Version: 5.0
Node.js in Linux
Node.js Setup
While Building a Linux Image
Node.js can be added to an OpenEmbedded Linux build for inclusion into the image's rootfs. After establishing the image build configuration, additionally append the following line to the oe-core/build/conf/local.conf file:
IMAGE_INSTALL_append = "nodejs"
You may also include NPM:
IMAGE_INSTALL_append = "nodejs nodejs-npm"
You may find the page TipsAndTricks/NPM from the Yocto Project Wiki useful.
Performance & Suitability
Since Node.js is a server-side interpreter for the Javascript language, it is expected to perform slower than a compiled language such as C/C++. However, because of its event-driven paradigm, it may well suit web I/O intensive tasks, such as implementing a web server.
Still, Node.js can also be viable for tasks that aren't very CPU intensive, which may be a fast development solution since Javascript is a high level programming language.
Node-RED
Torizon
If you want to run Node-RED on Torizon, we show how to run it on:
Linux BSPs
Install Node-RED with the following command:
# npm install -g node-red --unsafe-perm
Start Node-RED:
# node-red
Examples
GPIO - Blinking LED
var fs = require('fs');
var export_path = '/sys/class/gpio/export';
var blink_period = 500; //in milisseconds
var gpio_53 = new NewGpio(53, 'out', 0);
function NewGpio (id, direction, state) {
this.number = id;
this.path = '/sys/class/gpio/gpio' + id + '/';
this.direction = direction;
this.value = state;
function export_pin (pin, callback){
//callback has error as argument, or null if no error
console.log('first');
console.log(pin);
fs.stat(pin.path, function(err, stats) {
console.log('second_not_exp');
console.log(pin);
if (!err) callback(null, pin);//if gpio already exported
else{//if gpio not exported yet
//export it
fs.writeFile(export_path, pin.number, function (err) {
console.log('second_exp');
console.log(pin);
if (err) callback(err, null);
else callback(null, pin);
function configure_pin(pin, callback){
console.log('third');
console.log(pin);
fs.writeFile(pin.path + 'direction', pin.direction, function (err) {
function blink(pin){
console.log('fourth');
console.log(pin);
fs.writeFile(pin.path + 'value', pin.value, function (err) {
if (err) throw err;
pin.value ? pin.value = 0 : pin.value = 1;
//here the code execution starts
export_pin( gpio_53, function (err, pin) {
if (err) throw err;
configure_pin(pin, function (err, pin) {
if (err) throw err;
setInterval(function(){
blink(pin);
}, blink_period);//call blink periodically
