Search by Tags
BSP Layers and Reference Images for Yocto Project Issue Tracker
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex BSP Layers and Reference Images for Yocto Project.
The tickets are split into two major states:
  • Submitted (open): new features and bug fixes for BSP versions that have not yet been released. They may be scheduled for a specific release version; not planned; or in our backlog. All of them have one of the following states:
    • Known Issue: a bug or unexpected behavior that has been reported and is pending a fix. Once fixed, the status will transition to Fixed.
    • Feature Request: a new feature that may be added to a future release. Once released, the status will transition to New Feature.
  • Released (closed): new features and bug fixes for BSP versions that have already been released. All of them have one of the following states:
    • Fixed: a bug that has been fixed and released.
    • New Feature: something that didn't exist before and was added to a new release.
Any schedules are not guaranteed but reflect the current planning. The planning could be shifted due to priority changes.
Issues that are scheduled for a specific version will be integrated into the mentioned version of the BSP.
We will update this table continuously in order to always provide the latest state of our development plan. Please see also the Linux Support Strategy to learn more about the different releases.
Clear Filter
Issue #StatusSubjectModuleSubsystemWinCE OSSeveritySubmitted for Mainline
V2.7 Beta 1 (Release date: 2017-01-13)
Known Issue for Colibri VF61: U-Boot 2016.11 Missing m4boot Command.
ELB-369New FeatureUpdate BCB to Support Bad Block Markers and Complete PagesColibri iMX7, Colibri VF50, Colibri VF61Bootloader, ConfigBlockLowNo
Description: So far U-Boot writes a BCB (Boot Configuration Block) crafted in a way to work around errata e9609. This also requires the U-Boot to be written in a way which only uses 3/4 of a page (implemented by the writeboot command). This mode has a drawback in practice: It cannot detect bad blocks marked with the usual bad block marker. Colibri iMX7 V1.1B and later do not suffer errata e9609. In order to overcome the limitations of the work-around, new U-Boot version will write the BCB in a new format which allows detecting bad block markers and use complete pages. This also allows to write the boot loader using standard nand write commands.
