or cat /etc/issue
on the board.
Qt for Python offers the official Python bindings for Qt (PySide2) to build powerful Graphical User Interfaces (GUI). In this article, we will explain the Qt for Python usage and how you can use it in TorizonCore.
Both QML and Widgets are supported by the Visual Studio Code Extension for Torizon. This article focuses on QML, but while creating a new Torizon project with the extension, you can select a Widget template as a quick start.
This article complies to the Typographic Conventions for Torizon Documentation
$ pip3 install pyside2
Qt for Python project provides pySide2 to implement Qt applications using Python. pySide2 allows access to the complete Qt 5.12+ framework.
A pySide2/QML application requires at least two files:
In this article, we will demonstrate a basic Qt for Python project created from scratch. The source code of the example is available on the project's GitHub page.
QML is a declarative language to describe the user interface.
The QML file of the sample project describes the existing elements in the UI. For example, to create a button, the following code snippet is used:
usr_interface.qmlButton { id: button x: 62 y: 40 width: 94 height: 37 text: qsTr("Temp/Hum") clip: false checkable: false opacity: 1 onClicked: pythonObj.generateEvent() }
In addition to the QML file, it is necessary a Python script to load the QML. In the main Python file of the project, the main function handles the QML file loading.
show_readings.pyif __name__ == '__main__': appObj = QGuiApplication(sys.argv) engineObj = QQmlApplicationEngine() eventObj = EventGenerator() engineObj.rootContext().setContextProperty("pythonObj", eventObj) # Load the QML file with the description of the GUI qmlFile = join(dirname(__file__), 'usr_interface.qml') engineObj.load(QUrl(qmlFile)) if not engineObj.rootObjects(): sys.exit(-1) sys.exit(appObj.exec_())
See the example Dockerfile on Github for this project. Remember to set the IMAGE_ARCH
, IMAGE_NAME
and APPNAME
variables accordingly to your needs. Set IMAGE_ARCH=linux/arm
and IMAGE_NAME=qt5-wayland
for 32-bits SoC (i.MX6, i.MX7) or IMAGE_ARCH=linux/arm64
and IMAGE_NAME=qt5-wayland-vivante
for 64-bits SoC (i.MX8).
The proposed Qt application in this article requires the following pyside2 and QML Debian packages as dependencies:
python3
qml-module-qtquick2
qml-module-qtquick-control
qml-module-qtquick-controls
qml-module-qtquick-dialogs
python3-pyside2.qtcore
python3-pyside2.qtgui
python3-pyside2.qtquick
python3-pyside2.qtwidgets
python3-pyside2.qtqm
python3-pyside2.qtnetwork
Note: you may need to add or remove dependencies based on your project's needs. There are several other qml-module-
Warning: the current version of package python3-pyside2.qtgui
in Debian Bullseye contains a leftover dependency for libqt5gui5
. This may cause conflicts when installing the dependencies in containers for devices with Vivante graphics, because these containers require package libqt5gui5-gles
instead. The Dockerfile example from Toradex works around this issue by installing an adapted version of python3-pyside2.qtgui
See the Torizon Samples Github Page for an example written in Python, reading temperature and humidity from i2c based sht3x sensor and showing it on the GUI developed using QML.
1 - In your development host machine, git clone the Torizon Samples repository:
$ git clone --branch=bullseye https://github.com/toradex/torizon-samples.git
2 - Change to the torizon-samples/python-qml
directory. Build the container image.
$ cd torizon-samples/python-qml $ docker build . -t <your-dockehub-username>/python-qml
3- Push the image to your Dockerhub account:
$ docker push <your-dockehub-username>/python-qml
4- In your board's terminal, pull the Docker container image:
# docker pull <your-dockehub-username>/python-qml
5- The image built with this Dockerfile requires the Qt Wayland container. Therefore, we start the Weston container as the graphics server, as explained on the Qt Debian Container for Torizon, before the application. Select your SoM from the tabs below and follow the instructions:
(Optional) pull the torizon/weston
container image:
# docker pull torizon/weston:$CT_TAG_WESTON
Start the weston
compositor:
# docker run -d --rm --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG \
torizon/weston:$CT_TAG_WESTON --developer weston-launch --tty=/dev/tty7 --user=torizon
container image:
Start the weston
compositor:
# docker run -d --rm --ipc=host --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG \
torizon/weston:$CT_TAG_WESTON --developer weston-launch \
--tty=/dev/tty7 --user=torizon -- --use-pixman
(Optional) pull the torizon/weston-vivante
container image:
# docker pull torizon/weston-vivante:$CT_TAG_WESTON_VIVANTE
Start the weston
compositor:
Attention: Please, note that by executing the following line you are accepting the terms and conditions of the NXP's End-User License Agreement (EULA)
# docker run -e ACCEPT_FSL_EULA=1 -d --rm --name=weston --net=host --cap-add CAP_SYS_TTY_CONFIG \
torizon/weston-vivante:$CT_TAG_WESTON_VIVANTE --developer weston-launch \
6- Run the sample image:
# docker run --rm -it -v /tmp:/tmp \
-v /dev/dri:/dev/dri --device-cgroup-rule='c 226:* rmw' \
A window should pop up with a button and two text fields.
First of all, follow the steps from Python Development and Debugging on TorizonCore Using Visual Studio Code.
The same project can also be built/deployed/debugged/released through VScode using the extension for Python.
1 - Git clone the Torizon Samples repository:
2 - Create a new Python project on VS Code. See Python Development and Debugging on Torizon Using Visual Studio Code article for detailed instructions on how to start and build a new Python project with Torizon.
Warning: Select python3 arm32v7 qt
or python3 arm64v8 qt
as the base image, depending on the target module.
3 - Add all the files from the folder python-qml/python-qml/app
to your VS Code project. You can use the mouse to add and drop these files to your project.
4 - Copy the content from the show_readings.py
file to main.py
, overwriting the original content of the main.py
file. After this, you can remove the show_readings.py
file.
5 - On the appconfig_0
folder of the project, create a new file on the VS Code, with the name docker-compose.yml
. This Docker Compose file defines the containers to start the TorizonCore Debian With Weston Wayland Compositor Image before to display the Qt application. See the image's .yml sample file for arm64v8 or .yml sample file for arm32v7 as reference.
Note: Only the Weston service is needed to be copied to your .yml file.
Warning: for iMX8, also add the following lines to the Weston service to accept NXP's EULA required to run Vivante's graphic drivers
docker-compose.ymlenvironment: - ACCEPT_FSL_EULA=1
6 - Open the Torizon Configurations view, To do that, press F1 in Visual Studio Code command bar and then type "Torizon/Python: Focus on Configurations View"
7 - On the dockercomposefile
property, type docker-compose.yml
8 - Press F5 to build and run your application.
, IMAGE_NAME
and APPNAME
Please note that the pyside2 and QML requires the following Debian packages:
DockerfileRUN apt-get update && apt-get install -y --no-install-recommends \ python3 \ qml-module-qtquick2 \ qml-module-qtquick-controls \ qml-module-qtquick-controls2 \ qml-module-qtquick-dialogs \ python3-pyside2.qtcore \ python3-pyside2.qtquick \ python3-pyside2.qtwidgets \ python3-pyside2.qtgui \ python3-pyside2.qtqml \ python3-pyside2.qtnetwork \ && rm -rf /var/lib/apt/lists/*
Start weston
using the torizon/arm32v7-debian-weston:buster
container image:
--device-cgroup-rule='c 4:* rmw' --device-cgroup-rule='c 13:* rmw' --device-cgroup-rule='c 226:* rmw'\
torizon/arm32v7-debian-weston:buster --developer weston-launch --tty=/dev/tty7 --user=torizon
Start weston
container image:
--device-cgroup-rule='c 4:* rmw' --device-cgroup-rule='c 13:* rmw' --device-cgroup-rule='c 226:* rmw' \
torizon/arm32v7-debian-weston:buster --developer weston-launch --tty=/dev/tty7 --user=torizon -- --use-pixman
Start weston
using the torizon/arm64v8-debian-weston-vivante:buster
container image:
--device-cgroup-rule='c 4:* rmw' --device-cgroup-rule='c 13:* rmw' --device-cgroup-rule='c 199:* rmw' --device-cgroup-rule='c 226:* rmw' \
torizon/arm64v8-debian-weston-vivante:buster --developer weston-launch --tty=/dev/tty7 --user=torizon
file to main.py
file.
