Search by Tags
BSP Layers and Reference Images for Yocto Project Issue Tracker
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex BSP Layers and Reference Images for Yocto Project.
The tickets are split into two major states:
  • Submitted (open): new features and bug fixes for BSP versions that have not yet been released. They may be scheduled for a specific release version; not planned; or in our backlog. All of them have one of the following states:
    • Known Issue: a bug or unexpected behavior that has been reported and is pending a fix. Once fixed, the status will transition to Fixed.
    • Feature Request: a new feature that may be added to a future release. Once released, the status will transition to New Feature.
  • Released (closed): new features and bug fixes for BSP versions that have already been released. All of them have one of the following states:
    • Fixed: a bug that has been fixed and released.
    • New Feature: something that didn't exist before and was added to a new release.
Any schedules are not guaranteed but reflect the current planning. The planning could be shifted due to priority changes.
Issues that are scheduled for a specific version will be integrated into the mentioned version of the BSP.
We will update this table continuously in order to always provide the latest state of our development plan. Please see also the Linux Support Strategy to learn more about the different releases.
Clear Filter
Issue #StatusSubjectModuleSubsystemWinCE OSSeveritySubmitted for Mainline
2.8b4 (Release date: 2018-10-05)
ELB-1009New FeatureAssert nRESET_OUT on RebootColibri iMX6ULLPower Management, WatchdogLowNo
Description: The i.MX6 ULL's watchdog is used to reset the SoC on reboot. The watchdog is configured to use the SoC's internal reset signal which does not generate a reset pulse on nRESET_OUT. Change the watchdog configuration to use a SoC external HW signal. This will additionally change the 'Reset cause' message from U-Boot from WDOG to POR. Note that the bmode_usb application in Linux no longer works due to the reset cause change. The behaviour in U-Boot has not been changed, the U-Boot command 'bmode usb' works as before.
