Search by Tags
Toradex Easy Installer Issue Tracker
The following table contains known issues, scheduled bug fixes, and feature improvements for the Toradex Easy Installer. The tickets are split in two major states:
  • Submitted (open): new features and bug fixes for Toradex Easy Installer versions that have not yet been released. They may be scheduled for a specific release version; not planned; or in our backlog. All of them have one of the following states:
    • Known Issue: a bug or unexpected behavior that has been reported and pending a fix. Once fixed, the status will transition to Fixed.
    • Feature Request: a new feature that may be added to a future release. Once released, the status will transition to New Feature.
  • Released (closed): new features and bug fixes for BSP versions that have already been released. All of them have one of the following states:
    • Fixed: a bug that has been fixed and released.
    • New Feature: something that didn't exist before and was added to a new release.
Any schedules are not guaranteed but reflect the current planning. The planning could be shifted due to priority changes.
Issues that are scheduled for a specific version will be integrated into the mentioned version of the BSP.
Clear Filter
Issue #StatusSubjectModuleSubsystemSeveritySubmitted for Mainline
2.0b1 (Release date: 2019-06-14)
TEI-26FixedDistro Boot Only Works From The First PartitionColibri iMX7, Colibri iMX6ULL, Apalis iMX6, Colibri iMX6, Apalis TK1, Apalis T30BootloaderLowNo
Description: Turns out our current boot.scr script uses ${bootpart} rather than ${distro_bootpart} to reference the partition. Luckily, U-Boot just assumes the first partition if nothing is passed e.g. in a load command. That is why distro boot worked at all at least from the first partition.
Workaround: First, you have to make sure whatever partition you want to boot from is actually set to active boot in the partition table.
Then, change the boot script making sure you use ${distro_bootpart} rather than ${bootpart}. You may re-create the script from a text file as follows:
mkimage -T script -C none -n 'Distro boot script' -d boot.txt boot.scr
