Wi-Fi on Toradex Computer on Modules
Toradex offers a variety of System on Modules (SoMs) with integrated Wi-Fi. You can also integrate a 3rd Party Wi-Fi module to our board. Please, select the option that fits your preference to see the related articles we currently have in our Knowledge Base:
- My project will use a Toradex SoM with integrated Wi-Fi
- I want to integrate Toradex SoM with 3rd party Wi-Fi modules
Working with Toradex Modules with Integrated Wi-Fi/Bluetooth
First Steps with Linux
Advanced Linux Setup
- Toradex’s Linux Images - How to setup the Wi-Fi interface for Access Point Mode
- Operating Toradex Wi-Fi/BT Capable Modules Using Single Antenna Configuration
- Step-by-Step on GitHub - How to add NXP drivers for wifi/bluetooth on a Yocto Build
Hardware and Certification
- Azurewave AW-CM276NF Wi-Fi & Bluetooth module
- Wi-Fi certification on recommended Wi-Fi cables/antennas for Toradex modules
- Certification documents for Azurewave AW-CM276NF Wi-Fi / Bluetooth module
- u-blox MAYA-W160 Wi-Fi & Bluetooth module
- Certification documents for u-blox MAYA-W160 Wi-Fi & Bluetooth module
- u-blox MAYA-W260 Wi-Fi & Bluetooth module
- Certification documents for u-blox MAYA-W260 Wi-Fi & Bluetooth module
WinCE
Toradex SoMs featuring the u-blox MAYA-W160-00B Wi-Fi / Bluetooth module:
| System on Module | Product Number | Version |
| Verdin AM62 Quad 2GB Wi-Fi / Bluetooth | 0076 | V1.1A and newer |
| Verdin AM62 Dual 1GB Wi-Fi / Bluetooth | 0075 | V1.1A and newer |
| Verdin AM62 Solo 512MB Wi-Fi / Bluetooth | 0072 | V1.1A and newer |
Toradex SoMs featuring the u-blox MAYA-W260-00B Wi-Fi / Bluetooth module:
| SMARC iMX95 Hexa 8GB Wi-Fi / Bluetooth IT | 0096 | V1.0A |
| Verdin iMX95 Hexa 8GB WB IT Wi-Fi / Bluetooth IT | 0089 | V1.0A |
| Verdin AM62P Quad 2GB WB IT Wi-Fi / Bluetooth IT | 0099 | V1.0A |
| Apalis iMX8 QuadMax 4GB Wi-Fi / Bluetooth IT | 0037 | V1.0A and newer |
| Apalis iMX8 QuadPlus 2GB Wi-Fi / Bluetooth | 0048 | V1.0A and newer |
| Colibri iMX8X QuadXPlus 2GB Wi-Fi / Bluetooth IT | 0038 | V1.0A and newer |
| Colibri iMX8X DualX 1GB Wi-Fi / Bluetooth | 0051 | V1.0A and newer |
| Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT | 0040 | V1.1A and newer |
| Colibri iMX6ULL 512MB Wi-Fi / Bluetooth | 0045 | V1.1A and newer |
| Verdin iMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT | 0055 | V1.0B and newer |
| Verdin iMX8M Mini DualLite 1GB Wi-Fi / Bluetooth IT | 0060 | V1.1A and newer |
| Verdin iMX8M Plus Quad 2GB Wi-Fi / Bluetooth IT | 0064 | V1.1A and newer |
| Verdin iMX8M Plus Quad 4GB Wi-Fi / Bluetooth IT | 0058 | V1.0B and newer |
| Verdin iMX8M Plus Quad 8GB Wi-Fi / Bluetooth IT | 0070 | V1.1A and newer |
Wi2Wi WM828CC6 has been replaced by Azurewave AW-CM276NF on newer Toradex SoMs.
| System on Module | Version |
| Colibri iMX6ULL 512MB Wi-Fi / Bluetooth | V1.0x |
| Wi-fi Adapter | Wi-Fi Standards | Bluetooth version | Adapter's Chipset | Antenna Configuration |
| AzureWave AW-CM276NF | 802.11 a/b/g/n/ac | 5.3 | NXP 88W8997 | 2.4/5 GHz Dual-band 2x2 Wi-Fi 5 (802.11ac) |
| Wi2Wi WM828CC6 | 802.11 a/b/g/n/ac | 4.2 | NXP 88W8887 | 2.4/5 GHz Dual-band 1x1 Wi-Fi 5 (802.11ac) |
| u-blox MAYA-W160-00B | 802.11 a/b/g/n | 5.2 | NXP IW416 | 2.4/5 GHz Dual Band 1x1 Wi-Fi 4 (802.11n) |
| u-blox MAYA-W260-00B | 802.11 a/b/g/n/ac/ax | 5.4 | NXP IW416 | 2.4/5 GHz Dual Band 1x1 Wi-Fi 6 (802.11ax) |
Working with external 3rd Party Wi-Fi Modules
Linux BSP Integration
- Setting up Kernel Support for 3rd Party Wi-Fi Adapters in Toradex’s Linux Images
- Kernel Driver Backports Integration
WinCE
Wi-Fi Database
Browse the Peripheral Database for devices that have been successfully tested at least once on Toradex Computer on Modules.
