Toradex Easy Installer - OS and Demo Images
Article updated at 04 May 2021
On this page you will find the images from Toradex and our partners, for offline installation using the Toradex Easy Installer. It is useful when an image is not available directly in our online servers - for instance, old versions of a specific image - or when your company network does not allow the board to access our online servers.
Partner Demo Images
Among the options presented in Toradex Easy Installer, there are partner demo images available for the evaluation of different technologies and solutions. Please check the Partner Demo Images for more information or go to a specific partner demo image page from the table below. You will find the download links on each partner demo image page.
Partner Demo Image Summary Overview
Built with Qt Qt Company Qt for Device Creation Light-weight, Qt-optimized, full software stack for embedded Linux systems
Kynetics Android Kynetics Kynetics Android Android port to Toradex hardware by Kynetics
Acontis Technologies Acontis Technologies acontis EC-Master EtherCAT Stack EtherCAT System implementation by Acontis Technologies
BE.services Matrikon OPC UA Server BE.services
Matrikon
BE.services Matrikon OPC UA Server Matrikon OPC UA Server implementation by BE.services GmbH
BlackBerry QNX BlackBerry QNX QNX Neutrino Real-time Operating System QNX Neutrino RTOS port to Toradex hardware
Direct Insight QNX Direct Insight Direct Insight - QNX Neutrino Real-time Operating System Direct Insight - QNX Neutrino RTOS port to Toradex hardware
AWS Pasta Demo Amazon Web Services AWS AI at the Edge Pasta Detection End-to-end demonstration of pasta detection using deep learning and connected to the AWS cloud
MVTec Embedded vision MVTec Software GmbH MVTec Embedded Vision HPeek Demo The essence of MVTec HALCON's key features and performance, ease of use in Machine Vision
Mender & Toradex Mender.io Mender Easy Installer Secure and robust Over The Air update manager solution for connected embedded Linux devices
DiSTI GL Studio DiSTI Corporation DiSTI GL Studio DiSTI's technology of GL Studio showcased in a UI with the look and feel of automotive design
TES 3D Surround View TES Eletronic Solutions TES 3D Surround View 3D representation of a vehicle driver assistance system based on the input of cameras, GPU optimized
ITTIA DB SQL for Device Data Management Demo ITTIA ITTIA DB SQL for Device Data Management Interactive relational database utilities and management system for intelligent embedded systems
TorizonCore Embedded Linux Images
Attention: if you have a Colibri iMX8X V1.0B or older use a suitable image as indicated in the download table below, or the online Toradex Easy Installer feed. If you have a Colibri iMX8X V1.0C or newer, make sure to install the default image, or the one for the V1.0C if available, either from the table below or the online Toradex Easy Instaler feed.
If you install an image for the wrong version of Colibri iMX8X, it will not boot and you will have to enter Recovery Mode, re-load Toradex Easy Installer and install a suitable image.
The TorizonCore images for offline instalation are provided below:
TorizonCore Quarterly Releases
Quarterly releases are production releases. They are good for development but also for deployment on the field. They get replaced with a newer quarterly every 3 months.
OS Image Supported Modules Summary Overview
TorizonCore TorizonCore with evaluation containers
5.1.0+build.1.container
Apalis iMX6 (2021-01-06 | 5.1.0+build.1.container | 416.88 MB)
Apalis iMX8 (2021-01-06 | 5.1.0+build.1.container | 409.78 MB)
Apalis iMX8X (2021-01-06 | 5.1.0+build.1.container | 409.29 MB)
Colibri iMX6 (2021-01-06 | 5.1.0+build.1.container | 426.65 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-01-06 | 5.1.0+build.1.container | 415.53 MB)
Colibri iMX8X (2021-01-06 | 5.1.0+build.1.container | 409.37 MB)
Colibri iMX8X V1.0B (2021-01-06 | 5.1.0+build.1.container | 409.24 MB)
Verdin iMX8M Mini (2021-01-06 | 5.1.0+build.1.container | 416.13 MB)
TorizonCore Linux with several containers focused on development:
Weston, Chromium, Portainer and Development Tools container
5.1.0+build.1
Apalis iMX6 (2021-01-06 | 5.1.0+build.1 | 153.52 MB)
Apalis iMX8 (2021-01-06 | 5.1.0+build.1 | 174.52 MB)
Apalis iMX8X (2021-01-06 | 5.1.0+build.1 | 174.03 MB)
Colibri iMX6 (2021-01-06 | 5.1.0+build.1 | 163.28 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-01-06 | 5.1.0+build.1 | 153.13 MB)
Colibri iMX8X (2021-01-06 | 5.1.0+build.1 | 174.27 MB)
Colibri iMX8X V1.0B (2021-01-06 | 5.1.0+build.1 | 174.24 MB)
Verdin iMX8M Mini (2021-01-06 | 5.1.0+build.1 | 180.88 MB)
TorizonCore Linux with no containers pre-provisioned
TorizonCore Monthly Releases
Monthly releases are pre-production releases. They are good for development as you keep up-to-date with the latest features and bugfixes.
Warning: The images with the PREEMPT_RT patch haven't been fully validated by Toradex. We have only run smoke tests and cyclictest to make sure that the system boots properly and the PREEMPT_RT patches are working on idle conditions.
5.3.0-devel-202105+build.12.container
Apalis iMX6 (2021-05-04 | 5.3.0-devel-202105+build.12.container | 430.1 MB)
Apalis iMX8 (2021-05-04 | 5.3.0-devel-202105+build.12.container | 430.81 MB)
Apalis iMX8X (2021-05-04 | 5.3.0-devel-202105+build.12.container | 440.91 MB)
Colibri iMX6 (2021-05-04 | 5.3.0-devel-202105+build.12.container | 429.81 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-05-04 | 5.3.0-devel-202105+build.12.container | 438.58 MB)
Colibri iMX8X (2021-05-04 | 5.3.0-devel-202105+build.12.container | 430.83 MB)
Colibri iMX8X V1.0B (2021-05-04 | 5.3.0-devel-202105+build.12.container | 441.73 MB)
Verdin iMX8M Mini (2021-05-04 | 5.3.0-devel-202105+build.12.container | 448.75 MB)
Apalis iMX6 (2021-05-04 | 5.3.0-devel-202105+build.12 | 165.69 MB)
Apalis iMX8 (2021-05-04 | 5.3.0-devel-202105+build.12 | 185.33 MB)
Apalis iMX8X (2021-05-04 | 5.3.0-devel-202105+build.12 | 195.43 MB)
Colibri iMX6 (2021-05-04 | 5.3.0-devel-202105+build.12 | 165.41 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-05-04 | 5.3.0-devel-202105+build.12 | 175.33 MB)
Colibri iMX8X (2021-05-04 | 5.3.0-devel-202105+build.12 | 185.03 MB)
Colibri iMX8X V1.0B (2021-05-04 | 5.3.0-devel-202105+build.12 | 196.25 MB)
Verdin iMX8M Mini (2021-05-04 | 5.3.0-devel-202105+build.12 | 203.28 MB)
Verdin iMX8M Plus (2021-05-04 | 5.3.0-devel-202105+build.12 | 185.33 MB)
TorizonCore TorizonCore with evaluation containers (PREEMPT_RT)
Apalis iMX6 (2021-05-04 | 5.3.0-devel-202105+build.12.container | 429.25 MB)
Apalis iMX8 (2021-05-04 | 5.3.0-devel-202105+build.12.container | 440.71 MB)
Apalis iMX8X (2021-05-04 | 5.3.0-devel-202105+build.12.container | 439.46 MB)
Colibri iMX6 (2021-05-04 | 5.3.0-devel-202105+build.12.container | 438.8 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-05-04 | 5.3.0-devel-202105+build.12.container | 427.71 MB)
Colibri iMX8X (2021-05-04 | 5.3.0-devel-202105+build.12.container | 440.75 MB)
Colibri iMX8X V1.0B (2021-05-04 | 5.3.0-devel-202105+build.12.container | 429.19 MB)
Verdin iMX8M Mini (2021-05-04 | 5.3.0-devel-202105+build.12.container | 436.04 MB)
TorizonCore Linux with real-time patch applied and several
containers focused on development: Weston, Chromium,
TorizonCore TorizonCore (PREEMPT_RT)
Apalis iMX6 (2021-05-04 | 5.3.0-devel-202105+build.12 | 164.84 MB)
Apalis iMX8 (2021-05-04 | 5.3.0-devel-202105+build.12 | 195.24 MB)
Apalis iMX8X (2021-05-04 | 5.3.0-devel-202105+build.12 | 193.99 MB)
Colibri iMX6 (2021-05-04 | 5.3.0-devel-202105+build.12 | 174.39 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-05-04 | 5.3.0-devel-202105+build.12 | 164.44 MB)
Colibri iMX8X (2021-05-04 | 5.3.0-devel-202105+build.12 | 194.95 MB)
Colibri iMX8X V1.0B (2021-05-04 | 5.3.0-devel-202105+build.12 | 183.71 MB)
Verdin iMX8M Mini (2021-05-04 | 5.3.0-devel-202105+build.12 | 190.57 MB)
Verdin iMX8M Plus (2021-05-04 | 5.3.0-devel-202105+build.12 | 185.34 MB)
TorizonCore Linux with no containers pre-provisioned. Using a Linux
kernel with PREEMPT_RT real-time patch applied
TorizonCore Nightly and Experimental Releases
Nightly and experimental builds are available from our artifacts server.
  1. Navigate to the corresponding SoM release directory.
  2. Choose the distro and image you want to use.
  3. Inside the oedeploy directory, a tarball of the image for Toradex Easy Installer (abbreviated as Tezi) is available for download.
See our illustration below as an example:
  • How to Download a Nightly TorizonCore Image
Toradex Embedded Linux Reference Images for Yocto Project
Toradex provides Reference Images for Yocto Project built from the Toradex BSP Layers for Yocto Project. For further details, please visit the Linux software cover page. The list of images available from Toradex Easy Installer is provided below:
Toradex Embedded Linux Long Term Supported(LTS) Releases
LTS releases are production releases. They are good for development but also for deployment on the field. They have a maintenance cycle usually around 2 to 3 years. Learn more about the different image options on BSP Layers and Reference Images for Yocto Project Software.
OS Image Supported Modules/Download Link Summary Overview
Tux Linux Console Image Apalis TK1
Apalis TK1 Mainline
Apalis iMX6
Colibri iMX6
Colibri iMX6ULL
Colibri iMX7 Solo 256MB/Dual 512MB
Minimal Embedded Linux Image Without Graphical User Interface
Tux Linux For Tegra Image Apalis TK1 Ubuntu GNOME Desktop Environment Based on NVIDIA L4T
Tux JetPack Linux For Tegra Image Apalis TK1 Ubuntu GNOME Desktop Environment Based on NVIDIA L4T With NVIDIA Support
for a set of Tools to Develop Artificial Intelligence and Computer Vision Applications
Click here to show/hide older LTS releases
Toradex Embedded Linux Quarterly Releases
Quarterly releases are production releases. They are good for development but also for deployment on the field. They get replaced with a newer quarterly every 3 months. Learn more about the different image options on BSP Layers and Reference Images for Yocto Project Software.
Linux Reference Minimal
Downstream SoC vendor based kernel
Wayland/XWayland graphics back-end supported but not included
5.2.0+build.7
Apalis iMX6 (2021-04-08 | 5.2.0+build.7 | 32.71 MB)
Apalis iMX8 (2021-04-08 | 5.2.0+build.7 | 39.92 MB)
Apalis iMX8X (2021-04-08 | 5.2.0+build.7 | 39.62 MB)
Apalis iMX8X V1.1A (2021-04-08 | 5.2.0+build.7 | 39.6 MB)
Apalis TK1 (2021-04-08 | 5.2.0+build.7 | 33.65 MB)
Colibri iMX6 (2021-04-08 | 5.2.0+build.7 | 31.84 MB)
Colibri iMX6ULL (2021-04-08 | 5.2.0+build.7 | 32.65 MB)
Colibri iMX7 Solo 256MB/Dual 512MB (2021-04-08 | 5.2.0+build.7 | 33.17 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-04-08 | 5.2.0+build.7 | 31.81 MB)
Colibri iMX8X (2021-04-08 | 5.2.0+build.7 | 39.68 MB)
Colibri iMX8X V1.0B (2021-04-08 | 5.2.0+build.7 | 39.69 MB)
Verdin iMX8M Mini (2021-04-08 | 5.2.0+build.7 | 40.06 MB)
Verdin iMX8M Plus (2021-04-08 | 5.2.0+build.7 | 40.01 MB)
Minimal Embedded Linux Image Without a Graphical User Interface
Mainline based kernel
5.2.0+build.7
Apalis iMX6 (2021-04-08 | 5.2.0+build.7 | 38.69 MB)
Colibri iMX6 (2021-04-08 | 5.2.0+build.7 | 38.35 MB)
Colibri iMX6ULL (2021-04-08 | 5.2.0+build.7 | 39.54 MB)
Colibri iMX7 Solo 256MB/Dual 512MB (2021-04-08 | 5.2.0+build.7 | 39.67 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-04-08 | 5.2.0+build.7 | 38.32 MB)
Linux Reference Multimedia
Wayland/XWayland graphics back-end included
5.2.0+build.7
Apalis iMX6 (2021-04-08 | 5.2.0+build.7 | 174.05 MB)
Apalis iMX8 (2021-04-08 | 5.2.0+build.7 | 188.25 MB)
Apalis iMX8X (2021-04-08 | 5.2.0+build.7 | 185.81 MB)
Apalis iMX8X V1.1A (2021-04-08 | 5.2.0+build.7 | 185.84 MB)
Apalis TK1 (2021-04-08 | 5.2.0+build.7 | 173.3 MB)
Colibri iMX6 (2021-04-08 | 5.2.0+build.7 | 172.71 MB)
Colibri iMX6ULL (2021-04-08 | 5.2.0+build.7 | 119.94 MB)
Colibri iMX7 Solo 256MB/Dual 512MB (2021-04-08 | 5.2.0+build.7 | 134.31 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-04-08 | 5.2.0+build.7 | 175.71 MB)
Colibri iMX8X (2021-04-08 | 5.2.0+build.7 | 185.87 MB)
Colibri iMX8X V1.0B (2021-04-08 | 5.2.0+build.7 | 185.88 MB)
Verdin iMX8M Mini (2021-04-08 | 5.2.0+build.7 | 184.78 MB)
Verdin iMX8M Plus (2021-04-08 | 5.2.0+build.7 | 185.73 MB)
Reference Embedded Linux Image with Multimedia Capabilities
5.2.0+build.7
Apalis iMX6 (2021-04-08 | 5.2.0+build.7 | 177.33 MB)
Apalis TK1 (2021-04-08 | 5.2.0+build.7 | 173.35 MB)
Colibri iMX6 (2021-04-08 | 5.2.0+build.7 | 177.3 MB)
Colibri iMX6ULL (2021-04-08 | 5.2.0+build.7 | 127.21 MB)
Colibri iMX7 Solo 256MB/Dual 512MB (2021-04-08 | 5.2.0+build.7 | 140.45 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-04-08 | 5.2.0+build.7 | 181.33 MB)
Click here to show/hide older Quarterly releases
Toradex Embedded Linux Monthly Releases
Monthly releases are pre-production releases. They are good for development as you keep up-to-date with the latest features and bugfixes. Learn more about the different image options on BSP Layers and Reference Images for Yocto Project Software.
Attention: we are in the process of migrating the graphical back-end from X to Wayland on BSP 5. Some early nightly and monthly builds might still use X until the migration is finished, and therefore not be available in the table below.
5.3.0-devel-202105+build.10
Apalis iMX6 (2021-05-03 | 5.3.0-devel-202105+build.10 | 32.72 MB)
Apalis iMX8 (2021-05-03 | 5.3.0-devel-202105+build.10 | 39.94 MB)
Apalis iMX8X (2021-05-03 | 5.3.0-devel-202105+build.10 | 39.61 MB)
Apalis iMX8X V1.1A (2021-05-03 | 5.3.0-devel-202105+build.10 | 39.6 MB)
Apalis TK1 (2021-05-03 | 5.3.0-devel-202105+build.10 | 33.66 MB)
Colibri iMX6 (2021-05-03 | 5.3.0-devel-202105+build.10 | 31.84 MB)
Colibri iMX6ULL (2021-05-03 | 5.3.0-devel-202105+build.10 | 32.65 MB)
Colibri iMX7 Solo 256MB/Dual 512MB (2021-05-03 | 5.3.0-devel-202105+build.10 | 33.18 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-05-03 | 5.3.0-devel-202105+build.10 | 31.82 MB)
Colibri iMX8X (2021-05-03 | 5.3.0-devel-202105+build.10 | 39.7 MB)
Colibri iMX8X V1.0B (2021-05-03 | 5.3.0-devel-202105+build.10 | 39.67 MB)
Verdin iMX8M Mini (2021-05-03 | 5.3.0-devel-202105+build.10 | 40.06 MB)
Verdin iMX8M Plus (2021-05-03 | 5.3.0-devel-202105+build.10 | 40.01 MB)
Apalis iMX6 (2021-05-03 | 5.3.0-devel-202105+build.10 | 38.7 MB)
Colibri iMX6 (2021-05-03 | 5.3.0-devel-202105+build.10 | 38.36 MB)
Colibri iMX6ULL (2021-05-03 | 5.3.0-devel-202105+build.10 | 39.56 MB)
Colibri iMX7 Solo 256MB/Dual 512MB (2021-05-03 | 5.3.0-devel-202105+build.10 | 39.66 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-05-03 | 5.3.0-devel-202105+build.10 | 38.33 MB)
Apalis iMX6 (2021-05-03 | 5.3.0-devel-202105+build.10 | 174.05 MB)
Apalis iMX8 (2021-05-03 | 5.3.0-devel-202105+build.10 | 188.24 MB)
Apalis iMX8X (2021-05-03 | 5.3.0-devel-202105+build.10 | 185.81 MB)
Apalis iMX8X V1.1A (2021-05-03 | 5.3.0-devel-202105+build.10 | 185.83 MB)
Apalis TK1 (2021-05-03 | 5.3.0-devel-202105+build.10 | 173.29 MB)
Colibri iMX6 (2021-05-03 | 5.3.0-devel-202105+build.10 | 172.72 MB)
Colibri iMX6ULL (2021-05-03 | 5.3.0-devel-202105+build.10 | 119.94 MB)
Colibri iMX7 Solo 256MB/Dual 512MB (2021-05-03 | 5.3.0-devel-202105+build.10 | 134.31 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-05-03 | 5.3.0-devel-202105+build.10 | 175.74 MB)
Colibri iMX8X (2021-05-03 | 5.3.0-devel-202105+build.10 | 185.86 MB)
Colibri iMX8X V1.0B (2021-05-03 | 5.3.0-devel-202105+build.10 | 185.86 MB)
Verdin iMX8M Mini (2021-05-03 | 5.3.0-devel-202105+build.10 | 184.78 MB)
Verdin iMX8M Plus (2021-05-03 | 5.3.0-devel-202105+build.10 | 185.74 MB)
Apalis iMX6 (2021-05-03 | 5.3.0-devel-202105+build.10 | 177.32 MB)
Apalis TK1 (2021-05-03 | 5.3.0-devel-202105+build.10 | 173.3 MB)
Colibri iMX6 (2021-05-03 | 5.3.0-devel-202105+build.10 | 177.32 MB)
Colibri iMX6ULL (2021-05-03 | 5.3.0-devel-202105+build.10 | 127.19 MB)
Colibri iMX7 Solo 256MB/Dual 512MB (2021-05-03 | 5.3.0-devel-202105+build.10 | 140.46 MB)
Colibri iMX7 Dual 1GB (eMMC) (2021-05-03 | 5.3.0-devel-202105+build.10 | 181.29 MB)
Toradex Embedded Linux Nightly Releases
Nightly builds are available from our artifacts server.
  • How to Download a Nightly Reference Image
Toradex Windows Embedded Compact Images
Toradex provides a Windows Embedded Compact (WEC) BSP, including OS image releases. For further details, please visit the Windows Embedded Compact (WEC) software cover page. The list of images available from Toradex Easy Installer is provided below:
Toradex WEC Stable Releases
WinCE WEC 7 Apalis/Colibri iMX6
Windows Embedded Compact 7
WinCE WEC 2013 Apalis/Colibri iMX6
Windows Embedded Compact 2013
Toradex WEC Beta Releases
