Apalis iMX8 Power Consumption
Overviewโ€‹
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Apalis iMX8.
The Apalis iMX8's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimerโ€‹
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditionsโ€‹
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0067 Apalis iMX8QM 8GB WB IT V1.1Aโ€‹
Resultsโ€‹
Test caseMean Power Consumption [W]Max Power Consumption [W]
Idlling mode without screen and withouth eth3.717.25
Idlling mode without screen and with eth4.267.95
Idlling mode with screen and withouth eth4.3711.49
Idlling mode with screen and with eth4.8711.92
Stress 1 core(s) without screen4.728.43
Stress 2 core(s)5.5012.51
Stress 3 core(s)5.7712.73
Stress 4 core(s)6.0612.95
Stress 5 core(s)7.4114.87
Stress 6 core(s)8.5915.40
iperf3 with CPU Stress and eth and with screen8.7415.10
iperf3 with CPU Stress and 2.4GHz and with screen9.6416.57
iperf3 with CPU Stress and eth and 2.4GHz and with screen9.8816.62
iperf3 with CPU Stress and 5GHz and with screen9.6416.76
iperf3 with CPU Stress and eth and 5GHz and with screen9.8516.57
iperf3 eth and without screen5.468.94
iperf3 5GHz and without screen5.8610.40
iperf3 2.4GHz and without screen5.399.69
glmark2 with all cores stressed11.8817.95
glmark29.1615.12
max stress: all cores stressed, glmark2, iperf3 and ethernet11.3017.92
max stress: all cores stressed, glmark2, iperf3 wifi 2.4GHz and ethernet12.1619.30
max stress: all cores stressed, glmark2, iperf3 wifi 5GHz and ethernet11.8219.19
CPU stress + video play10.1517.38
cpu neon stress script8.0615.42
suspend mode idle--
poweroff state--
0037 Apalis iMX8QM 4GB WB IT V1.1Bโ€‹
Resultsโ€‹
Suspend1.3841.400
Idle4.7285.029
Idle after 20 min4.7384.878
Stress 1 core5.8906.495
Stress 2 core5.4826.259
Stress 3 core6.1667.208
Stress 4 core7.2708.599
Stress 5 core8.3609.757
Stress 6 core8.92211.244
Idle (headless)4.5884.862
Headless & Full stress8.71310.879
iperf3 Ethernet & Full stress9.74511.041
iperf3 Wi-Fi & Full stress11.16712.588
Glmark2 & full stress13.34917.943
HD video & full stress10.77412.402
CPU burn-neon9.75010.847
Max stress: all cores stressed, glmark2b,iperf3 wifi 2.4GHz, and Ethernet13.89618.191
0037 Apalis iMX8QM 4GB WB IT V1.1Eโ€‹
Resultsโ€‹
Suspend mode0.9490.979
Idle5.6896.767
Idle +20min4.6765.056
Stress 15.0665.646
Stress 26.3997.509
Stress 36.6997.835
Stress 47.4719.000
Stress 59.0709.269
Stress 68.38910.898
Headless idle3.7983.914
Headless full stress7.94710.470
Headless Ethernet4.1324.233
Headless iperf full stress8.74310.463
Full stress glmark211.76615.371
Full stress video playing9.91014.263
CPU burn-neon7.5837.904
Max stress11.83215.509
Poweroff0.0007.632
Poweroff +2min0.0000.000
0047 Apalis iMX8QM 4GB IT V1.1Bโ€‹
Resultsโ€‹
Test caseMean Power Consumption [W*]Max Power Consumption [W*]
RTC after shutdown0.053 ยตW-
RTC after power off0.053 ยตW-
Suspend1.351.37
Idle4.294.45
Idle after 20 min4.294.43
stress 1 core5.045.73
Stress 2 core5.285.88
Stress 3 core6.527.2
Stress 4 core6.857.56
Stress 5 core7.098.06
Stress 6 core8.168.97
Idle (headless)4.124.57
Headless & full stress6.847.80
iperf3 Ethernet & full stress8.799.88
Glmark2 & full stress13.8416.92
HD video & full stress9.219.80
CPU burn - neon stress script7.568.37
Max stress: full stress, iperf3 Ethernet and glmark14.1617.1
  • Unless explicitly mentioned
0047 Apalis iMX8QM 4GB IT V1.1Dโ€‹
Resultsโ€‹
Suspend mode0.7760.836
Idle4.4724.684
Idle +20min4.4514.733
Stress 14.7765.555
Stress 26.2817.364
Stress 36.6127.928
Stress 47.3708.937
Stress 58.06910.100
Stress 68.26710.930
Headless idle3.5543.659
Headless full stress7.84210.257
Headless Ethernet3.8853.979
Headless iperf full stress8.71910.276
Full stress glmark210.49114.161
Full stress video playing10.29612.544
CPU burn - neon stress script8.5929.923
Max stress11.19414.593
Poweroff0.0007.776
0048 Apalis iMX8QP 2GB WB V1.1Dโ€‹
Resultsโ€‹
Idling mode without screen and eth3.496.17
idling mode without screen with eth4.056.89
idling mode with screen without eth4.2110.70
Idling mode with screen and eth4.6411.29
Stress 1 core without screen4.486.98
Stress 2 cores5.2511.86
Stress 3 cores5.5112.20
Stress 4 cores6.1212.69
Stress 5 cores7.0913.48
CPU stress with iperf3 eth7.4413.41
CPU stress with iperf3 wifi 2.4GHz8.1614.67
CPU stress with iperf3 wifi 5GHz8.4514.78
CPU stress with iperf3 eth and wifi 2.4 GHz8.3214.92
CPU stress with iperf3 eth and wifi 5 GHz8.5212.50
All cores stressed and glmark25.227.57
Glmark25.438.58
CPU neon stress script5.218.43
Max stress: all cores stressed, glmark2 , iperf3 wifi 2.4GHz and ethernet9.7114.73
Max stress: all cores stressed, glmark2 , iperf3 wifi 5GHz and ethernet7.9012.82
Iperf3 Wifi 2.4GHz no screen9.3914.66
Iperf3 Wifi 5GHz no screen10.1115.91
iperf3 eth no screen10.2316.03
CPU stress & video play8.6514.98
All cores stressed, glmark2, ethernet iperf37.2314.10
Suspend mode idle0.850.88
Poweroff state0.000.02
0048 Apalis iMX8QP 2GB WB V1.1Bโ€‹
Resultsโ€‹
Suspend1.511.51
Idle4.835.23
Idle after 20 min4.835.24
Stress 1 core5.145.59
Stress 2 core5.375.88
Stress 3 core5.616.12
Stress 4 core6.747.21
Stress 5 core7.017.23
Stress 6 coren/an/a
Idle (headless)4.625.07
Headless & full stress6.796.97
iperf3 Ethernet & full stress7.737.91
iperf3 wifi & full stress9.389.16
Glmark2 & full stress10.3212.03
HD video & full stress8.688.95
CPU burn - neon stress script7.777.94
Max stress: full stress, iperf3 Ethernet, iperf3 Wi-Fi and glmark11.1013.40
0049 Apalis iMX8QP 2GB V1.1Dโ€‹
Resultsโ€‹
Idling mode without screen and eth3.365.35
idling mode without screen with eth3.936.23
idling mode with screen without eth4.095.72
Idling mode with screen and eth4.626.04
Stress 1 core without screen4.457.09
Stress 2 cores5.347.56
Stress 3 cores5.637.94
Stress 4 cores6.329.29
Stress 5 cores7.269.71
CPU stress with iperf3 eth7.419.90
All cores stressed and glmark29.6314.78
Glmark27.9412.19
CPU neon stress script7.048.97
iperf3 Ethernet (no display)4.586.45
CPU stress & video play8.5111.40
Max stress: full stress, iperf3 Ethernet, iperf39.5614.68
Suspend mode idle0.560.56
Poweroff state0.000.00
0049 Apalis iMX8QP 2GB V1.1Bโ€‹
Resultsโ€‹
RTC after shutdown0.052 ยตW-
RTC after power off0.049 ยตW-
Suspend1.341.37
Idle4.214.59
Idle after 20 min4.214.57
Stress 1 core4.545.00
Stress 2 core4.775.24
Stress 3 core4.995.45
Stress 4 core6.166.57
Stress 5 core6.456.59
Headless idle4.034.47
Headless & full stress6.226.40
iperf3 Ethernet & full stress7.187.42
Glmark2 & full stress9.8311.45
HD video & full stress8.128.41
CPU burn - neon stress script7.237.44
Max stress: full stress, iperf3 Ethernet and glmark9.8211.47
Additional Resourcesโ€‹
Product Page and Datasheet: Apalis iMX8
Specifications and Design Guides: Carrier Board Design Guides
Thermal Management in Toradex Modules: Thermal Management
How to Suspend Your Module Running Linux: Suspend/Resume (Linux)
