USB Bluetooth Adapter - DeLOCK
Manufacture: DeLOCK
Device Type: Bluetooth Adapter
Interface: USB
Features: BT 4.0
Device Page
Compatible Setups
No results found.
If your setup is not listed above, the following table provides some generic setups that are expected to work with this device:
- / -Any Module (Any Version)Any Carrier Board (Any Version)Linux (Any)-
- / -Any Module (Any Version)Any Carrier Board (Any Version)WEC (Any)-
