Search by Tags
Verdin iMX8M Mini
Verdin iMX8M Mini
  • NXP i.MX 8M Mini Cortex-A53 dual or quad core
  • RAM: up to 2GB, Flash: up to 16GB eMMC
  • Temperature range: -40° to 85° C and 0° to 70° C
Verdin iMX8M Mini is a member of the Verdin Family. You will find all technical details such as features, datasheets, software, etc. here.
Recommendation for a first-time order
For starting for the first time with your Verdin iMX8M Mini you will need a suitable Verdin carrier board as well as some adapters and cables for connecting your desired interfaces.
Toradex recommends to order one of the following carrier boards for your first-time order:
Where do I buy this product?
You can buy the Verdin iMX8M Mini module, Dahlia Carrier Board and Verdin Development Board from the Toradex webshop.
Getting started
The Verdin iMX8M Mini comes with Toradex Easy Installer pre-installed. Once you power-on the board, it will display a list of available images to be installed. Check out how to get started with the Toradex Easy Installer:
For quickstart step-by-step instructions about how to start using Torizon, please have a look at our step-by-step Getting-Started Guide:
Warning: the step-by-step Getting Started guide is not yet available for Verdin.
For detailed instructions about how to start developing your software for this Computer on Module, check out our software page. The following Linux-based offerings are currently supported:
The following Linux-based offerings will be supported soon:
Additional information
For information on how to re-flash an operating system or image on the computer on module please check the Toradex Easy Installer article:
We have quick video tutorials:
For developing software on the platform, please browse through the list of knowledge-base articles provided in the link below:
Having trouble?
Please contact our technical support. Various option of technical support are mentioned below:
Check the hardware features on the product page in toradex.com:
Get details including free downloads of images and BSPs for operating systems supported by Verdin iMX8M Mini.
In-house development and support
Verdin iMX8M Mini 3D Mechanical Models
The Verdin iMX8M Mini 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the generic Verdin mechanical model with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Verdin modules as well as future releases.
This is a SolidWorks CAD model. You can download the free eDrawings model viewer from SolidWorks here.
This is a generic STEP model that can be opened and modified in any 3D CAD.
This is a generic 3D pdf model that can be opened in Adobe Reader.
Off-the-shelf Carrier Boards
Custom Carrier Board Design
Find free reference designs, schematics, 3D designs and tools to build your carrier board easily in the link below:
Verdin iMX8M Mini DualLite 1GB
Product # Product Description Changes from Previous Version Release Date PCN Document
00571100
Verdin iMX8M Mini DualLite 1GB V1.1A
Initial Release
Q4 2020
No PCN
Verdin iMX8M Mini DualLite 1GB Wi-Fi / Bluetooth IT
00601100
Verdin iMX8M Mini DualLite 1GB Wi-Fi / Bluetooth IT V1.1A
Initial Release
Q4 2020
No PCN
Verdin iMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT
00551001
Verdin IMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT V1.0B
Initial Release
Q1 2020
Sample Product, No PCN
Verdin iMX8M Mini Quad 2GB IT
00591100
Verdin IMX8M Mini Quad 2GB IT V1.1A
Initial Release
Q4 2020
No PCN
SoC Errata
Errata document
Errata/Known issues
