Manufacture: | e-con Systems |
Device Type: | Camera |
Interface: | MIPI CSI-2 |
Operating Temperature: | -30°C to 70°C |
Features: | Focus: Fixed Focus Housing: Bare Board Integrated ISP Lens Mount: S-mount Pixels: 5MP Resolution: 2592 × 1944 Sensor Type: CMOS Sensor: AR0521 |
Hardware / Firmware Version | Module (Version) | Board (Version) | OS (OS / BSP Version) | Note | Test Date |
No results found. |
e-con Systems provides a user manual with comprehensive instructions to make the camera work. In this article, we summarize some of those steps for a quick reference, but you should not skip reading the e-con Systems documentation:
The camera module e-CAM55_CUMI0521_MOD from e-con Systems is sold together with an adapter board and cables as the evaluation kit e-CAM50_CUiMX8.
The kit works out-of-the-box with the following computer on modules:
Toradex and e-con Systems are working to also support the following computer on modules:
Any Toradex carrier board that supports the MIPI CSI-2 interface connects to the camera kit out-of-the-box, hardware-wise:
Note: support was added from the BSP version 5.0.0+devel-202008 onwards, a.k.a. August monthly build.
The camera works both with the Toradex BSP Layers and Reference Images for Yocto Project and Torizon. The camera device driver and device tree are integrated into the Toradex BSP Layers and the binaries are deployed to the reference images. Using them is easy:
Install the Toradex Reference Multimedia pre-built image using the Toradex Easy Installer.
Stop U_Boot and set the correct device tree:
> setenv fdtfile fsl-imx8qm-apalis-v1.1-eval-ar0521.dtb
> saveenv
> reset
On the Linux terminal, run a Gstreamer pipeline:
$ gst-launch-1.0 v4l2src device='/dev/video4' ! video/x-raw,format=RGB16,width=1920,height=1080,framerate=30/1 ! waylandsink -v
For troubleshooting, you can verify that the camera driver is starting correctly:
$ dmesg | grep ar0
[ 7.045228] ar0521 5-0042: Current Firmware Version - (1150CU96RKV1901110d381894XXXXXXX)
[ 11.646248] mx8-img-md: Registered sensor subdevice: ar0521 5-0042 (1)
[ 11.750804] mx8-img-md: created link [ar0521 5-0042] => [mxc-mipi-csi2.1]
e-con Systems and Toradex are working on a Partner Demo Container for a great out-of-the-box experience. Subscribe to our developer website updates or contact our sales team to stay up-to-date.
Please register yourself on e-con Systems Official Webiste in order to have access for all the device documents.
