Search by Tags
Toradex BSP Layers and Reference Images for Yocto Project
Introduction
The BSP Layers and Reference Images for Yocto Project are the base for Embedded Linux on Toradex SoMs. They can be used as the starting point for your own customization and are also the foundation of Torizon, our ready-to-use Linux DevOps platform.
  • Logo Linux
  • Logo Linux
Resources
Browse for BSP Layers and Reference Images for Yocto Project resources from the tabs below.
Requirements
Hardware
To assemble the hardware for the first time, you can follow the first lesson from our Quickstart Guide. The hardware assembly is OS agnostic, therefore you can follow it even if the guide is not available for the Reference Images for Yocto Project.
OS Installation
A Reference Image for Yocto Project is installed via the Toradex Easy Installer that comes pre-installed in Toradex SoMs from the factory. Install the Toradex Embedded Linux Reference Multimedia Image:
  • Install Toradex Embedded Linux Reference Multimedia Image
Reference Images
The Reference Minimal Image is a good starting point for customization from the bottom up, that is, for adding features on top of it. It is not friendly for evaluation.
The Reference Multimedia Image is a good starting point for customization from the top down, that is, for removing features and only keeping the ones you need. It is also nice for out-of-the-box evaluation of hardware features and system performance. We recommend that you install it for the first time.
Upstream or Downstream?
You may be presented with two versions of the same Reference Image, with and without the (UPSTREAM). It is only available to some SoMs.
The upstream variant is based on the mainline kernel, usually an LTS version.
The downstream version is based on the kernel provided by the SoC silicon vendor.
For a first-time evaluation, you can install either.
Access to Command-line
Upon booting one can login on the serial console (debug UART) or from the network via SSH using the following user and password:
  • User: root
  • Password: (no password is set)
Additional Resources
Move on to the BSP Layers and Reference Images Documentation tab for a comprehensive list of resources.
An overview of relevant articles is presented in this tab. You can scroll through contents or click on your topic of interest below:
We use icons to help you identify the content in an article:
Command Line Conceptual Starting Point
First Steps
Article Brief Description
Toradex Easy Installer Install a pre-built Reference Image for evaluation of the hardware and its features
Reference Images for Yocto Project Software Downloads If your board does not have access to the internet, you can install pre-built images offline
Basic Linux Commands If you are new to Linux, learn some basic Linux commands to help you get started
Configuring Serial Port Debug Console (Linux/U-Boot) Access the Linux console through the debug UART
Serial Terminal Emulator Choose a terminal emulator of choice, in case you don't have one
SSH Access the Linux console (terminal) through the network
Scan your local network to find the board IP and MAC address How to scan you local network and find your board's IP, useful if you don't have access to the debug UART
Essentials
Toradex Embedded Linux Offerings A non-technical overview of our Embedded Linux offerings
BSP Layers and Reference Images for Yocto Project A non-technical overview of our BSP Layers and Reference Images
BSP Layers and Reference Images for Yocto Project Software An introduction to our BSP Layers and Reference Images for Yocto Project, the most essential read for both newcomers and seasoned developers
Products Datasheets, design resources, revision history and more. You must go through the datasheet for your computer on module and carrier board
Long Term Availability Understand about long term availability from a hardware standpoint
Toradex Embedded Linux Support Strategy Learn about our release types, software alerts and versioning scheme
BSP Layers and Reference Images for Yocto Project Issue Tracker Browse our backlog of feature requests and known issues, learn what is added to each release and subscribe for updates
Embedded Linux Release Matrix Check out our active releases and the version of remarkable components as the Linux Kernel and U-Boot
BSP Source Code, Build Instructions and OS Customization
Yocto Project An overview of the Yocto Project and OpenEmbedded in the context of Toradex BSPs
Build a Reference Image with Yocto Project/OpenEmbedded This is the base for you to create your own custom Embedded Linux image
Custom meta layers, recipes and images in Yocto Project (hello-world examples) Basic tasks for customizing your image, such as adding your application or customizing the kernel
Linux SDKs For developing applications with a compiled language as C or C++, you need an SDK with a cross-compilation toolchain and root filesystem
Build U-Boot and Linux Kernel from Source Code Customizing U-Boot and the Linux Kernel outside the Yocto Project/OpenEmbedded can be handy, speed-up your development
Kernel Driver Backports Integration Some BSP versions include backports. Learn how to compile them outside the Yocto Project/OpenEmbedded
Build Custom i.MX 8/8X System Controller Firmware (SCFW) On very specific scenarios, you may need to customize NXP's SCFW. Learn how to build it
Device Tree Customization When creating a custom carrier board or changing pin functionality, you will likely have to customize a device tree
Pin Multiplexing - Changing Pin Functionalities in the Linux Device Tree This is a common topic when doing device tree customization
Device Tree Overlays (Linux) Customize a device tree without modifying it, by writing overlays. Toradex pre-compiled overlays allow you to easily evaluate our accessories and add-ons
Device Tree Customization Examples Collection of examples tied to specific BSP releases and hardware versions
Maintaining Open Source License Compliance Useful methods for complying with open-source licensing when using the Yocto Project/OpenEmbedded
How to Autorun Application at the Start up in Linux On most embedded systems, applications must start automatically when the system boots
Production Programming for Linux Learn how to install your custom Embedded Linux image to many SoMs
How to Erase the eMMC Flash Memory Learn how to erase the eMMC, returning to a known state
Application Development
How to setup environment for Embedded Linux application development Set up the environment between your board and your development PC
How to setup Networking for Embedded Linux Application Development Learn how to configure DHCP, TFTP and NFS servers on your development PC
Boot from a TFTP/NFS Server Booting from the network can be useful during development, so you can update system components on your development PC or server, instead of the board
Boot From an SD Card / USB Stick / SATA drive Alternative to booting from the network, booting from external media may also be useful on development scenarios
Over-The-Air Update Solutions Remote updates may be useful during development and are suitable for production. You may consider it over network or external media boot
Hello World application on Embedded Linux How to cross-compile and debug a C or C++ application
Enable and Analyse Core Dumps in Linux An interesting technique for debugging applications when GDB cannot be used
Python in Linux How to install Python with the Yocto Project/OpenEmbedded, write your own recipes and more
Node.js in Linux How to install Node.js and NPM with the Yocto Project/OpenEmbedded and more
Java Virtual Machine How to install a JVM with the Yocto Project/OpenEmbedded
Web Browser on Toradex Computer on Modules How to install a web browser with the Yocto Project/OpenEmbedded, allowing you to run web-based apps on a local display in kiosk mode
Cross compiling Pascal on Lazarus IDE How to cross-compile a Pascal application using the Lazarus IDE and the Free Pascal Compiler (FPC)
Web Server (Linux) How to install a web server with the Yocto Project/OpenEmbedded, allowing you to serve web-based apps to other services on the board, or over the network
Partner Demo Images
Partner Demo Image Summary Overview
Built with Qt Qt Company Qt for Device Creation Light-weight, Qt-optimized, full software stack for embedded Linux systems
Kynetics Android Kynetics Kynetics Android Android port to Toradex hardware by Kynetics
Acontis Technologies Acontis Technologies acontis EC-Master EtherCAT Stack EtherCAT System implementation by Acontis Technologies
BlackBerry QNX BlackBerry QNX QNX Neutrino Real-time Operating System QNX Neutrino RTOS port to Toradex hardware
Direct Insight QNX Direct Insight Direct Insight - QNX Neutrino Real-time Operating System Direct Insight - QNX Neutrino RTOS port to Toradex hardware
AWS Pasta Demo Amazon Web Services AWS AI at the Edge Pasta Detection End-to-end demonstration of pasta detection using deep learning and connected to the AWS cloud
MVTec Embedded vision MVTec Software GmbH MVTec Embedded Vision HPeek Demo The essence of MVTec HALCON's key features and performance, ease of use in Machine Vision
Mender & Toradex Mender.io Mender Easy Installer Secure and robust Over The Air update manager solution for connected embedded Linux devices
DiSTI GL Studio DiSTI Corporation DiSTI GL Studio DiSTI's technology of GL Studio showcased in a UI with the look and feel of automotive design
TES 3D Surround View TES Eletronic Solutions TES 3D Surround View 3D representation of a vehicle driver assistance system based on the input of cameras, GPU optimized
ITTIA DB SQL for Device Data Management Demo ITTIA ITTIA DB SQL for Device Data Management Interactive relational database utilities and management system for intelligent embedded systems
Displays
First Steps with Capacitive Touch Display 10.1 Inch LVDS How to assemble the hardware and make the display work with Linux
First Steps with Capacitive Touch Display 7" Parallel How to assemble the hardware and make the display work with Linux
First Steps with Resistive Touch Display 7" Parallel How to assemble the hardware and make the display work with Linux
Display Output, Resolution and Timings (Linux) Comprehensive source of information on how to configure video outputs, display resolution and timings
Resistive Touch Screen (Linux) Overview information on resistive touch screen implementation on Toradex SoMs
Touch Screen Calibration (Linux) How to calibrate a touch screen, particularly useful for resistive touch panels
Framebuffer (Linux) Tips on how to disable the console on a screen and how to write directly to the framebuffer using Cairo
Display drive strength configuration Advice on how to configure the display driver strenght to reduce EMC emission
Graphical User Interface (GUI)
Getting Started with Qt An overview page about Qt on Toradex
Qt for Device Creation An overview of Qt for Device Creation, a commercial offering for embedded systems
How to set up Qt Creator to cross compile for embedded Linux Build an image and SDK with the Yocto Project/OpenEmbedded, and setup Qt Creator for application development
TotalCross How to add the TotalCross framework with the Yocto Project/OpenEmbedded
Crank Storyboard How to get started with Crank Storyboard on Toradex SoMs
2D/3D Graphics Acceleration (GPU) Compare OpenGL and OpenGL ES performance, and learn how to run some samples
Hardware Access
ADC (Linux) How to use analog inputs, also known as analog to digital converters (ADC)
Backlight (Linux) How to control display backlight power and brightness
CAN (Linux) How to use the Controller Area Network, widely known as CAN bus
EtherCAT How to get started with EtherCAT on Toradex SoMs
GPIO (Linux) How to use GPIO as a toggle or input device, a power-off button, an LED driver, a pulse-per-second (PPS) signal and more
How to Use GPIO on TorizonCore How to use libgpiod, the kernel interface that superseded sysfs GPIO
GPIO Alphanumeric to GPIO Numeric Assignment Lookup the Linux pin number from the SoC vendor pin name
Real-Time Clock (Linux) How to manually set the date and time, or use the alarm feature to wake up from suspend
I2C (Linux) How to use the I2C bus from the Linux userspace
PWM (Linux) How to use the PWM
SATA (Linux) Useful information about SATA
SD/MMC Card (Linux) Useful information about SD Card and MMC on Linux
SPI (Linux) How to use the SPI
UART (Linux) Hwo to configure and use the UART, also known as serial interface. Also, contains information about RS-485
USB Host Mode (Linux) Information on the USB when used as host
USB Device Mode (Linux) Information on how to use the USB as a gadget, mass storage, RNDIS and more
External Bus Memory (Linux) How to use the External Memory Bus, typically used to connect high speed devices like FPGAs, DSPs and others.
Linux Features
CPU (Linux) How to configure some CPU parameters, for example how to power-off CPU cores
CPU Frequency and DVFS (Linux) How to configure the CPU frequency and governor, learn about the Dynamic Voltage and Frequency Scaling (DVFS)
Suspend/Resume (Linux) Put the system on a sleep state to save energy
Linux - Booting learn about different boot scenarios, such as booting from the internal flash, external media or the network
Distro Boot Learn about Distro Boot and the boot process on our BSP
Using DIP Switches to change the boot process How to use GPIO on U-Boot to set configuration based on the state of DIP switches
eMMC (Linux) Learn more about eMMC in the context of Linux. Several of our SoMs are equipped with eMMC flash memory as the primary storage device
Flash Layout (Linux) How the interal flash - either eMMC or raw NAND - is partitioned
Updating NAND-based modules from userspace How to update the U-Boot, Kernel and device tree from Linux on raw NAND-based SoMs
TRIM and ubihealthd Support (Linux) Learn how to use the TRIM and ubihealthd commands to keep your flash memory healthy
Contiguous Memory Allocator - CMA (Linux) Learn how to check and change the CMA value in our BSP
MAC Address How to force a custom MAC Address. Learn the relationship between the MAC Address and the Toradex unique Serial Number
Serial Number Learn about the unique Toradex Serial Number
SoC Unique ID (Linux) SoCs have a unique ID, learn how to read it
Real-Time Linux An overview of real-time in the context of Linux, mostly focused on the PREEMPT_RT patch approach
Splash Screen on Toradex Computer on Modules Overview page with an index to different splash screen methods on different stages of the boot process
Splash Screen on U-Boot Display a splash screen as early as possible, on U-Boot
Splash Screen on the Linux Kernel Display a splash screen early on the Kernel boot process
Temperature Sensor (Linux) Read the internal temperature of the SoC
U-Boot fw-utils Read and write to U-Boot environment variables from the Linux userspace
Watchdog (Linux) How to enable the hardware watchdog available on the SoC
Networking
Ethernet/Network (Linux) Learn about the network manager used in our Reference Images, how to configure static IP and more
Wi-Fi on Toradex Computer on Modules An overview and entry point to Wi-Fi resources on Toradex SoMs
Toradex’s Linux Images - How to connect to a Wi-Fi network How to connect to a Wi-Fi network and more
Using Wi-Fi or Bluetooth on Single Antenna Configuration How to use Wi-Fi or Bluetooth with a single antenna
How to Setup Wi-Fi Access Point Mode (Linux) How to configure a Wi-Fi adapter as access point
VPN on Toradex Computer on Modules Overview of VPN usage
OpenVPN (Linux) How to install OpenVPN with the Yocto Project/OpenEmbedded
SMB support How to install Samba with the Yocto Project/OpenEmbedded
Connectivity
Bluetooth on Toradex Computer on Modules Overview of Bluetooth on Toradex SoMs
Bluetooth (Linux) How to use Bluetooth
Cellular Modem on Toradex Computer on Modules Overview of cellular modems (GSM, LTE and others) on Toradex SoMs
Modem Support How to use ModemManager to configure a cellular connection
Multimedia, Camera and Video Processing
Camera on Toradex Computer on Modules An overview of how to use cameras with Toradex SoMs
How to use Analogue Camera Adapter on Embedded Linux How to use the Toradex Add-on Analogue Camera Adapter
Video Encoding and Playback With GStreamer (Linux) How to play and record videos, a must-read if you plan to use multimedia features
Webcam (Linux) How to use a webcam with GStreamer
Audio/Video over RTP (Linux) How to stream audio and video over a network with GStreamer
Audio (Linux) How to playback and record audio
Bluetooth Audio (Linux) How to use audio over Bluetooth
Computer Vision (CV), Artificial Intelligence (AI), Machine Learning (ML) and Deep Learning (DL)
AI, Computer Vision and Machine Learning on Toradex Computer on Modules An overview of computer vision and machine learning on Toradex SoMs
Building Machine Learning Software with Reference Images for Yocto Project How to add dependecies to run machine learning models with the Yocto Project/OpenEmbedded
OpenCV (Linux) Tips on how to use OpenCV on Toradex SoMs
Power Consumption
iMX6 Power Consumption Power consumption of NXP i.MX 6-based Toradex SoMs
iMX6ULL Power Consumption Power consumption of NXP i.MX 6ULL-based Toradex SoMs
iMX7 Power Consumption Power consumption of NXP i.MX 7-based Toradex SoMs
iMX8M Plus Power Consumption Power consumption of NXP i.MX 8M Plus-based Toradex SoMs
Tegra Power Consumption Power consumption of NVIDIA Tegra-based Toradex SoMs
VFxx Power Consumption Power consumption of NXP Vybrid-based Toradex SoMs
Thermal Management Tips on thermal management, including how to reduce the power consumption
Suspend/Resume (Linux) How to put the Linux system in a low-power state
CPU Frequency and DVFS (Linux) How to reduce the CPU frequency, impacting on the power consumption
Partners
Acontis Technologies acontis provides an EtherCAT Master Stack
Codesys Software PLC Solution CODESYS is a Software PLC
Crank Storyboard Crank Storyboard is a suite for GUI development
e-con Systems e-con Systems is a camera partner with MIPI CSI-2 cameras compatible with Toradex SoMs
Gumstix Upverter Upverter is a drag and drop carrier board designer tool that automatically generates a compatible BSP
Getting Started with Qt Qt is a widely adopted GUI framework
TotalCross TotalCross is a cross-platform GUI framework
Other Articles
You can find other articles using our search by tags and selecting the BSP Layers / Reference Images for Yocto (Linux) tag:
