Version: 5.0
Colibri iMX8X Power Consumption
Overview​
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Colibri iMX8X.
The Colibri iMX8X's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer​
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditions​
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0038 Colibri iMX8QXP 2GB WB IT V1.0C​
Software Version: TBD
Results​
Test caseAverage [W]Maximum [W]
Idling mode with screen2.582.71
Stress 1 cores2.772.78
Stress 2 cores2.943.02
Stress 3 cores3.093.17
Stress 4 cores3.243.34
Stress 5 cores (arithmetic core)3.253.34
Headless mode all cores stressed2.642.69
Headless mode, all cores, iperf3 100Mbit/s ETH3.073.21
Headless mode, idling1.961.99
All cores stressed and glmark24.775.35
All cores stressed + HD video on screen4.394.54
CPU neon stress script, no screen3.153.82
All cores stressed, glmark2, ethernet iperf34.855.47
RTC clock (proper shutdown)0.0141na
RTC clock (power cable removing shutdown )0.0139na
0038 Colibri iMX8QXP 2GB WB IT V1.0D​
Software Versions:
  • 5.0.0-devel-202010+build.3
  • TDX Wayland with XWayland 5.1.0-devel-20201014+build.96 (dunfell)
Results​
Test caseMean Power Consumption [W]Max Power Consumption [W]
Idling mode with screen1.982.20
Idling mode with screen for 20 minutes1.982.36
Idling without screen2.002.33
Stress 1 cores2.363.25
Stress 2 cores2.633.39
Stress 3 cores2.903.69
Stress 4 cores3.134.21
All cores stressed without screen3.084.02
CPU stress with iperf3 eth3.494.26
CPU stress with iperf3 wifi 2.4GHz5.516.22
CPU stress with iperf3 eth and wifi 2.4GHz5.756.32
All cores stressed and glmark24.145.09
CPU neon stress script3.183.79
Max stress: all cores stressed, glmark2 ,iperf3 wifi 5GHz and ethernet5.666.69
Max stress: all cores stressed, glmark2 ,iperf3 wifi 2.4GHz and ethernet5.856.95
Iperf3 Wifi 2.4GHz no screen4.114.36
Iperf3 Wifi 5GHz no screen4.194.48
Iperf3 eth no screen2.412.75
All cores stressed, glmark2, ethernet iperf33.994.84
Suspend mode0.420.44
RTC clock (proper shutdown)12.52uW13.38uW
RTC clock (power cable removing shutdown )12.39uW12.90uW
0050 Colibri iMX8QXP 2GB IT V1.0C​
Software Versions:
  • TDX Wayland with XWayland 0.0.0-devel-20200717+build.9 (dunfell) colibri-imx8x ttyLP3Colibri-iMX8X_Verification-Image
  • TDX Wayland with XWayland 4.0.0-devel-20200630+build.134 (zeus) colibri-imx8x ttyLP3Colibri-iMX8X_Verification-Image
  • TDX Wayland with XWayland 4.0.0-devel-20200717+build.155 (zeus) colibri-imx8x ttyLP3Colibri-iMX8X_Verification-Image
Results​
Idle2.0432.099
Idle after 20 min1.9892.051
Stress 1 core2.2452.796
Stress 2 core2.5323.084
Stress 3 core2.7783.404
Stress 4 core2.9903.637
Headless idle1.4661.520
Headless & full stress2.4833.164
Iperf3 eth & full stress3.0863.637
Glmark2 & full stress3.9064.613
HD video & full stress3.7584.149
CPUburn-neo2.8552.924
Max stress: full stress, iperf3 eth and glmark3.9584.653
Suspend0.2020.240
0050 Colibri iMX8QXP 2GB IT V1.0D​
Software Versions:
  • 5.1.0-devel-20201014+build.96 (dunfell)
Results​
Idling mode with screen1.401.51
Idling mode with screen for 20 minutes1.401.49
Idling without screen *1.391.50
Stress 1 cores1.692.29
Stress 2 cores1.982.57
Stress 3 cores2.252.94
Stress 4 cores2.493.21
All cores stressed without screen2.453.19
CPU stress with iperf3 eth2.753.28
All cores stressed and glmark23.364.14
CPU neon stress script2.352.42
Max stress: all cores stressed, glmark2 ,iperf3 ethernet3.314.11
Iperf3 eth no screen1.791.86
Suspend mode0.150.17
RTC clock (proper shutdown)12.21uW12.72uW
RTC clock (power cable removing shutdown )12.06uW12.45uW
0051 Colibri iMX8DX 1GB WB V1.0D​
Results​
Idling mode with screen2.442.80
Idling mode with screen for 20 minutes2.432.92
Idling without screen and DSI adapter1.822.21
Stress 1 cores2.713.32
Stress 2 cores2.963.65
all cores stressed without screen (no dsi adapter)2.323.00
CPU stress with iperf3 eth3.263.69
All cores stressed and iperf3 2.4GHz5.185.70
All cores stressed, iperf3 ethernet and iperf3 2.4GHz5.395.82
All cores stressed and glmark23.824.53
Glmark23.373.89
CPU neon stress script3.023.42
Max stress: all cores stressed, glmark2 ,iperf3 ethernet, wifi 2.4GHz5.776.39
All cores stressed, glmark2 ,iperf3 ethernet3.664.21
Iperf3 wifi 5GHz no screen3.944.26
Iperf3 wifi 2.4GHz no screen3.854.27
Iperf3 with screen2.492.90
Iperf3 eth no screen (no dsi adapter)2.112.59
Suspend mode with dsi adapter0.510.54
Suspend mode (no dsi adapter)0.390.44
RTC clock (proper shutdown)12.71uW13.94uW
RTC clock (power cable removing shutdown )12.38uW12.98uW
0052 Colibri iMX8DX 1GB V1.0D​
Results​
Idling mode with screen1.831.96
Idling mode with screen for 20 minutes1.821.95
Idling without screen and DSI adapter1.221.75
Stress 1 cores2.082.52
Stress 2 cores2.312.71
All cores stressed without screen (no dsi adapter)1.702.21
CPU stress with iperf3 eth2.482.77
All cores stressed and glmark22.933.29
Glmark22.693.07
CPU neon stress script2.262.37
Max stress: all cores stressed, glmark2 ,iperf3 ethernet2.913.25
Iperf3 with screen2.082.30
Iperf3 eth no screen (no dsi adapter)1.501.75
Suspend mode with dsi adapter0.270.30
Suspend mode (no dsi adapter)0.160.17
RTC clock (proper shutdown)12.19uW12.68uW
RTC clock (power cable removing shutdown )12.26uW12.54uW
Additional Resources​
Product Page and Datasheet: Colibri iMX8X
Specifications and Design Guides: Carrier Board Design Guides
Thermal Management in Toradex Modules: Thermal Management
How to Suspend Your Module Running Linux: Suspend/Resume (Linux)
