Visual Studio Code Extension for Torizon
  1. Torizon 5.0.0
    1. Introduction
    2. Prerequisites
    3. Install the Visual Studio Code Extension for Torizon
      1. Install the .Net Core SDK on Windows
      2. Install the Windows Subsystem for Linux (WSL2)
      3. Install the .Net Core SDK on Linux
      4. Configure a Local Docker Registry (Optional)
      5. Configure a Shared Docker Registry (Optional)
      6. Add Target Device Connection In Visual Studio Code
    4. Setup of SSH Connection
    5. Create and Configure a Project
    6. Deploy and Debug
      1. Add Breakpoints
      2. Start Debugging
      3. Get Debug Information in the Right Places
      4. Configure Multi Container Services with Docker Compose
    7. Deploy and Release
      1. Build Release Container Image
      2. Deploy Release Container Image
      3. Run Release Container Image
      4. Push a Release Container Image to a Registry
    8. Beyond the Release and Production Programming
      1. Generate a Dockerfile for the Application
      2. Generate a Docker Command to Run the Application
      3. Generate a Docker Compose File to Deploy the Application With Torizon OTA
      4. Remove IDs and Keys Before Publishing Source-code to a Public Repository
    9. Visual Studio Code Extension Commands
    10. Next Steps
      1. Application Development for Torizon
      2. Production Programming
  2. Webinars
    1. Zero to Hero: Visual Studio Code for Embedded Linux Development
    2. Update to a Newer Debian Container Version
  3. Torizon 4.0.0
    1. Update to a Newer Debian Container Version
    2. Introduction
    3. Prerequisites
    4. Install the Visual Studio Code Extension for Torizon
      4. Enable ARM Emulation Mode
      5. Add Target Device Connection In Visual Studio Code
    5. Visual Studio Code Extension Commands
    6. Known Issues
Article updated at 03 Dec 2020
Torizon 5.0.0
Toradex offers a VS Code extension to help users to develop, deploy, and debug applications on TorizonCore. The following programming languages are currently supported:
  • C/C++
  • Python 3.9
  • .NET Core Framework 3.1 and 5.0
This article demonstrates how to set up the recommended configuration comprising:
  • Visual Studio Extension for Torizon
  • .NET Code SDK (Required for .NET Core applications only)
  • Windows Subsystem for Linux - WSL2 (Only for Windows host machine )
Note: Make sure that the board and development computers are on the same network.
The latest versions of the Toradex Torizon Support extension can be found on the Visual Studio Code marketplace, in two versions:
Click on the Extensions button in Visual Studio Code as shown in the image below and search for Toradex Torizon Support, then select the option you prefer among the ones presented above:
  • Toradex Torizon Support Extension for Visual Studio Code
Verify that the extension has been enabled:
  • Torizon extension
    Torizon extension
Choose your development PC OS from the tabs below:
Warning: Required for .NET Core applications only
Download the latest .NET Core SDK on Microsoft Official Website and follow the setup installation. To check if everything went well, open up a command prompt, and run the following command:
$ dotnet
If the installation was successful, you should see the .NET options on the command prompt.
Expected result
To obtain the Linux subsystem, please refer to the Microsoft instructions. After following all the steps, reboot your machine.
Warning: WSL2 requires Windows 10, updated to version 2004 (also known as the Windows 10 May 2020 Update) or higher.
WSL Setup Video
You may want to install Windows Terminal from the Microsoft Store to improve your experience using wsl.
Open the Microsoft Store and install a distro. We recommend Ubuntu 18.04 LTS. When the process ends, open CMD and run the following command:
$ wsl
It will ask for your username and password, write it. After setting up your credentials, run the command below to see some information about the distro:
$ wslfetch
  • Wsl output
    Wslfetch output
After evaluating the Windows Subsystem for Linux works, install rsync and ssh from the Linux prompt:
$ sudo apt-get update && sudo apt-get install rsync ssh
Check if Ubuntu 18.04 LTS is the default wsl distro on your system by running the command bellow:
$ wsl -l -v
  • wsl -l -v output
    wsl -l -v output
Your default distro is represented by the *. If your output is similar to the one above (docker-desktop or another distro being the default), make Ubuntu default distribution by typing the following command:
$ wsl -s Ubuntu-18.04
  • wsl -s Ubuntu-18.04 output
Follow the .NET Microsoft Documentation to install it on Linux, and make sure you select the correct distribution on the left.
You can test if everything went well by running the following command:
$ dotnet --info
Expected result
By default, our extension deploys applications to the board via SSH. This works well because it does not require any extra configuration on your PC, but the tradeoff is that it takes longer to re-deploy the application when the base container needs to be rebuilt. To overcome this penalty and rely on the layers approach used by Docker, you may opt-in to use a local Docker registry.
To enable the use of a local Docker registry managed by the extension, create the following file on your PC:
  • For Windows: %USERPROFILE%\.moses\server.yaml
  • For Linux: $HOME/.moses/server.yaml
server.yaml
deployment:
  registry: "local"
Close and re-open Visual Studio Code before proceeding.
Tip: this is an advanced use case. If you are just starting, either go with the default configuration or see how to configure a local Docker registry in the previous section.
You may want to bring up your own registry instead of the one managed by the extension.
To enable the use of a shared Docker registry managed by you in your PC or another PC on your LAN, create the following file on your PC:
server.yaml
deployment:
  registry: "<hostname:port of your registry>"
  # example registry: "192.168.10.5:6000"
  proxy: true
The proxy variable will create a proxy on the board that redirects connections to the given registry. The default value is true, even if you omit it. When you set it to false, it is up to you to configure a secure registry and install self-signed certificates.
To debug and test our application, we need a device to deploy it. Go to the Torizon tab and see that your "devices" view is empty. Click on Add Device and choose to either add the device using the Network connection or over the Serial Port. The end result will be the same, regardless of the method chosen:
  • Network: you must make sure that your SoM is on the same network as your development PC, and your PC can reach this address. You must know in advance the IP address or the hostname. If using the hostname, make sure to add the suffix .local. If you don't have either, then learn how to find your IP or learn how to find your hostname or try registering the device using the Serial Port method.
  • Serial Port: you must have access to the serial port and know what is the corresponding device, usually /dev/ttyUSBx on Linux or COMx on Windows.
Either way, you will be prompted to enter a valid username and password that is on your Torizon device (remember that the default is torizon and torizon, but you should change the password on the first boot). Once you type in the credentials, the device will reboot. The device will be listed in the Devices view of the Torizon tab and, as soon as the reboot is complete, you'll be able to see some device info. You should see some dialog in the Terminal output of VS code that shows whether the connection was a success or not.
See how both methods work:
  • Adding a Torizon Device
If you prefer to use the VS Code command palette, open it by pressing F1 or Ctrl + Shift + P, then use the following commands with the same instructions above:
  • Network: Torizon: Detect device via network connection
  • Serial Port: Torizon: Detect device via serial port connection
  • Adding a Torizon device using the command palette
Please make sure to have followed the instructions for installing the WSL2 if you are running Windows.
Connecting to the board via SSH is made easy with the extension.
Read the section Using the Visual Studio Code Extension for Torizon from the SSH article to learn how.
The creation and setup of a new project is dependent of the programming language you choose. Therefore, we expect that you follow one of the articles below, since they are the entry point for those languages:
After you finish following them through, come back to the current article and proceed to the next sections, which are again common to all programming languages.
Deploy and Debug
Attention: on Windows, make sure to disable buildkit as explained on Configure Build Environment for Torizon Containers, otherwise, build errors may happen.
The deploy and debug process, from your perspective, is common to all supported languages. Under the hood, each language has its own debugging setup, but that is made transparent.
Add Breakpoints
Open your source-code files and click on the left side of a line number to add a breakpoint. If you right-click, you can choose to add a conditional breakpoint or a logpoint.
If you have issues adding breakpoints, enable the use of breakpoints everywhere. Go to File --> Preferences --> Settings and search for Debug: Allow Breakpoints Everywhere, then tick the box Allow setting breakpoints in any file.
Start Debugging
To start the process, all you have to do is press F5. Alternatively, you can select the menu Run and click on Start Debugging. A third method would be to open the command palette and type Debug: Start Debugging. The extension will build your application along with the debug container, deploy them to the board, and start the debugging session. You may be prompted to select a device if you have more than one added to the extension.
If you make changes to your application source-code and run the process again, only the application will be redeployed, making the process faster. On the other hand, if you add development or runtime packages, update the project configuration or add any other resources that impact the containers, they will be rebuilt and the process will take a bit longer for that specific run.
If your application has an infinite loop, you can simply stop the debugger to kill it.
  • Vscode Debug Session in C, Python and .NET
Most problems will be printed to the Terminal, Problems, Output and Debug Console tabs of VS Code. You can open them by going to the View menu, or with the shortcut Ctrl + Shift + ´.
  • VS Code Terminal, Output and Debug Tabs
In the Output, you can choose the Torizon output to get more information about the build and debug process, and more:
  • VS Code Torizon Output
In the Terminal, you can choose some terminals with useful information, depending on the project you are running, etc. The Torizon IDE backend process will always be available, and as you run commands you can find other terminals as the Task - deploy and the Torizon - Container Application Output:
  • VS Code Terminals
    VS Code Terminals
In the Debug, you can see and search for specific debug output:
  • VS Code Debug
    VS Code Debug
Docker-compose is used to define and run multi-container applications, and on our Visual Studio Extension is no different, there are two scenarios:
  • On graphical projects, such as a Python Qt QML Application, a docker-compose.yml.debug file for torizon/weston is generated on the /appconfig_0/work/ folder on the first time you build the application:
docker-compose.yml.debug Attention: Do not edit the autogenerated docker-compose.yml.debug file! It is overridden by the Torizon extension every time you rebuild your project, and therefore your changes will be lost. Keep on reading to learn how to properly add your own docker-compose.yml to a Torizon project.
  • On headless applications, such as a Python Console Application, there is no docker-compose.yml.debug file on the /appconfig_0/work/ folder, in order to configure your project, you need to create the docker-compose file as exemplified in the next paragraph.
For the two scenarios above, let's suppose that you want to add an environment variable to Weston or, do you need to start a container after any other container, as explained and exemplified on the Using Multiple Containers with TorizonCore article, how could you do that?
It's simple, just create a docker-compose.yml (for graphical projects, you might want to copy the docker-compose.yml.debug and then add your changes) file on the root of appconfig_0 and apply it on the configurations view of the Torizon extension, just like in the video below:
  • Creating and using your own docker-compose file
Deploy and Release
The deploy and release commands are common to all supported languages. They consist of tasks to build, deploy to the board, run on the board, and push images to a container registry.
To build a release container, on the VS Code command palette, run Torizon: Build release container for the application. It may take several minutes.
Please note that building a release container is not related to switching between debug and release configuration, if the language supports both. If you build a release container while in debug mode, the application deployed will have the debug symbols and everything else that is defined by the debug configuration.
In addition, you can add a custom property named tag to the project. You must use a regular Docker tag and the extension will tag your release container image accordingly, for example, my-user/my-container:my-version.
To deploy a release container, on the VS Code command palette, run Torizon: Deploy release container. It will deploy to the board the image built in the previous step.
On the VS Code command palette, run Torizon: Run/restart release container. It will run on the board the image deployed in the previous step.
Before the application container starts, all other containers described in the Docker Compose files appconfig_0/work/docker-compose.yml, appconfig_0/work/docker-compose.yml.debug or appconfig_0/work/docker-compose.yml.release, depending on the present project configuration, will also be started on the board by the IDE.
  • Building, Deploying and Running a Release Container
At some point in your development, you will need to push the container to a registry. You can learn more about it on Deploying Container Images to TorizonCore.
Before pushing the container, build a release container as described in the steps above.
Push the release container by opening the command palette and running Torizon: Push application container to a docker registry. It will ask you to add a tag if you haven't done it before, and you must use a regular Docker tag. If you are using Docker Hub, make sure that it begins with your user name, because your username is also your namespace). The extension will also ask you to enter the registry username and password.
  • Pushing a Container Image to Docker Hub
Tip: you can also push images to repositories other than Docker Hub. In the tag property you can specify the registry, as long as you use a compatible Docker tag. If, for instance, you have a local registry that is not protected with credentials, you can leave the fields username and password empty when prompted by the push command.
Additional commands to generate a command-line to run the application without the extension, and to generate a Docker Compose file, useful in many scenarios such as deploying the application through the TorizonCore Builder Tool or Torizon OTA, are explained in this section. You may find it useful to read the conceptual article Deploying Container Images to TorizonCore.
Since the IDE Extension builds a container image for your application under the hood, that means that there is a Dockerfile behind it somewhere. There are actually two Dockerfiles, one for debug and the other for release. We advise you not modify it manually, but it may be useful to check for debugging corner cases, or simply if you want to keep it for any reason.
The Dockerfiles are available under appconfig_0/work/<project name>/ and they are named Dockerfile.debug and Dockerfile.release. If any of them is missing that is because you haven't yet followed through the previous sections Deploy and Debug and Deploy and Release from this article.
For C/C++, additional Dockerfile_SDK.debug and Dockerfile_SDK.release may be available. Those are the Dockerfiles that create the SDK containers, as explained on C/C++ Development and Debugging on TorizonCore Using Visual Studio Code.
  • Create and Open the Release and Debug Dockerfiles
The IDE extension runs containers on the board. In some cases, you may need to know how to run the containers manually, either because you are done with development or for some other reason you want to run it outside the IDE. On Torizon, currently, that means:
This section explains how to generate a docker run command from the IDE, and the next section explains how to generate a Docker Compose file.
Open the command palette and run Torizon: export docker command line, select if you want to export it fordebugorrelease`. The docker command-line will be printed in the Torizon output tab.
  • Export the Docker Run Command Lines for Debug and Release
Tip: this is very different from the Docker Compose file presented on Deploy and Debug - Configure Multi Container Services with Docker Compose. The purpose of the former is to configure project dependencies using a Compose file to achieve that goal. The purpose of this section is to generate a final Compose file to easily run your project without the IDE Extension, being Torizon OTA one of the main use cases.
Open the command palette and run Torizon: export docker-compose file, select if you want to export it for debug or release, and a text editor with the file content will open. Notice that you must save the file.
This is a very useful command, because it bridges the IDE Extension to the TorizonCore Builder Tool and Torizon OTA. With them you can:
Get Started With Torizon OTA
  • Export Docker Compose Files for Debug and Release then Upload to Torizon OTA
IDs and keys are automatically generated by the extension. Before sharing it with others or publishing it to a public repository, for instance on GitHub or similar, those IDs and keys should be removed to avoid that all forks of a project will have the same container names and keys.
Open the command palette and run Torizon: Remove IDs and keys from application. A warning will show up explaining that you will need to close and re-open the project before being able to build, deploy and debug the app again. Accept it and add your source-code to your version control system (such as Git).
On Visual Studio Code, executing commands is easy: you need to press F1 to open the command palette then type the command you want. It is easy to find all commands inside VS Code, you just have to go to the Extensions tab, select the Torizon extension, and click on the Feature Contributions tab:
  • Find Extension Commands
Next Steps
Now that you have the extension set up, choose what you want to do next.
You can use release images for production programming. There are two phases and tools:
Webinars
Visual Studio Code related-webinars that you can watch on-demand.
Debian Containers for Torizon are subject to updates, including major updates to newer versions of Debian. Learn more about it, including how to update your VS Code project:
Torizon 4.0.0
  • Python
  • .NET Core
  • ARM emulation mode (Only for Linux host machine)
  • Development Computer with
  • One of the OS below:
    • Windows 10 version 2004 (a.k.a. May 2020 update) or higher.
    • Linux (it was validated using Ubuntu 18.04)
  • Toradex Computer on Module (CoM) with TorizonCore installed.
  • Torizon extension
    Torizon extension
$ dotnet
Expected result
$ wsl
It will ask for your username and password, write it, and re-run the command to see the following output:
  • Wsl output
    Wsl output
$ dotnet --info
Expected result
The VS Code extension needs ARM emulation mode enabled through binfmt. To allow it, press F1 and type "Torizon: Enable ARM emulation for Docker containers":
  • Torizon Enable ARM Emulation
Click on continue in the following window:
  • Continue arm emulation
If everything goes well, you should see the ARM emulation enabled message in your Visual Studio Code.
To debug and test our application, we need a device to deploy it. Open Visual Studio Code and press F1 to open the command bar, then you can run one of two commands below to add a device connected over the network or over serial.
The command torizon.detectSerialDevice will add a serial connection to a Torizon device. The interface will prompt to specify the port on your development PC connected to the device over serial.
The command torizon.detectNetworkDevice will add a network connection to your Torizon device. The interface will request to specify the IP address of your Torizon device. Just make sure that your SoM is on the same network as your development PC, and your PC can reach this address.
Either way, you will then be prompted to enter a valid username and password that is on your Torizon device; this will make it briefly reboot. You should see some dialog in the Terminal output of the VS code that shows whether the connection was a success or not. Also, if you’ve already created a Torizon Project, then the device will be listed via the Torizon extension sidebar menu.
Expected Result:
  • Adding a device - expected result
On Visual Studio Code, executing command is easy: you need to press F1 to open the command bar then type the command you want. Here is a list with every command and its respective action and category
Command Action Category
torizon.createPythonApp Create Python Application Torizon/Python
torizon.createDotNetCoreApp Create .NET Core Application Torizon/.NET
torizon.createAspDotNetCoreApp Create ASP.NET Application Torizon/.NET
torizon.detectSerialDevice Detect device via serial port connection Torizon
torizon.detectNetworkDevice Detect device via network connection Torizon
torizon.deleteDevice Remove device from device list Torizon
torizon.selectDevice Select default deployment device Torizon
torizon.buildPythonReleaseContainer Build release container for Python application Torizon/Python
torizon.enableARMEmulation Enable ARM emulation for docker containers Torizon
torizon.deployReleaseContainer Deploy release container Torizon
torizon.runReleaseContainer Run/restart release container Torizon
torizon.updateContainers Download/update base containers Torizon
torizon.buildDotNetReleaseContainer Build release container for .NET application Torizon/.NET
Known Issues
  • The extension will start the back-end server, which takes around 30 seconds. If you try to run commands during that time, you’ll get an error.
  • Toradex provides templates for 32 and 64 bits containers. At the moment, the 32bit version is the one used for the test during development. Feel free to test on the 64bit version.
  • There is no UI to configure projects, monitor devices, etc. (will come soon). At the moment, you can edit config.yaml in the appconfig_0 folder. See Moses IDE Backend for reference.
