToradexEasyInstaller_1.8-20181019 |
Colibri iMX6ULL (NAND flash memory) | All products | Colibri-iMX6ULL_ToradexEasyInstaller_1.8-20181019 |
Colibri iMX6ULL (eMMC flash memory) | All products | Toradex Easy Installer - 5.6.0 |
Verdin iMX8M Mini | All products | Toradex Easy Installer - 5.6.0 |
Verdin iMX8M Plus | All products | Toradex Easy Installer - 5.6.0 |
Verdin AM62 | All products | Toradex Easy Installer - TBD |
Apalis iMX8 | All products | Toradex Easy Installer - 5.6.0 |
Apalis iMX6 | All products | Toradex Easy Installer - 5.3.0 |
Apalis TK1 | All products | Apalis-TK1_ToradexEasyInstaller_1.9-20200805 |
Apalis T30 | All products | Angstrom Linux Apalis-T30_LXDE-Image 2.8b6.184 20190401 |
