Search by Tags
BSP Layers and Reference Images for Yocto Project Issue Tracker
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex BSP Layers and Reference Images for Yocto Project.
The tickets are split into two major states:
  • Submitted (open): new features and bug fixes for BSP versions that have not yet been released. They may be scheduled for a specific release version; not planned; or in our backlog. All of them have one of the following states:
    • Known Issue: a bug or unexpected behavior that has been reported and is pending a fix. Once fixed, the status will transition to Fixed.
    • Feature Request: a new feature that may be added to a future release. Once released, the status will transition to New Feature.
  • Released (closed): new features and bug fixes for BSP versions that have already been released. All of them have one of the following states:
    • Fixed: a bug that has been fixed and released.
    • New Feature: something that didn't exist before and was added to a new release.
Any schedules are not guaranteed but reflect the current planning. The planning could be shifted due to priority changes.
Issues that are scheduled for a specific version will be integrated into the mentioned version of the BSP.
We will update this table continuously in order to always provide the latest state of our development plan. Please see also the Linux Support Strategy to learn more about the different releases.
Clear Filter
Issue #StatusSubjectModuleSubsystemWinCE OSSeveritySubmitted for Mainline
2.7b4 (Release date: 2017-10-05)
In this release we changed to use Ext4 file system by default. This could lead to non booting modules if a previously saved U-Boot environment is set to non-ext4. Please see the following issue for more details: http://developer.toradex.com/software/linux/linux-software/release-details?view=all&issue=27678
ELB-725Fixed'run update' Fails if the Rootfs is Exactly a Multiple of 64MApalis iMX6, Colibri iMX6, Apalis TK1, Colibri T30, Apalis T30BootloaderLowNo
Description: If an image creates a rootfs which is exactly a multiple of 64 MByte and then if one executes in U-Boot 'run update' the detection that all 64 MByte chunks have been flashed fails and the update never completes. Note that the Toradex Easy Installer is not affected.
Workaround: Check the last rootfs chunk on the update media and create a zero length chunk with incremented number, e.g.: $ ls -l //colibri-imx6/ ... -rw-r--r--. 1 root root 67108864 Jul 12 15:13 root.ext3-106 -rw-r--r--. 1 root root 67108864 Jul 12 15:13 root.ext3-107 -rw-r--r--. 1 root root 48128 Jul 12 15:13 SPL ... $ touch //colibri-imx6/root.ext3-108
