Version: 5.0
Supported displays
For a general overview of all the different display interfaces, see our Display Interface page.
The Toradex ARM Computer Modules supports almost every active and passive LCD without any glue logic. You can attach TFT (active) and STN (passive) displays glueless (without any CPLD) to the Colibri display interface.
EDT Unified Interface Display
The Unified TFT Interface form EDT allows you to use several different displays with exactly the same connector on the baseboard. Toradex provides 2 EDT displays in the webshop but there are even more available form 3rd parties. Here the complete list:
SizePart NumberTouchResolution
3.5"ET035080DM6NoQVGA 320*240
3.5"ET035080DH6resistiveQVGA 320*240
5.7"ET057090DMUNoVGA 640*480
5.7"ET057090DHUresistiveVGA 640*480
7.0"ET070080DH6resistiveWVGA 800*480
Please note we have not tested all these displays.
Tested Displays
The following displays have been used by Toradex customers:
RGB and LVDS Displays
SizeResolutionTypeManufacturerComment
3.5"240x320TD035STED4Toppoly
3.5"480x640TD035STEE1Toppoly
6.4"640x480LB064V02-A1Philips
15.4"1024x768G150XG01AUOLVDS converter needed
10.4"800x600G104SN03AUOLVDS converter needed
3.7"480x640LS037V7DW01Sharpwith touch
5.7"320x240AM-320240N1TMCW-00HAmpire
10.4"800x480AM800480E3TMQW-00HAmpire
4.3"640x480AM640480ATMCW00Ampire
7"480x272TFT-GG1N4014DTSW-W-TP-Ev1.1TrulyLED
7"800x480TFT-G800480DTSW-15W-E(7D)v1.2TrulyLED
12.1"800x600LQ121S1DG11Sharp
5.5"320x240nl3224bc35-22-0065NECSunlight Readable
6.5"640x480nl6448bc20-20-0126NECSunlight Readable
10.4"640x480nl6448bc33-64c-0157NECSunlight Readable
7"1280x800HSD070PWW1HannStarLVDS converter needed
10.1"1024x600B101AW03 V.1HannStarLVDS converter needed
10.1"1280x800HSD101PWW1HannStarLVDS converter needed
10.1"1280x800HSD101PWW1-AHannStarLVDS converter needed
8.4"800x600TM084SDHG01TianmaLVDS converter needed
15.6"1366x768B156XW04 V.5AU OptronicsLVDS converter needed
15.6"1920x1080N156HGE-LG1CHIMEI INNOLUXLVDS converter needed
Toradex carrier boards also provide a connector for the Unified TFT Display interface which gives the possibility to test a lot of different displays without the need for an adapter.
For other displays where adaptation is required, we have done some examples as mentioned below: (CAE data is freely available)
LVDS Mitsubishi Displays
There is a selection of Mitsubishi Electric displays that have been tested with a specially designed and manufactured cable compatible with the LVDS 40 pin connector available in most of (Apalis) carrier boards.
After checking with Mitsubishi, we can confirm that, with this cable, the following panel sizes and resolutions are available:
640x480 VGA 6.5"/ 8.4" / 10.4"
800x600 SVGA 8.4" / 10.4" / 12.1"
1024x768 XGA 8.4" / 10.4" / 12.1"
800x480, Wide-VGA, 7.0" / 8.0" / 9.0" 1280x768, Wide-XGA, 7.0" / 9.0" / 10.6" 1280x800, Wide-XGA, 12.1" / 14.1"
However, the customer would have to make the proper device tree changes and add the needed timings settings depending on the chosen display. For this, we greatly recommend informing yourself about Device Tree Customization and about Display Output, Resolution, and Timings (Linux).
You can find more information about the available displays and its characteristics in Mitsubishi's catalog (Under Color TFT-LCD Modules catalog): http://www.mitsubishielectric.com/semiconductors/catalog/index.html
Contact our sales team in you need more information.
Displays with Capacitive Touch
Some of the capacitive touch displays which our customers have tested.
SizeResolutionTypeManufacturerTouch Interface
10"1024x600FA1012LilliputUSB HID
9"1280x800ODROID-VUHARDKERNELUSB HID
7"1280x8007" HDMI Display with black panelChalkboard ElectronicsUSB HID
7"1280x8007" HDMI Display open frameChalkboard ElectronicsUSB HID
10"1366x76810" HDMI DisplayChalkboard ElectronicsUSB HID
14"1366x76814" HDMI DisplayChalkboard ElectronicsUSB HID
15.6"1366x76815.6" HDMI DisplayChalkboard ElectronicsUSB HID
Generic USB HID Driver(WinCE) can be downloaded from here.
SizeResolutionTypeManufacturerTouch InterfaceSoftware Driver & Hardware Adaptation
5"480x272ER-TFT050-2EAST RISINGI2C (GSL1680)Driver adaptation is required, display can be interfaced using Generic RGB Display Adapter Board Example
7"800x480ER-TFT070-4EAST RISINGI2C (FT5206)Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example
4.3"480x272FT800CB-HY43BHAOYU ELECTRONICSSPI (FT800)Driver adaptation is required, display can be interfaced using Generic RGB Display Adapter Board Example
5.0"480x272FT800CB-HY50BHAOYU ELECTRONICSSPI (FT800)Driver adaptation is required, display can be interfaced using Generic RGB Display Adapter Board Example
7.0"800x480HY070CTPHAOYU ELECTRONICSI2C (FT5206)Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example with small change, please refer NOTE1.
10.1"1024x600HY101CTP HAOYU ELECTRONICSI2C (FT5406)Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example with small change, please refer NOTE1.
4.3"480x272NHD-4.3-480272EF-ATXL#-CTPNewhaven DisplayI2C (FT5306)Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example, small change is required to be done, please refer NOTE2.
5.0"800x480NHD-5.0-800480TF-ATXL#-CTPNewhaven DisplayI2C (FT5306)Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example, small change is required to be done, please refer NOTE2.
7.0"800x480NHD-7.0-800480EF-ATXL#-CTPNewhaven DisplayI2C (FT5406)Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example, small change is required to be done, please refer NOTE2.
7.0"800x480NHD-7.0-800480EF-ATXV#-CTP (EOL)Newhaven DisplayI2C (FT5406)Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example, small change is required to be done, please refer NOTE2.
NOTE1: LED driver side, disconnect Pin 1, 2 of LCD from led driver circuit and give 5V input as led driver is integrated with the LCD and connect PWM signal for backlight dimming control to Pin 35 of LCD.
NOTE2: Remove resistors(R98, R99, R100, R101) on Pin 37, 38, 39, 40 and using jumper wire connect these to I2C_SCL_B, I2C_SDA_B, TOUCH_INT_B and TOUCH_RESET_B signals of X8.
_NOTE3: In the above displays, we have tested touch on WinCE only but it should be possible to run it on Linux as well with a little bit of adaptation.
Display Manufacturers
Some possible display suppliers:
Please contact us at support@toradex.com for any feedback or further support.
