Search by Tags
Toradex Easy Installer Issue Tracker
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex Easy Installer. The tickets are split in two major states:
  • Submitted (open): new features and bug fixes for Toradex Easy Installer versions that have not yet been released. They may be scheduled for a specific release version; not planned; or in our backlog. All of them have one of the following states:
    • Known Issue: a bug or unexpected behavior that has been reported and pending a fix. Once fixed, the status will transition to Fixed.
    • Feature Request: a new feature that may be added to a future release. Once released, the status will transition to New Feature.
  • Released (closed): new features and bug fixes for BSP versions that have already been released. All of them have one of the following states:
    • Fixed: a bug that has been fixed and released.
    • New Feature: something that didn't exist before and was added to a new release.
Any schedules are not guaranteed but reflect the current planning. The planning could be shifted due to priority changes.
Issues that are scheduled for a specific version will be integrated into the mentioned version of the BSP.
Clear Filter
Issue #StatusSubjectModuleSubsystemSeveritySubmitted for Mainline
2.0b1 (Release date: 2019-06-14)
TEI-6FixedAfter Recovery From Erased NAND Flash the System Remains UnbootableColibri iMX7, Colibri iMX6ULLBootloaderLowNo
Description: If the complete NAND gets erased, e.g. by the U-Boot command 'nand erase.chip' the BCB data structure at the beginning of the NAND needs to be rewritten in order to boot from NAND. The Toradex Easy Installer does this as part of a missing Config Block recovery process.
Workaround: If you erase the NAND chip, do not write the Config Block in U-Boot. Recover with the Toradex Easy Installer which will interactively ask for the Config Block data and write the BCB.
