Windows CE Library - Pulse Width Modulation Library (PWMlib)
Description
This library manages the PWM interfaces.
Current Version
V2.1.2
Application Notes
The PWMLib supports up to 4 PWM signals
The PWM duty cycle can be set as a percentage or, with more precision, in clock units.
Library API
Other Resources
Windows CE Libraries Overview
How to use PWM Library
Revision History
DateRevChange Notes
24/06/2013V2.1.2Added parameter type definition to DeInitPWM()
17/06/2013V2.1.1Updated to work with Apalis T30
