How to use OpenCL 1.2 in iMX8 on Torizon
Article updated at 11 Sep 2020
Torizon 5.0.0
Torizon features a container runtime, Debian container images and a deb package repository that greatly eases the development process for embedded applications. In this article, we will show how you can install and test OpenCL libraries optimized for GPUs available on NXP i.MX8/8X SoCs to integrate into your application. We will also obtain, build, and run an OpenCL benchmarking tool to check if the software is set up correctly and observe the GPU performance.
Dockerfile explained
Image base
Toradex provides a basic Wayland image in its dockerhub page. You need to add the torizon/wayland-base-vivante to your image. It contains the repository package. You also need to get the Vivante's OpenCL Debian package for Torizon.
Building clpeak
Clpeak is a benchmarking tool to measure the peak capabilities of OpenCL devices. We will build it from source for our system.
Run clpeak
In this demo Dockerfile, we will run get the built clpeak from the previous stages and use it as an entry point.
Complete Dockerfile
Now the full Dockerfile implementation should look something like this. The next section will show how to build and run this as a container.
Dockerfile instructions
To get the most out of this article it is recommended you clone the source from our samples github repository.
$ git clone -b bullseye https://github.com/toradex/torizon-samples.git
$ cd torizon-samples/opencl
To build
Inside the opencl directory that contains the Dockerfile on the host PC, build the image:
$ docker build -t <your-dockerhub-username>/opencl-image .
$ docker push <your-dockerhub-username>/opencl-image
To run
First, pull it from your dockerhub account to the board. In the terminal of your board: Warning: These instructions assumes that the dockerhub credentials are already set up on the board. If you did not setup your credentials yet, execute docker login
# docker pull <your-dockerhub-username>/opencl-image
After the pull, run a container based on the image.
Attention: Please, note that by executing the following line you are accepting the NXP's terms and conditions of the End-User License Agreement (EULA)
# docker run -e ACCEPT_FSL_EULA=1 -it --rm --name=clpeak-container --net=host --cap-add CAP_SYS_TTY_CONFIG \
             --device-cgroup-rule='c 4:* rmw'  --device-cgroup-rule='c 13:* rmw' --device-cgroup-rule='c 199:* rmw' --device-cgroup-rule='c 226:* rmw' \
Expected Output
This is the expected output from an Apalis iMX8 board:
Output
Platform: Vivante OpenCL Platform
  Device: Vivante OpenCL Device GC7000XSVX.6009.0000
    Driver version  : OpenCL 1.2 V6.2.4.p4.190076 (Linux ARM64)
    Compute units   : 1
    Clock frequency : 996 MHz
    Global memory bandwidth (GBPS)
      float   : 5.81
      float2  : 9.74
      float4  : 10.63
      float8  : 9.36
      float16 : 8.00
    Single-precision compute (GFLOPS)
      float   : 14.14
      float2  : 28.18
      float4  : 55.87
      float8  : 62.15
      float16 : 61.45
    No half precision support! Skipped
    No double precision support! Skipped
    Integer compute (GIOPS)
      int   : 14.13
      int2  : 14.09
      int4  : 15.84
      int8  : 15.73
      int16 : 14.54
    Transfer bandwidth (GBPS)
      enqueueWriteBuffer         : 1.43
      enqueueReadBuffer          : 0.08
      enqueueMapBuffer(for read) : 301.68
        memcpy from mapped ptr   : 0.08
      enqueueUnmap(after write)  : 269.08
        memcpy to mapped ptr     : 1.43
    Kernel launch latency : 97.56 us
    Compute units   : 1
      float   : 5.59
      float2  : 9.38
      float4  : 10.33
      float8  : 9.15
      float16 : 7.85
      float   : 14.14
      float2  : 28.18
      float4  : 55.87
      float8  : 62.15
      float16 : 61.45
      int   : 14.13
      int2  : 14.09
      int4  : 15.84
      int8  : 15.73
      int16 : 14.54
      enqueueWriteBuffer         : 1.42
      enqueueMapBuffer(for read) : 238.44
      enqueueUnmap(after write)  : 207.03
        memcpy to mapped ptr     : 1.44
    Kernel launch latency : 126.82 us
Torizon 4.0.0
Torizon features Docker runtime. Toradex provides Debian Docker images and deb packages that greatly eases the development process for embedded applications. In this article, we will show how you can install and test OpenCL libraries optimized to iMX8 GPU to integrate into your application. We will also obtain, build, and run an OpenCL benchmarking tool to check if the software is set up correctly and observe the GPU performance.
  • A Toradex's i.MX8 SoM with Torizon installed ( To get instructions about how to install Torizon, see the Quickstart Guide )
  • Basic knowledge of Docker containers. To learn more about Docker, visit the developer's website. To learn the first steps with Docker usage and Torizon, check the Quickstart Guide.
Image base
Toradex provides a basic Wayland image in its dockerhub page. You need to add the torizon/arm64v8-debian-wayland-base-vivante to your image. It contains the repository package. You also need to get the Vivante's OpenCL Debian package for Torizon.
Building clpeak
Run clpeak
Complete Dockerfile
To build
To run
Expected Output
Output
    Compute units   : 1
      float   : 5.81
      float2  : 9.74
      float4  : 10.63
      float8  : 9.36
      float16 : 8.00
      float   : 14.14
      float2  : 28.18
      float4  : 55.87
      float8  : 62.15
      float16 : 61.45
      int   : 14.13
      int2  : 14.09
      int4  : 15.84
      int8  : 15.73
      int16 : 14.54
    Compute units   : 1
      float   : 5.59
      float2  : 9.38
      float4  : 10.33
      float8  : 9.15
      float16 : 7.85
      float   : 14.14
      float2  : 28.18
      float4  : 55.87
      float8  : 62.15
      float16 : 61.45
      int   : 14.13
      int2  : 14.09
      int4  : 15.84
      int8  : 15.73
      int16 : 14.54
