Attention: the features and instructions contained in this article are not guaranteed to be maintained by Toradex.
The Atmel MaXTouch controllers have a configuration file saved in their internal NVRAM. On rare occasions, one may need those files for some purpose.
Attention: it is very likely that you don't need to get the configuration from the controller. Avoid messing up with it, so you avoid permanently damaging the controller.
This article focuses on specifically how to retrieve the configuration from the Capacitive Touch Display 10.1" LVDS on Torizon. It most likely works for the Capacitive Touch Display 7" Parallel, or at least very similar instructions. The configuration is retrieved using the mxt-app and you should read the README.md of the repo for further details.
Build a container named mxt-app
using the Dockerfile below:
Warning: the Dockerfile provided in this article may not comply with best practices. It is intended as a quickstart only.
DockerfileFROM arm64v8/ubuntu RUN apt-get update && apt-get upgrade -y && apt-get install -y \ git \ build-essential \ autoconf \ libtool \ i2c-tools RUN git clone https://github.com/atmel-maxtouch/mxt-app.git && \ cd mxt-app && \ ./autogen.sh && \ make && \ cp mxt-app /usr/local/bin/ CMD ["/bin/bash"]
Run with:
# cd /home/torizon
# mkdir mxt
# docker run --rm -it --privileged -v /dev:/dev -v /tmp:/tmp -v /run/udev/:/run/udev/ -v /sys:/sys -v /home/torizon/mxt:/mxt mxt-app
You'll later save the config file in the bind-mount /home/torizon/mxt.
In the interactive bash session inside the container, find the i2c controller and address:
## ls /sys/bus/i2c/drivers/atmel_mxt_ts/
4-004a bind uevent unbind
In this case, it is 4-004a. Now you can dump the config to a file:
## cd mxt
## mxt-app -d i2c-dev:4-004a --save mxt.xcfg
Version:1.28-25-g927e026
Registered i2c-dev adapter:4 address:0x4a
REPORTALL command issued
Timeout
Read config from device
Saved config to mxt.xcfg in .xcfg format
## cd mxt
## mxt-app -d i2c-dev:4-004a --save mxt.bin
Timeout
Saved config to mxt.bin in OBP_RAW format
Exit the container and copy the file to your PC from /home/torizon/mxt/mxt.xcfg using, for instance, scp
# scp /home/torizon/mxt/mxt.xcfg <user>@<ip>:<path to save file on your PC>
