Version: 5.0
Shock and Vibration Compliance Tests
Shock and vibration tests compliance is an important measure for many industries. Many people are worried about these tests when it comes to modules. However, it isn't a problem for our modules and the module approach in general to comply with many different standards.
The vibration tests were conducted on a shaker fixture plate setup and pictures of the setup are provided in the test reports. While the devices under test were exposed to vibration and shock, software was executed to detect discontinuities in the edge connector or failures on the module and carrier board. The vibration and shock tests have been performed on fifteen different combinations of Toradex carrier boards and Computer on Modules. Proper fastening methods were applied: screws, heatsinks, fasteners or SODIMM fingers.
Hardware Configuration
Computer on ModuleCarrier BoardFastening Method
Apalis iMX6D 1GB ITIxoraScrews
Apalis iMX6Q 1GBIxoraApalis Heatsink
Apalis iMX8QM 4GB WBIxoraScrews
Apalis TK1 2GBIxoraApalis Heatsink
Colibri iMX6DL 512MB ITIrisNo fastening (SODIMM fingers only)
Colibri iMX6DL 512MB ITIrisColibri Fastener
Colibri iMX6ULL 512MB WB ITViola PlusScrews
Colibri iMX7D 512MBViola PlusScrews
Colibri T30 1GB ITIrisColibri Fastener
Colibri T30 1GB ITViola PlusScrews
Tests and Results
This section provides a list of tests executed as well as the full test reports, which contain comprehensive specification, procedures and result information. The test procedures have been performed by a leading independent and internationally accredited testing laboratory company (ISO/IEC 17025), inspection body (ISO/IEC 17020), Quinel AG.
Broad-band Random Vibration
Result: passed for all configuration
  • Standards: EN 60068-2-64:2008
  • Frequency range: 10Hz-2kHz
  • RMS level: 57.9m/s2
  • Duration of exposure: 32h / axis
  • Testing axes: in all 3 main axes
  • Report: U2243-21a-18
Vibration (sinusoidal) - Test 1
  • Standards: EN 60068-2-6:2008
  • Frequency range: 10Hz.......55Hz
  • Vibration amplitude: 0.54mm (constant amplitude/displacement)
  • Peak acceleration (@ 55Hz): 3.2 m/s2
  • Endurance procedure: by sweeping
  • Duration of endurance: 2 hours / axis
  • Sweep rate (exponential): 1 octave per min.
  • Axes of vibration: in all 3 main axes
  • Report: U2243-22a-18
Vibration (sinusoidal) - Test 2
  • Frequency range: 10Hz.......300Hz
  • Vibration amplitude : (10-20)Hz constant amplitude, (20-300)Hz constant acceleration: 39m/s2
  • Endurance procedure: at resonance frequency 206.89 Hz (Colibri) and 231 Hz (Apalis)
  • Duration of endurance: 10 Minutes / resonance frequency
  • Report: U2243-23a-18
Mechanical Shock - Test 1
  • Standards: EN 60068-2-27:2009
  • Pulse shape and tolerances: half sine
  • Number and direction of shocks: 200 shocks in each direction of the 3 mutually perpendicular axes (total 1200 shocks)
  • Severity: peak acceleration and duration of nominal pulse: 150ms-2 (15g) 11ms
  • Pre-conditioning procedure: Temperature stabilised at ambient temperature during 2h
  • Report: U2243-24a-18
Mechanical Shock - Test 2
  • Severity: peak acceleration and duration of nominal pulse: 300ms-2 (30g) 18ms
  • Report: U2243-25a-18
Mechanical Shock - Test 3
  • Severity: peak acceleration and duration of nominal pulse: 500ms-2 (50g) 20ms
  • Report: U2243-26a-18
Mechanical Shock - Test 4
  • Number and direction of shocks: 1000 shocks in each direction of the 3 mutually perpendicular axes (total 6000 shocks)
  • Severity: peak acceleration and duration of nominal pulse: 300ms-2 (30g) 11ms
  • Report: U2243-27a-18
Colibri PXA310 - Legacy Tests
The following tests were successfully passed by using a Colibri PXA310, module, the Colibri Fastener V1.0 and a normal SODIMM connector (Tyco 1473005-1).
Vibration
ISO 16750-3
10-2000Hz @ 58m/s²
EN 60068-2-64:2009
10-2000Hz @ 49m/s²
EN 60068-2-6:2008
2-500Hz @ 20m/s²
Shock
IEC 60068-2-72
40G for 11ms
