WiFi Support on Toradex’s Linux Images
Article updated at 23 Oct 2019
Toradex offers a range of Computer on Modules (COMs) with WiFi/BlueTooth integrated:
Module Version Product Description Wi-fi Adapter Bluetooth version Adapter's Chipset Antenna Configuration
Colibri iMX8X from V1.0A QuadXPlus 2GB Wi-Fi / Bluetooth IT and DualX 1GB Wi-Fi AzureWave AW-CM276NF Bluetooth 5.0 complaint with Bluetooth 2.1 Marvell 88W8997 Dual-Band 802.11ac 2x2 MU-MIMO
Apalis iMX8 from V1.0A QuadMax 4GB Wi-Fi / Bluetooth ITand QuadPlus 2GB Wi-Fi / Bluetooth AzureWave AW-CM276NF Bluetooth 5.0 complaint with Bluetooth 2.1 Marvell 88W8997 Dual-Band 802.11ac 2x2 MU-MIMO
Apalis iMX8X from V1.0A QuadXPlus 2GB Wi-Fi / Bluetooth IT AzureWave AW-CM276NF Bluetooth 5.0 complaint with Bluetooth 2.1 Marvell 88W8997 Dual-Band 802.11ac 2x2 MU-MIMO
Colibri iMX6ULL from V1.1A 512MB Wi-Fi / Bluetooth ITand 512MB Wi-Fi / Bluetooth AzureWave AW-CM276NF Bluetooth 5.0 complaint with Bluetooth 2.1 Marvell 88W8997 Dual-Band 802.11ac 2x2 MU-MIMO
Colibri iMX6ULL V1.0x 512MB Wi-Fi / Bluetooth Wi2Wi WM828CC6 Bluetooth 4.2 Marvell 88W8887 Dual-Band 802.11ac 1x1 spatial stream
For modules that don't come with on-module Wi-Fi hardware, a mini-PCIe, SDIO or USB Wi-Fi module can be used.
Toradex's Embedded Linux BSPs only provide out-of-the-box software support for the LM006 Wi-Fi dongle, Wi2Wi WM828CC6, and AzureWave AW-CM276NF modules.
This article will show you how to set up both the WiFi module integrated on Toradex-Computer-on-Modules (COMs) or external 3rd party modules.
Other Wi-Fi related articles
If this is not the information you are looking for, please, expand the menu below for more WiFi related information.
3rd Party WiFi interface modules
Alternatively, many off-the-shelf Wi-Fi modules will work just fine once the matching driver is compiled into a custom Linux kernel. For a complete list of tested modules, see the Toradex modules with WiFi connectivity and 3rd-party Tested Devices page
Note that most Wi-Fi modules require matching firmware as well. It is recommended to first test the selected WiFi module on a regular PC running Linux (e.g. using a mini-PCIe to PCIe adapter if required). Make sure to use a Linux kernel version as close as possible to the version running on the Toradex module. This procedure not only checks if the module works reliably but also can be used to copy the matching firmware from there if required.
Note: Since the Embedded Linux BSP 2.7b4, the driver backports are added to the Toradex pre-built image. Please see the Kernel Driver Backports Integration article for further information.
Also see the Linux BSP Release, where you can filter for information about the Wi-Fi Subsystem, and the official Linux Wireless wiki, where you can get information such as the supported chips and their drivers status, as well as how to install firmware, among other information.
Custom Kernel
To enable support for other Wi-Fi hardware a custom Linux kernel is required. Please refer to the following article concerning its setup/compilation:
Build U-Boot and Linux Kernel from Source Code
And once completed continue with the driver backports article:
Modules with integrated Wi-Fi Interfaces - Station vs. Access Point
root@colibri-imx6ull:~# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,DYNAMIC,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 00:14:2d:2e:e4:94 brd ff:ff:ff:ff:ff:ff
=> wired Ethernet
3: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
    link/can
=> MCP2515 SPI CAN controller available on the Colibri Evaluation board
4: usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
    link/ether 00:14:2d:ff:ff:ff brd ff:ff:ff:ff:ff:ff
=> USB RNDIS
5: mlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 00:19:88:5e:10:de brd ff:ff:ff:ff:ff:ff
=> Regular station Wi-Fi interface (e.g. to connect to Wi-Fi networks)
6: uap0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/ether 00:19:88:5e:11:de brd ff:ff:ff:ff:ff:ff
=> Access point Wi-Fi interface (e.g. to be used with hostapd)
If the access point interface is not required one may just delete the following module configuration:
root@colibri-imx6ull:~# cat /etc/modprobe.d/mwifiex.conf
options mwifiex driver_mode=0x3
Physical interfaces
Mini-PCIe
Our embedded Linux BSPs so far do not support any mini-PCIe Wi-Fi modules out-of-the-box. However we successfully tested various mini-PCIe Wi-Fi modules based on Broadcom (e.g. BCM4311KFBG) and Intel (e.g. 4965AGN, 6230AGN, ,N-1000 and N-7260) chip sets.
To configure e.g. support for the Intel 6230AGN mini-PCIe module one has to enable CONFIG_IWLAGN as follows:
[user@host linux-toradex]$ make menuconfig
Device Drivers --->
[*] Network device support --->
[*] Wireless LAN --->
<*> Intel Wireless WiFi Next Gen AGN - Wireless-N/Advanced-N/Ultimate-N (iwlagn)
< Exit > (4 times)
Do you wish to save your new configuration? < Yes >
Then just compile and deploy the custom kernel as explained in the above mentioned article.
During boot one gets the following kernel messages:
[ 7.290881] Intel(R) Wireless WiFi Link AGN driver for Linux, in-tree:
[ 7.344598] iwlagn 0000:04:00.0: HW Revision ID = 0x34
[ 7.357966] iwlagn 0000:04:00.0: Detected Intel(R) Centrino(R) Advanced-N 6230 AGN, REV=0xB0
[ 7.369558] iwlagn 0000:04:00.0: L1 Disabled; Enabling L0S
[ 7.396050] iwlagn 0000:04:00.0: device EEPROM VER=0x716, CALIB=0x6
[ 7.405308] iwlagn 0000:04:00.0: Device SKU: 0X1f0
USB
The following USB Wi-Fi sticks with the Realtek RTL8188CUS/RTL8188EUS chip set are supported out-of-the-box. However we successfully tested various USB Wi-Fi modules based on Ralink(e.g RT5370, RT5572), Realtek(e.g RTL8188CUS, RTL8192EU chipset), Zydas(e.g ZD1211B).
  • LM006 USB Wi-Fi
During boot or upon insertion the following kernel messages identify the LM006 stick:
[ 55.779953] usb 3-1: new high speed USB device number 3 using tegra-ehci
[ 55.971825] usb 3-1: New USB device found, idVendor=0bda, idProduct=8176
[ 55.978538] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 55.985743] usb 3-1: Product: 802.11n WLAN Adapter
[ 55.990587] usb 3-1: Manufacturer: Realtek
[ 55.994688] usb 3-1: SerialNumber: 00e04c000001
[ 56.151090] rtl8192cu: MAC address: 5c:f3:70:24:97:e5
[ 56.156167] rtl8192cu: Board Type 0
[ 56.171585] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
In user space it can be identified by lsusb as follows:
root@colibri_t20:~# lsusb
Bus 003 Device 003: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Legacy information regarding the Ambicon WL250N USB WiFi firmware
SDIO
We successfully tested the WiBear 11n SDIO Wifi wireless adapter module based on Marvel 8787 chipset. In addition, Wi2Wi WM828CC6 is employed as the on-module Wi-Fi for some models of the Colibri iMX6ULL SoM, and thus supported out-of-the-box in our BSP.
To configure support for the Marvel 8787 SDIO wireless adapter module one has to enable CONFIG_MWIFIEX, CONFIG_MWIFIEX_SDIO as follows:
Device Drivers --->
<*> Marvell WiFi-Ex Driver
<*> Marvell WiFi-Ex Driver for SD8786/SD8787/SD8797/SD8887/SD8897
< Exit > (4 times)
[ 392.591781] mmc1: new high speed SDIO card at address 0001
[ 393.583165] mwifiex_sdio mmc1:0001:1: WLAN FW is active
[ 394.068554] mwifiex_sdio mmc1:0001:1: ignoring F/W country code US
[ 394.118806] mwifiex_sdio mmc1:0001:1: driver_version = mwifiex 1.0 (14.66.35.p52)
[ 429.748907] IPv6: ADDRCONF(NETDEV_UP): mlan0: link is not ready
Firmware
Most Wi-Fi hardware uses specific firmware to operate properly. Certain such firmware can easily be installed as follows:
opkg update
opkg --force-depends install linux-firmware
Wi-Fi Connection Bring Up
Wi-Fi Connection Bring Up BSP V1.x
On images V1.x the following brings up the connection from the command line:
ifconfig wlan0 up
iwlist wlan0 scanning
wpa_supplicant -Dwext -iwlan0 -c/etc/wpa_supplicant.conf
# -dd for debugging
# -B for background daemon
To do WEP, WPA or WPA2 just edit /etc/wpa_supplicant.conf and add the information about your wireless network infrastructure.
If you erroneously specify proto=WPA but do have a WPA2 infrastructure, wpa_supplicant returns the following error message if run with debugging (-dd) enabled:
wlan0: skip - no WPA/RSN proto match
Wi-Fi Connection Bring Up BSP V2.x
On images V2.x the connman package provides connectivity management.
http://connman.net
Automatic (GUI)
The connections can be configured by starting the configuration program connman-properties or by starting the taskbar applet connman-applet.
Interactively
Note: On the Colibri iMX6ULL make sure to connect to the mlan0 Wi-Fi interface which may be distinguished based on their MAC addresses.
root@colibri-imx6ull:~# connmanctl
Error getting VPN connections: The name net.connman.vpn was not provided by any
connmanctl> enable wifi
[  426.104116] IPv6: ADDRCONF(NETDEV_UP): mlan0: link is not ready
[  426.145123] IPv6: ADDRCONF(NETDEV_UP): uap0: link is not ready
Enabled wifi
connmanctl> scan wifi
[  452.706815] ieee80211 phy0: mwifiex_cfg80211_sched_scan_start : Invalid Sched_scan parameters
Scan completed for wifi
connmanctl> agent on
Agent registered
connmanctl> services
    testnet             wifi_0019885e10de_666167776c616e32_managed_psk
    testnet             wifi_0019885e11de_666167776c616e32_managed_psk
connmanctl> connect wifi_0019885e10de_666167776c616e32_managed_psk
Agent RequestInput wifi_0019885e10de_666167776c616e32_managed_psk
  Passphrase = [ Type=psk, Requirement=mandatory ]
Passphrase? testpw
connmanctl> [  637.111283] mwifiex_sdio mmc1:0001:1: info: trying to associate to 'testnet' bssid 44:d9:e7:fa:cf:d5
[  637.137213] mwifiex_sdio mmc1:0001:1: info: associated to bssid 44:d9:e7:fa:cf:d5 successfully
[  637.194021] IPv6: ADDRCONF(NETDEV_CHANGE): mlan0: link becomes ready
[  676.632838] ieee80211 phy0: mwifiex_cfg80211_sched_scan_start : Invalid Sched_scan parameters
Connected wifi_0019885e10de_666167776c616e32_managed_psk
connmanctl> quit
Manual
Our latest V2.x images also include a command-line configuration tool called connmanctl:
https://gist.github.com/kylemanna/6930087
As follows how to connect to a WPA PSK enabled Wi-Fi using an LM006 USB stick, or the Colibri iMX6ULL 512MB WB on-module Wi2Wi WM828CC6 adapter.
First plug in the Wi-Fi USB stick (LM006 only):
Then enable the Wi-Fi technology layer:
root@colibri-t30:~# connmanctl enable wifi
[ 531.793311] rtl8192cu: MAC auto ON okay!
[ 531.857315] rtl8192cu: Tx queue select: 0x05
[ 531.863386] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cufw.bin
[ 532.376983] ADDRCONF(NETDEV_UP): wlan0: link is not ready
Enabled wifi
And scan for available networks:
root@colibri-t30:~# connmanctl scan wifi
Now show what the above actually found:
root@colibri-t30:~# connmanctl services
*AR Wired { ethernet_00142d486cef_cable }
<SSID> { wifi_<HASH>_managed_psk }
Finally adjust the security aka WPA PSK configuration:
root@colibri_t30:~# vi /var/lib/connman/<SSID>-psk.config
[service_wifi_<HASH>_managed_psk]
Type = wifi
Name = <SSID>
Passphrase = <PASSPHRASE>
Last but not least attempt to connect:
root@colibri_t30:~# connmanctl connect wifi_<HASH>_managed_psk
[ 1165.219739] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Connected
If you still have wired Ethernet connected make sure to disconnect the cable in order for Wi-Fi to take over:
root@colibri-t30:~# [ 653.968178] eth0: ax88772b - Link status is: 0
[ 654.026020] ADDRCONF(NETDEV_UP): eth0: link is not ready
Configuring Wi-Fi with static IP address
Configuring Wi-Fi with a static IP address can be done using the connman-applet with a graphical user interface. If one does not have a GUI, the process must be done via the command line interface.
When a WPA PSK configuration file is created, connman automatically configures Wi-Fi to use DHCP and does not allow manual changes to the IP address as it would for an Ethernet connection using connmanctl.
If the following file was created before, it needs to be deleted, as it conflicts with a new file that will be created:
First create the following directory (where is the hash identifier assigned to the device by connman):
mkdir /var/lib/connman/wifi_<HASH>_managed_psk
Inside the directory, create a file named “settings”:
vi /var/lib/connman/wifi_<HASH>_managed_psk/settings
The file should contain the following:
[wifi_<HASH>_managed_psk]
Name=<SSID> ← Name of your network
SSID=544f52414445585f4252 ← Name of your network in hexadecimal format
Favorite=true
IPv4.method=manual ← Method to be used (in our case manual IP)
IPv4.netmask_prefixlen=24
IPv4.local_address=192.168.0.133 ← Desired IP address
IPv4.gateway=192.168.0.1
Passphrase=<PASS> ← Wi-Fi network password
AutoConnect=true
In this next step we have three options, one can use what is best suited to the application:
  • reboot the module;
  • disconnect and reconnect the Wi-Fi module (if it was already connected);
  • restart the USB bus port with the following commands:
echo '1-1' > /sys/bus/usb/drivers/usb/unbind
echo '1-1' > /sys/bus/usb/drivers/usb/bind
Now enable the Wi-Fi technology layer:
Finally, simply connect to the network:
With all the steps concluded, the module should be connected with the chosen static IP address and it is now possible to freely change the IP address using connmanctl.
