WiBear11n-DF1 - Lesswire
Manufacture: Lesswire
Device Type: Bluetooth Adapter
Interface: SDIO (SMT Module)
Features: BT 2.1
BT 3.0
EN 300 328
Includes Wi-Fi
Device Page
Compatible Setups
No results found.
If your setup is not listed above, the following table provides some generic setups that are expected to work with this device:
- / -Any Module (Any Version)Any Carrier Board (Any Version)Yocto (Linux) (Any) -
- / -Any Module (Any Version)Any Carrier Board (Any Version)WEC (Any) -
WEC Driver
Available information here.
Note: Ensure that BT/WLAN muti-functions driver registry key is set to 1 to make WLAN/BT to work. If it is set to 0, then only the WLAN will work.
