Search by Tags
BSP Layers and Reference Images for Yocto Project Issue Tracker
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex BSP Layers and Reference Images for Yocto Project.
The tickets are split into two major states:
  • Submitted (open): new features and bug fixes for BSP versions that have not yet been released. They may be scheduled for a specific release version; not planned; or in our backlog. All of them have one of the following states:
    • Known Issue: a bug or unexpected behavior that has been reported and is pending a fix. Once fixed, the status will transition to Fixed.
    • Feature Request: a new feature that may be added to a future release. Once released, the status will transition to New Feature.
  • Released (closed): new features and bug fixes for BSP versions that have already been released. All of them have one of the following states:
    • Fixed: a bug that has been fixed and released.
    • New Feature: something that didn't exist before and was added to a new release.
Any schedules are not guaranteed but reflect the current planning. The planning could be shifted due to priority changes.
Issues that are scheduled for a specific version will be integrated into the mentioned version of the BSP.
We will update this table continuously in order to always provide the latest state of our development plan. Please see also the Linux Support Strategy to learn more about the different releases.
Clear Filter
Issue #StatusSubjectModuleSubsystemWinCE OSSeveritySubmitted for Mainline
Not Planned
ELB-978Known IssueLegacy Update Procedure May Fail With Bigger ImagesColibri iMX7, Colibri VF50, Colibri T20FlashMediumNo
Description: On NAND flash based modules like the Colibri T20, the legacy update procedure depends on first loading the entire root file system image into RAM. If your custom image is significantly larger than our regular demo images it may no longer easily fit into 256MB of RAM, therefore, failing the legacy update procedure (it may just hang or even crash but definitely fails to update the root file system).
Workaround: Doing the following before 'run setupdate; run update' may help to a certain extend:
setenv fdt_addr_r 0x01000000
However, even bigger images may still fail requiring a different flashing strategy altogether (e.g. initially booting from an initrd or via NFS subsequently updating the root file system from within Linux on-the-fly.
