Version: 5.0
I2C (Linux)
The Apalis standard provides 3 I2C busses on the MXM pins 201/203, 205/207 and 209/211.
The Colibri standard provides one I2C bus on the SODIMM pins 194/196.
Colibri iMX6, T20 and T30 provide an Extension Connector with an additional I2C on its pins 15/16 usually used for the display DDC channel.
Colibri iMX8X, has two FFC extension connectors with dedicated I2C buses, also available as alternative pin functions in the SODIMM. Pins 15/16 of X2 have a dedicated I2C for the first LVDS/MIPI-DSI. Pins 13/14 of X3 have a dedicated I2C for the second LVDS/MIPI-DSI.
The Verdin standard provides 3 I2C buses on compatible pins (always available on all Verdin modules) + 1 I2C bus on reserved pins (if available on the SoM, it will always be on specific pins):
  • On compatible pins: I2C for generic usage on pins 12/14; I2C for MIPI DSI on pins 53/55; I2C for MIPI CSI-2 on pins 93/95.
  • On reserved pins: I2C for HDMI DDC on pins 57/59.
On top of that most modules use an I2C bus for on-module components like the audio codec, PMIC or touch controller.
Additional I2Cs​
Depending on the module type additional I2C buses might be available as alternate functions of other pins given the kernel gets configured accordingly in the device tree or the platform data. Read the Computer on Module datasheet carefully and check the Pinout Designer Tool for more information about extra I2C and the impact on the default pinout of the module.
Bus Assignment​
The tables below display the I2C enumeration for the Embedded Linux BSP unchanged. If you decide to enable extra I2C controllers or disable existing ones, the index numbers may change. In such a case, the most reliable means to get the correct I2C index is from the controller address, which is a hardware feature and does not change. Check the sub-section Get the Linux Index from the Controller Address below for reference.
I2C busses should be accessed via i2cdev device nodes named with the module family and matching the signal name used in the module's datasheet.
tip
On all the families of modules, the SoM's interface numbering is different from the SoC. From the BSP 5 onwards, you can access the interfaces following the SoM's interface names, which enables software compatibility between members of the same family.
Apalis​
The Apalis module standard features these I2C interfaces:
SoM InterfacePins on Apalis StandardDevice nodes namesRecommended usage
I2C1MXM_209/211/dev/apalis-i2c1General Purpose
I2C2MXM_205/207/dev/apalis-i2c2Display Data Channel (DDC)
I2C3MXM_201/203/dev/apalis-i2c3Camera Interface
To obtain the device nodes names for the Apalis module family:
# ls -l /dev/apalis-i2c*
It will display the available Apalis pin-compatible I2Cs and display the corresponding names used by the BSP. Those corresponding names are important because the Linux kernel logs will print the real device names (e.g. /dev/i2c-4), not the Apalis symlinks (e.g. /dev/apalis-i2c1).
For non-standard interfaces, consult the specific SoM datasheet.
Colibri​
The Colibri module standard features only one generic I2C interface:
SoM InterfacePins on Colibri StandardDevice nodes namesRecommended usage
I2C1SODIMM_194/196/dev/colibri-i2c1General Purpose
Some of the members of the Colibri family may feature an additional I2C interface for DDC.
To obtain the device nodes names for the Colibri module family:
# ls -l /dev/colibri-i2c*
It will display the available Colibri pin-compatible I2Cs and display the corresponding names used by the BSP. Those corresponding names are important because the Linux kernel logs will print the real device names (e.g. /dev/i2c-4), not the Colibri symlinks (e.g. /dev/colibri-i2c1).
Verdin​
The Verdin module standard features only one generic I2C interface:
SoM InterfacePins on Verdin StandardDevice nodes namesRecommended usage
I2C1SODIMM_12/14/dev/verdin-i2c1General Purpose
Some modules may feature additional interfaces reserved for the DSI display, HDMI output, and the CSI camera.
To obtain the device nodes names for the Verdin module family:
# ls -l /dev/verdin-i2c*
It will display the available Verdin pin-compatible I2Cs and display the corresponding names used by the BSP. Those corresponding names are important because the Linux kernel logs will print the real device names (e.g. /dev/i2c-4), not the Verdin symlinks (e.g. /dev/verdin-i2c1).
Get the Linux Index from the Controller Address​
The default values from the tables above may change if you enable extra I2Cs, for example, to use a MIPI-CSI2 camera, an LVDS or MIPI-DSI display - or for any other reason you enable or disable I2Cs.
You can make sure that you are using the correct I2C by using the controller address to get the Linux index. The controller address does not change.
Example - Colibri iMX8X​
See the addresses for Colibri iMX8X in the table below:
SODIMM_194/196
(Generic)
On-Module
5a810000.i2c5a800000.i2c
You can use any of i2cdetect -l or ls -la /sys/class/i2c-dev to get the index once you know the address.
Examples below are provided for the Embedded Linux BSP with only 2 I2Cs enabled: the one from the Colibri standard and the on-module.
Using i2cdetect -l:
# i2cdetect -l
i2c-17 i2c 5a810000.i2c I2C adapter
i2c-16 i2c 5a800000.i2c I2C adapter
Using ls -la /sys/class/i2c-dev:
# ls -la /sys/class/i2c-dev
drwxr-xr-x 2 root root 0 Jan 13 15:20 .
drwxr-xr-x 68 root root 0 Jan 13 15:20 ..
lrwxrwxrwx 1 root root 0 Jan 13 15:20 i2c-16 -> ../../devices/platform/5a800000.i2c/i2c-16/i2c-dev/i2c-16
lrwxrwxrwx 1 root root 0 Jan 13 15:20 i2c-17 -> ../../devices/platform/5a810000.i2c/i2c-17/i2c-dev/i2c-17
I2C Tools​
Most I2C devices are handled by kernel drivers. The device tree or platform data binds the I2C bus to such drivers. From userspace one accesses them then through the relevant subsystem rather than having to do low-level I2C access. E.g. for an RTC one would use /dev/rtcX or even a userspace program like hwclock.
I2C Tools Integration Into Reference Images for Yocto Project​
The Yocto Project/OpenEmbedded i2c-tools is recommended for adding the I2C Tools into your custom image. It is included in the Toradex Reference Images for Yocto Project as follows:
Provided on packagegroup-tdx-cli.bb, through the package packagegroup-devel-tdx-cli.
Included in the Reference Multimedia Image, but not included in the Reference Minimal Image.
The I2C Tools package provides tools for low-level access to I2C devices.
How to Use I2C Tools​
As follows a few sample use cases:
Check the configured I2C busses
root@colibri-t20:~# ls -l /dev/i2c-*
crw------- 1 root root 89, 0 Jan 1 2000 /dev/i2c-0
crw------- 1 root root 89, 1 Jan 1 2000 /dev/i2c-1
crw------- 1 root root 89, 4 Jan 1 2000 /dev/i2c-4
Detect devices on i2c-0
root@colibri-t20:~# i2cdetect -y -r 0
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
UU denotes a device which is used by a kernel driver and thus is usually not touched. Depending on the I2C device it may not get discovered by i2cdetect.
Dump register content of an I2C device
root@colibri-t20:~# i2cdump -r 0-0xf 0 0x20 b
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-0, address 0x20, mode byte
Probe range limited to 0x00-0x0f.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 10 40 00 00 10 80 00 80 88 02 00 23 00 00 03 18 ?@..??.???.#..??
Read a single byte, change its value and verify it with an additional read
root@colibri-t20:~# i2cget 0 0x20 4 b
I will read from device file /dev/i2c-0, chip address 0x20, data address
0x04, using read byte data.
Continue? [Y/n] y
0x10
root@colibri-t20:~# i2cset 0 0x20 4 0x18 b
I will write to device file /dev/i2c-0, chip address 0x20, data address
0x04, data 0x18, mode byte.
Continue? [Y/n] y
Continue? [Y/n]
0x18
