Toradex offers a range of Computer on Modules (COMs) with WiFi/BlueTooth integrated:
System on Module | Version |
Apalis iMX8 QuadMax 4GB Wi-Fi / Bluetooth IT | V1.0A and newer |
Apalis iMX8 QuadPlus 2GB Wi-Fi / Bluetooth | V1.0A and newer |
Apalis iMX8X QuadXPlus 2GB Wi-Fi / Bluetooth IT | V1.0A and newer |
Verdin iMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT | V1.0A and newer |
Colibri iMX8X QuadXPlus 2GB Wi-Fi / Bluetooth IT | V1.0A and newer |
Colibri iMX8X DualX 1GB Wi-Fi / Bluetooth | V1.0A and newer |
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT | V1.1A and newer |
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth | V1.1A and newer |
Note: Wi2Wi WM828CC6 has been replaced by Azurewave AW-CM276NF on newer Toradex SoMs.
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth | V1.0x |
Wi-fi Adapter | Wi-Fi Standards | Bluetooth version | Adapter's Chipset | Antenna Configuration |
AzureWave AW-CM276NF | 802.11 a/b/g/n/ac | 5.0 compliant with 2.1 | Marvell 88W8997 | Dual-Band 802.11ac 2x2 MU-MIMO |
Wi2Wi WM828CC6 | 802.11 a/b/g/n/ac | 4.2 | Marvell 88W8887 | Dual-Band 802.11ac 1x1 spatial stream |
This article will show RF cables and antennas recommendations for AzureWave AW-CM276NF integrated modules.
The AW-CM276NF implements the Marvell 88W8997 Reference Design, therefore the certificates of the 88W8997 apply to the AW-CM276NF as well. The processes of certifying radio equipment vary from one region to the other. This article concentrates on the certification of the AW-CM276NF to be used in combination with the antennas listed below in the following regions: USA, Canada, European Economic Area (EEA) with Switzerland, India as well as Japan. With regards to end-devices, these certifications are to be understood as pre-certifications. Depending on the country in question, end-devices might still need to undergo final testing and certification of the overall product.
Pre-certification measurements are carried out by an accredited laboratory. Pre-certification of the AW-CM276NF with selected Wi-Fi accessories allows customers to use combinations of those devices in a compliant way and provides additional trust that the pre-certified device combinations will not impede final certification of the respective end-devices.
Pre-certification is not related to the Wi-Fi Alliance and the “WiFi CERTIFIED” logo found on the packaging of many Wi-Fi capable products.
Browse below for antennas that have been successfully tested at least once on Toradex Computer on Modules.
PCB
PCB
PCB
PCB
Browse below for antenna cables that have been successfully tested at least once on Toradex Computer on Modules.
