Download Links
On this page you will find the images from Toradex and our partners, for offline installation using the Toradex Easy Installer. It is useful when an image is not available directly in our online servers - for instance, old versions of a specific image - or when your company network does not allow the board to access our online servers.
How to install these images
To install these images, you need to use the Toradex Easy Installer, which comes pre-installed on Toradex modules. You can also load it to your module if you have it already flashed with another image. To load Toradex Easy Installer to your module, please download it and follow the steps to load it. To make the images available to Toradex Easy Installer, check the Provide OS Images section.
Test Results
All images provided by Toradex are tested. To see the test results for each image, see the Toradex Software Test Results page.
Partner Demo Images
Among the options presented in Toradex Easy Installer, there are partner demo images available for the evaluation of different technologies and solutions. Please go to a specific partner demo image page from the table below. You will find the download links on each partner demo image page.
PartnerDemo ImageSummary Overview
Built with Qt
Qt CompanyQt for Device CreationLight-weight, Qt-optimized, full software stack for embedded Linux systems
Kynetics Android
KyneticsKynetics AndroidAndroid port to Toradex hardware by Kynetics
Acontis Technologies
Acontis Technologiesacontis EC-Master EtherCAT StackEtherCAT System implementation by Acontis Technologies
BlackBerry QNX
BlackBerry QNXQNX Neutrino Real-time Operating SystemQNX Neutrino RTOS port to Toradex hardware
AWS Pasta Demo
Amazon Web ServicesAWS AI at the Edge Pasta DetectionEnd-to-end demonstration of pasta detection using deep learning and connected to the AWS cloud
DiSTI GL Studio
DiSTI CorporationDiSTI GL StudioDiSTI's technology of GL Studio showcased in a UI with the look and feel of automotive design
ITTIA DB SQL for Device Data Management Demo
ITTIAITTIA DB SQL for Device Data ManagementInteractive relational database utilities and management system for intelligent embedded systems
Torizon OS Embedded Linux Images for Toradex Hardware
The Torizon OS images for offline installation are provided below:
Torizon OS Quarterly Releases
Quarterly releases are production releases. They are good for development but also for deployment on the field. They get replaced with a newer quarterly every 3 months.
Torizon OS 7
Torizon OS Linux with no containers pre-provisioned.
OS ImageVersionDateSize
Apalis iMX6
🛈 MD57b9d6748fb7f60d0985d06beabf8a6c9
7.6.0+build.362026/04/19195.54 MiB
Apalis iMX8
🛈 MD57d121c7db2eb120b29b5e8abce6e477c
7.6.0+build.362026/04/19212.85 MiB
Aquila AM69/TDA4
🛈 MD5bbc97f1ed73e7c09a9918b9be70c145a
7.6.0+build.362026/04/19278.02 MiB
Aquila iMX95
🛈 MD54c8305a6bdb6029e6fc37bc9211c16ed
7.6.0+build.362026/04/19268.15 MiB
Colibri iMX6
🛈 MD5529342ceca113b0d996003b08e9bacd0
7.6.0+build.362026/04/19195.01 MiB
Colibri iMX6ULL eMMC
🛈 MD5dd833e0206c14b0d8f7a9fbc267f4db7
7.6.0+build.362026/04/19201.16 MiB
Colibri iMX7 eMMC
🛈 MD5a9d25288436778d493a57c7f81c5b915
7.6.0+build.362026/04/19194.58 MiB
Colibri iMX8X
🛈 MD5e81628686e9c6d1b61c197ebfc49b49e
7.6.0+build.362026/04/19212.72 MiB
SMARC iMX8M Plus
🛈 MD5e55d2f38f2db649a9159b3e4990c826c
7.6.0+build.362026/04/19213.07 MiB
SMARC iMX95
🛈 MD538c9506e66d8e8b23dcccd5263afefbb
7.6.0+build.362026/04/19251.85 MiB
Verdin AM62
🛈 MD57302139381d80f745b8a59f535c49256
7.6.0+build.362026/04/19239.58 MiB
Verdin AM62P
🛈 MD5689ec9596b684e703e0903c4694e1058
7.6.0+build.362026/04/19242.03 MiB
Verdin iMX8M Mini
🛈 MD5309cd8a123dee7c4d96c36498bd056ac
7.6.0+build.362026/04/19229.32 MiB
Verdin iMX8M Plus
🛈 MD50a4d04b446cfd8d9cc3df676ce6babfa
7.6.0+build.362026/04/19213.96 MiB
Verdin iMX95
🛈 MD50e7ef345e0b0f94e92a0a3d1f32b888d
7.6.0+build.362026/04/19251.88 MiB
Torizon OS 6
Apalis iMX6
🛈 MD5fad03fffbab30f7b56577bf14ca7fed2
6.8.7+build.432026/04/15183.59 MiB
Apalis iMX8
🛈 MD54e079ccc74052566deef03b4065a0d2c
6.8.7+build.432026/04/15198.72 MiB
Colibri iMX6
🛈 MD5df569c4ab2b894c02d3910a1044cc3cc
6.8.7+build.432026/04/15189.43 MiB
🛈 MD58ba1f3fc8de6ffebeaf4ab27e8e6c867
6.8.7+build.432026/04/15188.66 MiB
Colibri iMX7 eMMC
🛈 MD52a69d51859c93da46923f66e8d925b38
6.8.7+build.432026/04/15189.07 MiB
Colibri iMX8X
🛈 MD5356706c110cbd0d39405506026d4a7bf
6.8.7+build.432026/04/15198.18 MiB
Verdin AM62
🛈 MD5ff83621723e7e74c44fb1beae51c7585
6.8.7+build.432026/04/15222.68 MiB
Verdin iMX8M Mini
🛈 MD5c71f9b406db97b8dff8044f7031ac305
6.8.7+build.432026/04/15207.45 MiB
Verdin iMX8M Plus
🛈 MD5c24139e5aa4ba034a9a3b2217cdb0b40
6.8.7+build.432026/04/15198.96 MiB
TorizonCore 5
TorizonCore Linux with no containers pre-provisioned.
Apalis iMX6
🛈 MD5c7e582b84510412294a4f572c4621079
5.7.2+build.202023/03/29165.27 MiB
Apalis iMX8
🛈 MD5f6878fdf88bfdb49359f26f2f10d27d9
5.7.2+build.202023/03/29184.62 MiB
Colibri iMX6
🛈 MD50287186f56f50744846034d08b882ccf
5.7.2+build.202023/03/29164.96 MiB
🛈 MD5e230b8657f3c323ce283e8e5800847c8
5.7.2+build.202023/03/29174.31 MiB
Colibri iMX7 eMMC
🛈 MD504a059f5049462210206a52c5016f3ee
5.7.2+build.202023/03/29174.50 MiB
Colibri iMX8X
🛈 MD5959ebbb206abdf40edbff4684388e4b8
5.7.2+build.202023/03/29195.33 MiB
Verdin iMX8M Mini
🛈 MD5f8d65536485b587eaa1332986be1d5ef
5.7.2+build.202023/03/29202.46 MiB
Verdin iMX8M Plus
🛈 MD515bb7e1f8dd6d6519d75012f717d8997
5.7.2+build.202023/03/29183.99 MiB
Torizon OS Monthly Pre-releases
Monthly Pre-releases are good for development as you keep up-to-date with the latest features and bugfixes.
warning
The images with the PREEMPT_RT patch haven't been fully validated by Toradex. We have only run smoke tests and cyclictest to make sure that the system boots properly and the PREEMPT_RT patches are working on idle conditions.
Torizon OS 7
Apalis iMX6
🛈 MD50b1e4c3157049b3a1cd53243c5e5e82e
7.6.0-devel-202602+build.172026/02/03195.05 MiB
Apalis iMX8
🛈 MD523e7acdb97fa160ac0dea0fe873b5322
7.6.0-devel-202602+build.172026/02/03219.94 MiB
Aquila AM69/TDA4
🛈 MD5469055bab697a154de49e53a514cacfa
7.6.0-devel-202602+build.172026/02/03277.23 MiB
Aquila iMX95
🛈 MD5eb128c10a6a14983040e91badbae224e
7.6.0-devel-202602+build.172026/02/03235.50 MiB
Colibri iMX6
🛈 MD5efe34568823824c1e4d850a02f2dd5f4
7.6.0-devel-202602+build.172026/02/03194.39 MiB
🛈 MD5e85eba8bd8c93e399981b71a70366004
7.6.0-devel-202602+build.172026/02/03193.81 MiB
Colibri iMX7 eMMC
🛈 MD55f2d7e5b33302c14447bac51619216cf
7.6.0-devel-202602+build.172026/02/03194.40 MiB
Colibri iMX8X
🛈 MD56d734000e4ef6cb9f97870a36c2ecfba
7.6.0-devel-202602+build.172026/02/03219.79 MiB
SMARC iMX8M Plus
🛈 MD596ed475f516864c9c44839c178e39d69
7.6.0-devel-202602+build.172026/02/03220.10 MiB
SMARC iMX95
🛈 MD50685ad85b1689e892be8a12dd1ead548
7.6.0-devel-202602+build.172026/02/03251.37 MiB
Verdin AM62
🛈 MD5304a0db0d8e6b293c5d43fb19fdd029c
7.6.0-devel-202602+build.172026/02/03239.06 MiB
Verdin AM62P
🛈 MD56180bca4fa2b2e4c45dd0b8f30f814fd
7.6.0-devel-202602+build.172026/02/03248.79 MiB
Verdin iMX8M Mini
🛈 MD53deda8833e79702a82731571a9935574
7.6.0-devel-202602+build.172026/02/03228.62 MiB
Verdin iMX8M Plus
🛈 MD5099f3d2b3f2f86f8e8be88235851e14d
7.6.0-devel-202602+build.172026/02/03220.13 MiB
Verdin iMX95
🛈 MD57929920fbc127d33fb94d7d63ed1620d
7.6.0-devel-202602+build.172026/02/03258.48 MiB
Torizon OS 6
Apalis iMX6
🛈 MD56cb771c2938efa66e079d41a379fe838
6.8.0-devel-202409+build.262024/09/11182.57 MiB
Apalis iMX8
🛈 MD5b346c0098b8a5bc381dca19f4b966d5c
6.8.0-devel-202409+build.262024/09/11197.18 MiB
Colibri iMX6
🛈 MD5443d765ccc5b39c9d7e2d80cb46556f4
6.8.0-devel-202409+build.262024/09/11188.42 MiB
🛈 MD53ab37c47bf63f5b23c36b71b41de85bd
6.8.0-devel-202409+build.262024/09/11181.56 MiB
Colibri iMX7 eMMC
🛈 MD51700b896bdcc1dcb4025753a63270ae6
6.8.0-devel-202409+build.262024/09/11181.77 MiB
Colibri iMX8X
🛈 MD5ceeae9892c6954e793507a13b7d02039
6.8.0-devel-202409+build.262024/09/11204.07 MiB
Verdin AM62
🛈 MD5f881f1c6a2ca7aa6716538737e6b85f3
6.8.0-devel-202409+build.262024/09/11238.97 MiB
Verdin iMX8M Mini
🛈 MD5602f5c59650e036a9e80fc9896753836
6.8.0-devel-202409+build.262024/09/11205.48 MiB
Verdin iMX8M Plus
🛈 MD5678a6bb6b2d0622a5901f397f5d92792
6.8.0-devel-202409+build.262024/09/11204.08 MiB
TorizonCore 5
Torizon OS Nightly Pre-releases
Nightly pre-releases are available without extensive testing, and may not boot. They are typically used in development to focus on a feature or bug fix coming up in a monthly pre-release.
warning
Torizon OS 7
Apalis iMX6
🛈 MD5074344afc1ab9793a0ee0dcee09fe2e1
7.7.0-devel-20260426+build.4472026/04/26202.24 MiB
Apalis iMX8
🛈 MD538f4ade6d7edfb06ae1b32e0a4610372
7.7.0-devel-20260426+build.4472026/04/26220.67 MiB
Aquila AM69/TDA4
🛈 MD5c7224f528e2df78c5f98675558681249
7.7.0-devel-20260426+build.4472026/04/26286.36 MiB
Aquila iMX95
🛈 MD53ca232c2d15e1f236b4fc13ce947d6c8
7.7.0-devel-20260424+build.4462026/04/24268.55 MiB
Colibri iMX6
🛈 MD59689a93724c2f1bfa34adaa20fa267c4
7.7.0-devel-20260426+build.4472026/04/26202.03 MiB
🛈 MD5a3eeaee4162d7c92d11e56f234950b80
7.7.0-devel-20260426+build.4472026/04/26201.24 MiB
Colibri iMX7 eMMC
🛈 MD5cb292c18c3dc28593bc4e4b599af184d
7.7.0-devel-20260426+build.4472026/04/26201.40 MiB
Colibri iMX8X
🛈 MD58b82b0895b29914dd024768808022b88
7.7.0-devel-20260426+build.4472026/04/26220.53 MiB
SMARC iMX8M Plus
🛈 MD5c1e9f3aaeffbbe50547081e3079e8828
7.7.0-devel-20260426+build.4472026/04/26220.72 MiB
SMARC iMX95
🛈 MD55ed39bc99b29094784fa14550be463c7
7.7.0-devel-20260426+build.4472026/04/26259.00 MiB
Verdin AM62
🛈 MD5b329f24f241d72ca00010fcd8445eb85
7.7.0-devel-20260426+build.4472026/04/26239.84 MiB
Verdin AM62P
🛈 MD522f91fecbc9fe422f27d01b124220591
7.7.0-devel-20260426+build.4472026/04/26249.57 MiB
Verdin iMX8M Mini
🛈 MD5ef60ab9e00f63d6fff7360b377c839ef
7.7.0-devel-20260426+build.4472026/04/26221.25 MiB
Verdin iMX8M Plus
🛈 MD5c0e68ac712a37ece78c4a298c6231059
7.7.0-devel-20260426+build.4472026/04/26221.07 MiB
Verdin iMX95
🛈 MD5b4978a61655057530f91af24d9de5a9c
7.7.0-devel-20260426+build.4472026/04/26259.32 MiB
Torizon OS 6
Apalis iMX6
🛈 MD57d1169b8888bde269475666ac661360e
6.8.8-devel-20260430+build.10702026/04/30183.71 MiB
Apalis iMX8
🛈 MD508666ff7ad1b349719c93f23c26fbe18
6.8.8-devel-20260430+build.10702026/04/30198.46 MiB
Colibri iMX6
🛈 MD5bd6d6f6d73dc8cba1a0af63a2c0cba86
6.8.8-devel-20260430+build.10702026/04/30189.42 MiB
🛈 MD5435d2c9e5508d6fe23919ff133d2da2b
6.8.8-devel-20260430+build.10702026/04/30182.67 MiB
Colibri iMX7 eMMC
🛈 MD5aaa599a06b60721693d7b26164462aee
6.8.8-devel-20260430+build.10702026/04/30189.11 MiB
Colibri iMX8X
🛈 MD584c24b9035ac814633bf0729d94b2dde
6.8.8-devel-20260430+build.10702026/04/30198.38 MiB
Verdin AM62
🛈 MD5ed27c6a488de0d4576a9185bc6a1e821
6.8.8-devel-20260430+build.10702026/04/30229.66 MiB
Verdin iMX8M Mini
🛈 MD51aa6b1acce2b3eb4db80c65781691730
6.8.8-devel-20260430+build.10702026/04/30207.58 MiB
Verdin iMX8M Plus
🛈 MD5fe5343493e726b6ef0d6f33d02f5519a
6.8.8-devel-20260430+build.10702026/04/30199.00 MiB
Torizon OS Engineering Pre-releases
Engineering pre-releases are experimental, available without extensive testing, and may not fully work. They are typically used on early-access enablement of features or bug fixes. Read our Support Strategy Article for more information.
Torizon OS Walnascar
Torizon OS Linux on top of Yocto Walnascar.
Refer to AI and Machine Learning on i.MX 95 for more information.
Aquila iMX95
🛈 MD514c8895cb56e0fff57d8aa03f4c2af68
0.0.0-devel-20260428+build.352026/04/28261.24 MiB
SMARC iMX95
🛈 MD5eac2c981a38f67876d67934d89933591
0.0.0-devel-20260428+build.352026/04/28283.85 MiB
Verdin iMX95
🛈 MD52ca4fc5aba1bb357a3a81832a26893b0
0.0.0-devel-20260428+build.352026/04/28277.03 MiB
Torizon OS on Non-Toradex Hardware
The Torizon OS images for offline installation on non-Toradex hardware are provided below:
Torizon OS 7
Torizon OS for TI Machines
TI AM62Lx EVM
🛈 MD5a7536ce1ff3c37f1b42945a943856342
7.6.0+build.72026/04/161714.12 MiB
TI AM62Px EVM
🛈 MD56ac7ba188f74a21549054420ec239613
7.6.0+build.72026/04/161880.41 MiB
TI AM62x EVM
🛈 MD51faba7712e023ca1b1c9c7bb179b1f56
7.6.0+build.72026/04/161882.42 MiB
BeagleY-AI
🛈 MD5c403d7427500330e8070d5756cb00c69
7.6.0+build.72026/04/161999.22 MiB
Refer to the test setup guide for detailed instructions on testing Torizon on Texas Instruments machines.
Torizon OS for x86 Machines
x86 Intel Core i7
🛈 MD5db964f425d862817d810272117c51fb9
7.6.0+build.82026/04/161777.02 MiB
Refer to the test setup guide for detailed instructions on testing Torizon on x86 machines.
Torizon OS 7
TI AM62Lx EVM
🛈 MD5dcfbb976793a853bbb18a40a2a209e6d
7.7.0-devel-20260428+build.3162026/04/281719.96 MiB
TI AM62Px EVM
🛈 MD5fe796ef25d781cdcbbe213403323119f
7.7.0-devel-20260428+build.3162026/04/281885.98 MiB
TI AM62x EVM
🛈 MD549268affc815eb3c30697a0deb01241b
7.7.0-devel-20260428+build.3162026/04/281888.12 MiB
BeagleY-AI
🛈 MD5a70b41c12996a2d3900409e71fc873d8
7.7.0-devel-20260428+build.3162026/04/282015.29 MiB
x86 Intel Core i7
🛈 MD5eaf77da27dee536f9d13e31ccb19b4fe
7.7.0-devel-20260427+build.3062026/04/271767.63 MiB
Torizon OS Engineering Pre-Releases
Engineering pre-releases are intended for early evaluation and come with limited support. Before using one, first check whether an official released version is already available. For supported options, refer to the quarterly and nightly tables above.
Torizon OS for NXP Machines
FRDM i.MX 93 Development Board7.5.02025/12/17197.41 MiB
Refer to the test setup guide for detailed instructions on testing Torizon on NXP machines.
Torizon OS for Synaptics Machines
Astra SL2610 Development Board7.5.02025/12/16635. MB
Astra SL1680 Development Board7.6.02026/04/07832.64 MB
Toradex Luna SL1680 SBC7.5.02026/02/20373.41 MiB
For more information about Luna SL1680, please refer to Toradex Website.
For detailed instructions on testing Torizon on the Astra SL1680/SL2610 Development Board, please refer to the test setup guide.
Torizon OS for NVIDIA Machines
Jetson Orin Nano7.6.02026/03/04338.76 MiB
Refer to the test setup guide for detailed instructions on testing Torizon on NVIDIA machines.
Toradex Embedded Linux - Yocto Project Reference Images
Toradex provides Reference Images for Yocto Project built from the Toradex BSP Layers for Yocto Project. For further details, please visit the Linux software cover page. The list of images available from Toradex Easy Installer is provided below:
warning
Reference Images are good for evaluation. They are not Linux distributions. Torizon OS is the Embedded Linux distribution provided by Toradex.
Our LTS BSP Layers for Yocto Project are production-grade and ready to be integrated with your own Yocto Built Linux distribution.
BSP Quarterly Releases
These images are based on production releases of Toradex BSP, which are good for development but also for deployment on the field. They get replaced with a newer quarterly every 3 months. Learn more about the different image options on BSP Layers and Reference Images for Yocto Project Software.
BSP 7
Minimal Embedded Linux Image Without a Graphical User Interface, downstream SoC vendor-based kernel.
Wayland/XWayland graphics back-end supported but not included.
Apalis iMX8
🛈 MD5fa3b2f5810e9bec0701647746a2d4d06
7.6.0+build.142026/04/0447.14 MiB
Aquila AM69/TDA4
🛈 MD5d3294b5dbc894c2ed5a2cb9b57b6ea88
7.6.0+build.142026/04/0473.17 MiB
Aquila iMX95
🛈 MD55686e817bc2b049798c6b626ba8ff168
7.6.0+build.142026/04/0462.51 MiB
Colibri iMX8X
🛈 MD5af952fbf9a9b7c6a3af7923b289bab1d
7.6.0+build.142026/04/0446.94 MiB
Lino iMX93
🛈 MD55f84a26d8aae77f2500ccbe9ebf51b24
7.6.0+build.142026/04/0450.15 MiB
OSM iMX93
🛈 MD558e673208b23262034ebda1cf74fba14
7.6.0+build.142026/04/0447.17 MiB
SMARC iMX8M Plus
🛈 MD5809d58496f02fefd2b5cebb4fd31b186
7.6.0+build.142026/04/0447.56 MiB
SMARC iMX95
🛈 MD52b23054c7687c6cb2d424a4313c02e55
7.6.0+build.142026/04/0458.49 MiB
Verdin AM62
🛈 MD58c4cde8d912a36ed3c91c2256aa3d178
7.6.0+build.142026/04/0447.93 MiB
Verdin AM62P
🛈 MD5ccf759c60a3808bd2bde2333b814e4ed
7.6.0+build.142026/04/0450.57 MiB
Verdin iMX8M Mini
🛈 MD589dffb04c8097a5cfebc2ef644b5a381
7.6.0+build.142026/04/0446.99 MiB
Verdin iMX8M Plus
🛈 MD52c6be14b9a86661be22ad9925e3009de
7.6.0+build.142026/04/0447.60 MiB
Verdin iMX95
🛈 MD5c4ec822cce0ede61f09a2ecf85e29e4d
7.6.0+build.142026/04/0458.48 MiB
BSP 6
Minimal Embedded Linux Image Without a Graphical User Interface, downstream SoC vendor based kernel.
Apalis iMX8
🛈 MD5a1f2bae327b33f842a520a3be4c9060f
6.8.7+build.212026/04/0845.68 MiB
Aquila AM69/TDA4
🛈 MD5ab72657ec94ca24e56c762ab8fa837e2
6.8.4+build.182025/10/0344.74 MiB
Colibri iMX8X
🛈 MD50b8f1bc0c673431c6f781a618ead228e
6.8.7+build.212026/04/0845.51 MiB
Verdin AM62
🛈 MD56f53d18db6f187ffd0d565eab8d470c7
6.8.7+build.212026/04/0844.48 MiB
Verdin iMX8M Mini
🛈 MD5a1b1f7f49a129cebcde1b4d3d81bfa6b
6.8.7+build.212026/04/0845.93 MiB
Verdin iMX8M Plus
🛈 MD5e5b1155e08111826c6e8c66ad6d43b69
6.8.7+build.212026/04/0845.94 MiB
BSP 5
Apalis iMX6
🛈 MD5909dc141e39db9b93a6ef16167458ff0
5.7.6+build.292024/03/2735.63 MiB
Apalis iMX8
🛈 MD59083e56a083ee705075a964dc342ff2e
5.7.6+build.292024/03/2743.24 MiB
Apalis TK1
🛈 MD5cf7f4cbf37252aa3fea16e886bb0f781
5.7.6+build.292024/03/2736.19 MiB
Colibri iMX6
🛈 MD5c312ebec37b19e6c6b79094fbc5064cc
5.7.6+build.292024/03/2734.72 MiB
Colibri iMX6ULL
🛈 MD54b8347ce09712455f1575a93d9bc1359
5.7.6+build.292024/03/2735.87 MiB
🛈 MD5b6a5cb7eb887f99b0364e6f10e2e5e8c
5.7.6+build.292024/03/2734.52 MiB
Colibri iMX7
🛈 MD56d2f7855489fe726d528aff39caa559f
5.7.6+build.292024/03/2736.08 MiB
Colibri iMX7 eMMC
🛈 MD531215044ea4322ab808b90f86ae43516
5.7.6+build.292024/03/2734.68 MiB
Colibri iMX8X
🛈 MD52a7a62d72af889af01045133b89d7669
5.7.6+build.292024/03/2742.99 MiB
Verdin iMX8M Mini
🛈 MD5713b8624d8a0bad150ff73dc1a6d9ab0
5.7.6+build.292024/03/2743.36 MiB
Verdin iMX8M Plus
🛈 MD5e57d987c6fdea23cbe2088da2f86f133
5.7.6+build.292024/03/2743.25 MiB
Older Releases
BSP 2.7, 2.8, 3.0 LTS
OS ImageSupported Modules/Download Link
Tux
Linux Console Image 3.0
Minimal Embedded Linux Image Without Graphical User Interface
Apalis TK1
Apalis TK1 Mainline
Apalis iMX6
Colibri iMX6
Colibri iMX6ULL
Colibri iMX7 Solo 256MB/Dual 512MB
Colibri iMX7 Dual 1GB (eMMC)
Tux
Linux LXDE Image 2.8
Ångström LXDE Desktop Environment Image
Apalis TK1
Apalis TK1 Mainline
Apalis T30
Apalis iMX6
Colibri iMX6
Colibri iMX6ULL (only for devices with 512MB NAND flash)
Tux
Linux LXDE Image 2.7
Apalis T30
Apalis iMX6
Colibri iMX6
BSP 2.7, 2.8, 3.0 older releases
OS ImageSupported Modules/Download LinkSummary Overview
Linux Console Image 3.0b3Apalis TK1
Apalis TK1 Mainline
Apalis iMX6
Colibri iMX6
Toradex Console Image based on Poky
Tux
Linux Console Image 3.0b2Apalis TK1
Apalis TK1 Mainline
Apalis iMX6
Apalis iMX8
Colibri iMX6
Colibri iMX8X
Linux Image without graphical user interface
Tux
Linux Console Image 3.0b1Apalis iMX8Linux Image without graphical user interface
Tux
Linux LXDE Image 2.8b6Apalis TK1
Apalis TK1 Mainline
Apalis T30
Apalis iMX6
Colibri iMX6
Tux
Linux Console Image 2.8b6Colibri iMX6ULLLinux Image without graphical user interface
Tux
Linux LXDE Image 2.8b5Apalis TK1
Apalis TK1 Mainline
Apalis T30
Apalis iMX6
Colibri iMX6
Tux
Linux Console Image 2.8b5Colibri iMX6ULLLinux Image without graphical user interface
Tux
Linux LXDE Image 2.8b4Apalis TK1
Apalis TK1 Mainline
Apalis T30
Apalis iMX6
Colibri iMX6
Tux
Linux Console Image 2.8b4Colibri iMX6ULLLinux Image without graphical user interface
Tux
Linux LXDE Image 2.8b3Apalis TK1
Apalis T30
Apalis iMX6
Colibri iMX6
Tux
Linux Console Image 2.8b3Colibri iMX6ULLLinux Image without graphical user interface
Tux
Linux LXDE Image 2.8b2Apalis TK1
Apalis iMX6
Colibri iMX6
Tux
Linux Console Image 2.8b2Colibri iMX6ULLLinux Image without graphical user interface
Tux
Linux LXDE Image 2.8b1Apalis TK1
Apalis iMX6
Colibri iMX6
Tux
Linux Console Image 2.8b1Colibri iMX6ULLLinux Image without graphical user interface
Tux
Linux LXDE Image 2.7b5Apalis TK1
Tux
Linux Console Image 2.7b5Colibri iMX6ULLLinux Image without graphical user interface
Tux
Linux LXDE Image 2.7b4Apalis iMX6
Colibri iMX6
Tux
Linux Console Image 2.7b4Colibri iMX6ULLLinux Image without graphical user interface
Tux
Linux LXDE Image 2.7b3Apalis iMX6
Colibri iMX6
Tux
Colibri iMX6
Tux
Linux LXDE Image 2.7b2Apalis iMX6
Colibri iMX6
Tux
Linux LXDE Image 2.7b1.1Colibri iMX6
Tux
Linux LXDE Image 2.7b1Apalis iMX6
Colibri iMX6
BSP Monthly Pre-releases
These images are based on pre-production releases of Toradex BSP, which are good for development as you keep up-to-date with the latest features and bugfixes. Learn more about the different image options on BSP Layers and Reference Images for Yocto Project Software.
BSP 7
Apalis iMX8
🛈 MD552301a87bbe66e5ad27a235aa897236e
7.6.0-devel-202603+build.192026/03/0346.86 MiB
Aquila AM69/TDA4
🛈 MD52597ba04e00d0c1090f1d1b3e95d2700
7.6.0-devel-202603+build.192026/03/0372.98 MiB
Aquila iMX95
🛈 MD5d61cd9ed88faf11f1b95b085a12e40bb
7.6.0-devel-202603+build.192026/03/0362.35 MiB
Colibri iMX8X
🛈 MD56959439172a9394481e0e1eb73cbf95b
7.6.0-devel-202603+build.192026/03/0346.68 MiB
Lino iMX93
🛈 MD5942b32dfb9d45c97cf23a618d2f485ff
7.6.0-devel-202603+build.192026/03/0346.92 MiB
OSM iMX93
🛈 MD5800fc6fb167f2296253b4265615aff02
7.6.0-devel-202603+build.192026/03/0346.93 MiB
SMARC iMX8M Plus
🛈 MD50f2c4456bc0e94482a807a471ec0eb4a
7.6.0-devel-202603+build.192026/03/0347.28 MiB
SMARC iMX95
🛈 MD5d968d2302bed281b9ed99f16f3e85945
7.6.0-devel-202603+build.192026/03/0358.32 MiB
Verdin AM62
🛈 MD553b9ddd21372f59beb98b99251c3fe98
7.6.0-devel-202603+build.192026/03/0347.73 MiB
Verdin AM62P
🛈 MD5ef66ccc78ee2dcff8b36fba8ed52f213
7.6.0-devel-202603+build.192026/03/0350.36 MiB
Verdin iMX8M Mini
🛈 MD597e888cb59af9382416c911001a63037
7.6.0-devel-202603+build.192026/03/0346.81 MiB
Verdin iMX8M Plus
🛈 MD582f8139b5e950eecda12ab00219411ba
7.6.0-devel-202603+build.192026/03/0347.30 MiB
Verdin iMX95
🛈 MD51e3a6465ba897755097679fe43564d83
7.6.0-devel-202603+build.192026/03/0358.30 MiB
BSP 6/5
Apalis iMX8
🛈 MD50d4e4088695d150eeedb34aede22cdbf
6.9.0-devel-202411+build.252024/11/0645.61 MiB
Aquila AM69/TDA4
🛈 MD59088a53fa485d5d0a8748ad021071713
6.9.0-devel-202411+build.252024/11/0650.39 MiB
Colibri iMX8X
🛈 MD58598a91abb0c58b013bb2689618b8412
6.9.0-devel-202411+build.252024/11/0645.43 MiB
Verdin AM62
🛈 MD5e7f86d490fa8f35d81d753eb7b71b9d0
6.9.0-devel-202411+build.252024/11/0650.12 MiB
Verdin iMX8M Mini
🛈 MD5b3d3d862e70ad2ee14f98d71450cb01e
6.9.0-devel-202411+build.252024/11/0645.85 MiB
Verdin iMX8M Plus
🛈 MD51b21922d644afe0ffa45c5f8e10569af
6.9.0-devel-202411+build.252024/11/0645.87 MiB
BSP Nightly Pre-releases
These images are based on pre-production releases of Toradex BSP without testing, and may not boot. Typically they are only used in development to focus on a feature or bug fix coming up in a monthly release. Learn more about the different image options on BSP Layers and Reference Images for Yocto Project Software.
BSP 7
Apalis iMX8
🛈 MD5afb91be09d53db96f187dddf9d0955aa
7.7.0-devel-20260429+build.6322026/04/2947.14 MiB
Aquila AM69/TDA4
🛈 MD5f5f92f32b40bfd87125ea2691aa76114
7.7.0-devel-20260429+build.6322026/04/2973.18 MiB
Aquila iMX95
🛈 MD54b7645e09889bb1f36235487eb0cb67e
7.7.0-devel-20260429+build.6322026/04/2962.51 MiB
Colibri iMX8X
🛈 MD54ca3d67fa43845a07f8f8e031f48d5c3
7.7.0-devel-20260429+build.6322026/04/2946.96 MiB
Lino iMX93
🛈 MD54ee65d8783bf2944b302533bb2478c97
7.7.0-devel-20260429+build.6322026/04/2950.15 MiB
OSM iMX93
🛈 MD52d9e79c26372657392bc7e7121540f44
7.7.0-devel-20260429+build.6322026/04/2947.17 MiB
SMARC iMX8M Plus
🛈 MD5b55f67945d77972f3f5d2a2432f97a3e
7.7.0-devel-20260429+build.6322026/04/2947.57 MiB
SMARC iMX95
🛈 MD5c41ddff9207e0aced62b56cc272c2744
7.7.0-devel-20260429+build.6322026/04/2958.49 MiB
Verdin AM62
🛈 MD5962d4ab3efc586c67b61307cb8c5caa7
7.7.0-devel-20260429+build.6322026/04/2947.94 MiB
Verdin AM62P
🛈 MD5b20be391789d897fead7e301ec37eb45
7.7.0-devel-20260429+build.6322026/04/2950.58 MiB
Verdin iMX8M Mini
🛈 MD5206050e485d4a390f125254ffa3dfa0e
7.7.0-devel-20260429+build.6322026/04/2946.99 MiB
Verdin iMX8M Plus
🛈 MD51811fbc3d9be6bc01745647e591fae3b
7.7.0-devel-20260429+build.6322026/04/2947.59 MiB
Verdin iMX95
🛈 MD5bf9dd74638ab9ee71648eace6859c379
BSP 6
Apalis iMX8
🛈 MD5ecb2946667331cb8cd70e9f49d0b1ea0
6.8.8-devel-20260430+build.11432026/04/3045.68 MiB
Colibri iMX8X
🛈 MD52510b7d3d73a4ed880f0e898f4a4304d
6.8.8-devel-20260430+build.11432026/04/3045.53 MiB
Verdin AM62
🛈 MD5a8478551eab37c3e4a8afdbce6d2a3d0
6.8.8-devel-20260430+build.11432026/04/3044.50 MiB
Verdin iMX8M Mini
🛈 MD59312d267185840227810fe7d72ebc3ee
6.8.8-devel-20260430+build.11432026/04/3045.92 MiB
Verdin iMX8M Plus
🛈 MD503f60d97e711163ad056a7df33a71877
6.8.8-devel-20260430+build.11432026/04/3045.94 MiB
BSP 5
Apalis iMX6
🛈 MD5bbf7210bd421ef6b104f97d6c8d12b14
5.7.7-devel-20250106+build.8822025/01/0635.65 MiB
Apalis iMX8
🛈 MD56b5126df5b1b0645a09d20d704bf1aab
5.7.7-devel-20250106+build.8822025/01/0643.25 MiB
Apalis TK1
🛈 MD5903b09945d488247f7cd587f62a3f3e3
5.7.7-devel-20250106+build.8822025/01/0636.21 MiB
Colibri iMX6
🛈 MD53128cc0f8eb955b490601baec212dde5
5.7.7-devel-20250106+build.8822025/01/0634.72 MiB
Colibri iMX6ULL
🛈 MD545cd1e7777db9c75021bbc344d8c315b
5.7.7-devel-20250106+build.8822025/01/0635.90 MiB
🛈 MD52de29ae1978c1ed13779b5f64b16364f
5.7.7-devel-20250106+build.8822025/01/0634.53 MiB
Colibri iMX7
🛈 MD5db9e0fab0b42e381b0464c4dc9794ea3
5.7.7-devel-20250106+build.8822025/01/0636.11 MiB
Colibri iMX7 eMMC
🛈 MD5fe28485bf04270763c1b219674e56dfd
5.7.7-devel-20250106+build.8822025/01/0634.68 MiB
Colibri iMX8X
🛈 MD5d6e7055e9a71615a919fe081bee12967
5.7.7-devel-20250106+build.8822025/01/0643.01 MiB
Verdin iMX8M Mini
🛈 MD5b8b5b373dfb02c0e5c0e5973aac0e439
5.7.7-devel-20250106+build.8822025/01/0643.34 MiB
Verdin iMX8M Plus
🛈 MD59390cf6c054eb824e98441bee93a5fbe
BSP Legacy Images
The legacy image format is the only format supported for Colibri VF50/VF61/T20/T30, only used for BSP 2.8. Not available from BSP 3 onwards.
Downloads may be verified using the following SHA256SUMS file.
Toradex Embedded Linux Stable Releases
Tux
Linux LXDE ImageApalis TK1 (2.8.7 | 2020-06-10)
Apalis TK1 Mainline (2.8.7 | 2020-06-10)
Apalis T30 (2.8.7 | 2020-06-10)
Apalis iMX6 (2.8.7 | 2020-06-10)
Colibri T30 (2.8.7 | 2020-06-10)
Colibri T20 (2.8.7 | 2020-06-10)
Colibri iMX6 (2.8.7 | 2020-06-10)
Colibri iMX7 (2.8.7 | 2020-06-10)
Colibri VFxx (2.8.7 | 2020-06-10)
Angstrom LXDE desktop environment image
Tux
Linux Console ImageColibri VFxx (2.8.7 | 2020-06-10)Linux Image without graphical user interface
For older releases, please visit our separate server.
Toradex Windows Embedded Compact Images
Toradex provides a Windows Embedded Compact (WEC) BSP, including OS image releases.
For further details, please visit the Windows Embedded Compact (WEC) software documentation.
