Download Links
On this page you will find the images from Toradex and our partners, for offline installation using the Toradex Easy Installer. It is useful when an image is not available directly in our online servers - for instance, old versions of a specific image - or when your company network does not allow the board to access our online servers.
How to install these images
To install these images, you need to use the Toradex Easy Installer, which comes pre-installed on Toradex modules. You can also load it to your module if you have it already flashed with another image. To load Toradex Easy Installer to your module, please download it and follow the steps to load it. To make the images available to Toradex Easy Installer, check the Provide OS Images section.
Test Results
All images provided by Toradex are tested. To see the test results for each image, see the Toradex Software Test Results page.
Partner Demo Images
Among the options presented in Toradex Easy Installer, there are partner demo images available for the evaluation of different technologies and solutions. Please go to a specific partner demo image page from the table below. You will find the download links on each partner demo image page.
| Partner | Demo Image | Summary Overview | |
![]() | Qt Company | Qt for Device Creation | Light-weight, Qt-optimized, full software stack for embedded Linux systems |
| Kynetics | Kynetics Android | Android port to Toradex hardware by Kynetics | |
![]() | Acontis Technologies | acontis EC-Master EtherCAT Stack | EtherCAT System implementation by Acontis Technologies |
![]() | BlackBerry QNX | QNX Neutrino Real-time Operating System | QNX Neutrino RTOS port to Toradex hardware |
![]() | Amazon Web Services | AWS AI at the Edge Pasta Detection | End-to-end demonstration of pasta detection using deep learning and connected to the AWS cloud |
| DiSTI Corporation | DiSTI GL Studio | DiSTI's technology of GL Studio showcased in a UI with the look and feel of automotive design | |
![]() | ITTIA | ITTIA DB SQL for Device Data Management | Interactive relational database utilities and management system for intelligent embedded systems |
Torizon OS Embedded Linux Images
The Torizon OS images for offline installation are provided below:
Torizon OS Quarterly Releases
Quarterly releases are production releases. They are good for development but also for deployment on the field. They get replaced with a newer quarterly every 3 months.
Torizon OS 7
Torizon OS Linux with no containers pre-provisioned.
| OS Image | Version | Date | Size |
Apalis iMX6🛈 MD518f67810d5c7066859ec12fe81583025 | 7.5.0+build.30 | 2026/01/21 | 201.91 MiB |
Apalis iMX8🛈 MD58ebc455764826d820eff91eeecfdf676 | 7.5.0+build.30 | 2026/01/21 | 212.57 MiB |
Aquila AM69🛈 MD56072c6f40fddac426fc20c04425d5b32 | 7.5.0+build.30 | 2026/01/21 | 277.32 MiB |
Aquila iMX95🛈 MD5623da999171ed14502b978f72261bf81 | 7.5.0+build.30 | 2026/01/21 | 235.16 MiB |
Colibri iMX6🛈 MD5ae71ebfcc0520d35f16d8dd290df5693 | 7.5.0+build.30 | 2026/01/21 | 200.00 MiB |
Colibri iMX6ULL eMMC🛈 MD592bb7f36085377aa993117672325512d | 7.5.0+build.30 | 2026/01/21 | 193.02 MiB |
Colibri iMX7 eMMC🛈 MD54eaa1b671d3abe477dd4f0aec5bc74d7 | 7.5.0+build.30 | 2026/01/21 | 192.98 MiB |
Colibri iMX8X🛈 MD5f3a57da77c324b48f5ed0d892a80013a | 7.5.0+build.30 | 2026/01/21 | 211.79 MiB |
SMARC iMX8M Plus🛈 MD54a09909758be4b179f439b21f516789e | 7.5.0+build.30 | 2026/01/21 | 212.73 MiB |
SMARC iMX95🛈 MD57290dcf2aa4e7a3ceecc3adf4b0502a4 | 7.5.0+build.30 | 2026/01/21 | 258.48 MiB |
Verdin AM62🛈 MD5051d910322043c2bd4c7db4f024efe07 | 7.5.0+build.30 | 2026/01/21 | 246.41 MiB |
Verdin AM62P🛈 MD5518e54f940c6c40085160a858fbd6701 | 7.5.0+build.30 | 2026/01/21 | 248.77 MiB |
Verdin iMX8M Mini🛈 MD59a201a38eb9bbd79cfe240aebf6b6657 | 7.5.0+build.30 | 2026/01/21 | 220.59 MiB |
Verdin iMX8M Plus🛈 MD5069ddf30799e87349af93c81c19b794a | 7.5.0+build.30 | 2026/01/21 | 220.08 MiB |
Verdin iMX95🛈 MD5b4f5c7524ad41055565820c8db37c2d0 | 7.5.0+build.30 | 2026/01/21 | 258.51 MiB |
Torizon OS Linux with Easy Pairing application.
Apalis iMX6🛈 MD5aa7735225af2b24b094cb24402411ae6 | 7.5.0+build.30 | 2026/01/22 | 362.47 MiB |
Apalis iMX8🛈 MD58b62e22d8f909688558027cac64f38e8 | 7.5.0+build.30 | 2026/01/22 | 385.93 MiB |
Aquila AM69🛈 MD549a61898f7c688e65244b39dbbf27b35 | 7.5.0+build.30 | 2026/01/22 | 450.61 MiB |
Aquila iMX95🛈 MD51e957a1bcf7e2218f2418727fa8619bd | 7.5.0+build.30 | 2026/01/22 | 408.52 MiB |
Colibri iMX6🛈 MD5186e4f6c91ab7351faae2d27c3a7cabd | 7.5.0+build.30 | 2026/01/22 | 361.23 MiB |
Colibri iMX6ULL eMMC🛈 MD5201c88a86aa09965873691bd9a332105 | 7.5.0+build.30 | 2026/01/22 | 367.46 MiB |
Colibri iMX7 eMMC🛈 MD50a53d1a137d82351a5677daa9908158f | 7.5.0+build.30 | 2026/01/22 | 361.10 MiB |
Colibri iMX8X🛈 MD5823ab77cb1a36c444eded61f16e0eb6f | 7.5.0+build.30 | 2026/01/22 | 393.20 MiB |
SMARC iMX8M Plus🛈 MD5702f46e43b5839caad8debb80defa95c | 7.5.0+build.30 | 2026/01/22 | 385.61 MiB |
SMARC iMX95🛈 MD56f4171428a5d7a76f55580b81879465d | 7.5.0+build.30 | 2026/01/22 | 424.91 MiB |
Verdin AM62🛈 MD5406fa64a648aeaa50c1dff63c8210528 | 7.5.0+build.30 | 2026/01/22 | 412.42 MiB |
Verdin AM62P🛈 MD5afb16b31fa1b6590169ec208c7c46da5 | 7.5.0+build.30 | 2026/01/22 | 415.12 MiB |
Verdin iMX8M Mini🛈 MD5084bf02124c3189859e4e36f6c396367 | 7.5.0+build.30 | 2026/01/22 | 393.76 MiB |
Verdin iMX8M Plus🛈 MD5cb35e4d95c1f7c71b152aad62a57d781 | 7.5.0+build.30 | 2026/01/22 | 385.73 MiB |
Verdin iMX95🛈 MD53d02aa3262fa5592718e2f694347880a | 7.5.0+build.30 | 2026/01/22 | 424.48 MiB |
Torizon OS 6
- Torizon OS 6 maintenance releases
- Torizon OS 6 Easy Pairing maintenance releases
- Torizon OS 6 older quarterly releases
Apalis iMX6🛈 MD5fb3a0dbd8ce191b6f32a8bf87e926b38 | 6.8.5+build.41 | 2026/01/20 | 183.75 MiB |
Apalis iMX8🛈 MD59d3671a9161d55831233692f40abe651 | 6.8.5+build.41 | 2026/01/20 | 205.98 MiB |
Colibri iMX6🛈 MD52baffa63c1a94f3aae90f8779ac6d50d | 6.8.5+build.41 | 2026/01/20 | 183.22 MiB |
Colibri iMX6ULL eMMC🛈 MD5cb0e82aa615b97d1afc0c69ea1ec89d0 | 6.8.5+build.41 | 2026/01/20 | 188.74 MiB |
Colibri iMX7 eMMC🛈 MD585c9b47d8ee327961f45819dad734cd4 | 6.8.5+build.41 | 2026/01/21 | 182.80 MiB |
Colibri iMX8X🛈 MD5c8d79b2a83f4eb301d2d9a054d387a73 | 6.8.5+build.41 | 2026/01/20 | 198.34 MiB |
Verdin AM62🛈 MD5ce56089baa3a793263f3bc41386aa7ce | 6.8.5+build.41 | 2026/01/20 | 229.56 MiB |
Verdin iMX8M Mini🛈 MD56fc0b908a6d47d6eb84564d7b49b8816 | 6.8.5+build.41 | 2026/01/21 | 207.44 MiB |
Verdin iMX8M Plus🛈 MD56d7bead2af2852f4698b993173012cae | 6.8.5+build.41 | 2026/01/20 | 205.72 MiB |
Apalis iMX6🛈 MD57492e8e333669d5ad69ffdfb5ecd3a20 | 6.8.5+build.41 | 2026/01/21 | 321.63 MiB |
Apalis iMX8🛈 MD5b6caa0259795b590e2f64625d68825f5 | 6.8.5+build.41 | 2026/01/21 | 342.36 MiB |
Colibri iMX6🛈 MD5a068f6b0976b4bb2b8845fcf1eb4dd76 | 6.8.5+build.41 | 2026/01/21 | 314.48 MiB |
Colibri iMX6ULL eMMC🛈 MD5524bc0d92d6dc95416813519d58ee872 | 6.8.5+build.41 | 2026/01/21 | 320.55 MiB |
Colibri iMX7 eMMC🛈 MD5a6a88ef0b6d38fb7db2163b0eb27bb63 | 6.8.5+build.41 | 2026/01/21 | 314.27 MiB |
Colibri iMX8X🛈 MD5ddce0cba2c7e88af7b257d9fa4390805 | 6.8.5+build.41 | 2026/01/21 | 334.23 MiB |
Verdin AM62🛈 MD5f79d4d2e3d46373e770beaa154f8d08b | 6.8.5+build.41 | 2026/01/21 | 358.73 MiB |
Verdin iMX8M Mini🛈 MD50c6ea6d6c9c17475ee857a194ea937bd | 6.8.5+build.41 | 2026/01/21 | 351.41 MiB |
Verdin iMX8M Plus🛈 MD51cef404f470b8578fcc3390af8edb143 | 6.8.5+build.41 | 2026/01/21 | 335.37 MiB |
- Torizon OS 6.8.4+build.40
- Torizon OS 6.8.3+build.37
- Torizon OS 6.8.2+build.30
- Torizon OS 6.8.1+build.25
- Torizon OS 6.8.0+build.22
- Torizon OS 6.8.0+build.21
- Torizon OS 6.7.0+build.18
- Torizon OS 6.6.1+build.14
- Torizon OS 6.6.1+build.12
- Torizon OS 6.5.0+build.8
- Torizon OS 6.4.0+build.5
- Torizon OS 6.3.0+build.4
- Torizon OS 6.2.0+build.2
- Torizon OS 6.1.0+build.1
TorizonCore 5
- TorizonCore 5 maintenance releases
- TorizonCore 5 maintenance releases with evaluation containers
- TorizonCore 5 older quarterly releases
TorizonCore Linux with no containers pre-provisioned.
Apalis iMX6🛈 MD5c7e582b84510412294a4f572c4621079 | 5.7.2+build.20 | 2023/03/29 | 165.27 MiB |
Apalis iMX8🛈 MD5f6878fdf88bfdb49359f26f2f10d27d9 | 5.7.2+build.20 | 2023/03/29 | 184.62 MiB |
Colibri iMX6🛈 MD50287186f56f50744846034d08b882ccf | 5.7.2+build.20 | 2023/03/29 | 164.96 MiB |
Colibri iMX6ULL eMMC🛈 MD5e230b8657f3c323ce283e8e5800847c8 | 5.7.2+build.20 | 2023/03/29 | 174.31 MiB |
Colibri iMX7 eMMC🛈 MD504a059f5049462210206a52c5016f3ee | 5.7.2+build.20 | 2023/03/29 | 174.50 MiB |
Colibri iMX8X🛈 MD5959ebbb206abdf40edbff4684388e4b8 | 5.7.2+build.20 | 2023/03/29 | 195.33 MiB |
Verdin iMX8M Mini🛈 MD5f8d65536485b587eaa1332986be1d5ef | 5.7.2+build.20 | 2023/03/29 | 202.46 MiB |
Verdin iMX8M Plus🛈 MD515bb7e1f8dd6d6519d75012f717d8997 | 5.7.2+build.20 | 2023/03/29 | 183.99 MiB |
TorizonCore Linux with several containers focused on development: Weston, Chromium, Portainer and Development Tools container.
Apalis iMX6🛈 MD57261aa7a40151169b9601cec37ef1c37 | 5.7.2+build.20 | 2023/04/13 | 406.59 MiB |
Apalis iMX8🛈 MD5b1d645a3ec32306bd1e0a92d420dba6c | 5.7.2+build.20 | 2023/04/13 | 407.96 MiB |
Colibri iMX6🛈 MD592c2ae509a8978598c3dea10767bfbbe | 5.7.2+build.20 | 2023/04/13 | 406.33 MiB |
Colibri iMX6ULL eMMC🛈 MD5f3ceaa8d9e07b83677260c3fae76ebe1 | 5.7.2+build.20 | 2023/04/13 | 451.12 MiB |
Colibri iMX7 eMMC🛈 MD564e5f3c43b80dea6f07723cec2699347 | 5.7.2+build.20 | 2023/04/13 | 451.45 MiB |
Colibri iMX8X🛈 MD51ed179c3c602f58cb492335b68178997 | 5.7.2+build.20 | 2023/04/13 | 407.81 MiB |
Verdin iMX8M Mini🛈 MD57e08077fb601123fefbb715d0372c137 | 5.7.2+build.20 | 2023/04/13 | 414.58 MiB |
Verdin iMX8M Plus🛈 MD543e6ccbdadd3adbb096708224e958ded | 5.7.2+build.20 | 2023/04/13 | 407.51 MiB |
TorizonCore 5 Last Quarterly Release
| OS Image | Date | Version | Supported Modules | |
| TorizonCore with evaluation containers 5.7.0+build.17.container TorizonCore Linux with several containers focused on development: Weston, Chromium, Portainer and Development Tools container | 2022-07-28 | 5.7.0+build.17.container | Apalis iMX6 (441.27 MB) Apalis iMX8 (422.84 MB) Colibri iMX6 (440.77 MB) Colibri iMX6ULL 1GB (eMMC) (451.2 MB) Colibri iMX7 Dual 1GB (eMMC) (451.5 MB) Colibri iMX8X (422.79 MB) Verdin iMX8M Mini (429.52 MB) Verdin iMX8M Plus (non-LTS) (422.36 MB) | |
| TorizonCore 5.7.0+build.17 TorizonCore Linux with no containers pre-provisioned | 2022-07-28 | 5.7.0+build.17 | Apalis iMX6 (175.19 MB) Apalis iMX8 (184.44 MB) Colibri iMX6 (174.86 MB) Colibri iMX6ULL 1GB (eMMC) (174.18 MB) Colibri iMX7 Dual 1GB (eMMC) (174.55 MB) Colibri iMX8X (184.28 MB) Verdin iMX8M Mini (202.12 MB) Verdin iMX8M Plus (non-LTS) (183.85 MB) |
TorizonCore 5 Older Quarterly Releases
TorizonCore 5 Quarterly release is no longer built.
- TorizonCore 5.6.0
- TorizonCore 5.5.0
- TorizonCore 5.4.0
- TorizonCore 5.3.0
- TorizonCore 5.2.0 quarterly release was skipped. Learn more on TorizonCore 5.2.0-devel-202104 Release (Monthly)
- TorizonCore 5.1.0
Torizon OS Monthly Releases
Monthly releases are pre-production releases. They are good for development as you keep up-to-date with the latest features and bugfixes.
The images with the PREEMPT_RT patch haven't been fully validated by Toradex. We have only run smoke tests and cyclictest to make sure that the system boots properly and the PREEMPT_RT patches are working on idle conditions.
Torizon OS 7
- Torizon OS 7
- Torizon OS 7 PREEMPT_RT
- Torizon OS 7 Easy Pairing
- Torizon OS 7 PREEMPT_RT Easy Pairing
- Torizon OS 7 older monthly releases
Apalis iMX6🛈 MD50b1e4c3157049b3a1cd53243c5e5e82e | 7.6.0-devel-202602+build.17 | 2026/02/03 | 195.05 MiB |
Apalis iMX8🛈 MD523e7acdb97fa160ac0dea0fe873b5322 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 219.94 MiB |
Aquila AM69🛈 MD5469055bab697a154de49e53a514cacfa | 7.6.0-devel-202602+build.17 | 2026/02/03 | 277.23 MiB |
Aquila iMX95🛈 MD5eb128c10a6a14983040e91badbae224e | 7.6.0-devel-202602+build.17 | 2026/02/03 | 235.50 MiB |
Colibri iMX6🛈 MD5efe34568823824c1e4d850a02f2dd5f4 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 194.39 MiB |
Colibri iMX6ULL eMMC🛈 MD5e85eba8bd8c93e399981b71a70366004 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 193.81 MiB |
Colibri iMX7 eMMC🛈 MD55f2d7e5b33302c14447bac51619216cf | 7.6.0-devel-202602+build.17 | 2026/02/03 | 194.40 MiB |
Colibri iMX8X🛈 MD56d734000e4ef6cb9f97870a36c2ecfba | 7.6.0-devel-202602+build.17 | 2026/02/03 | 219.79 MiB |
SMARC iMX8M Plus🛈 MD596ed475f516864c9c44839c178e39d69 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 220.10 MiB |
SMARC iMX95🛈 MD50685ad85b1689e892be8a12dd1ead548 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 251.37 MiB |
Verdin AM62🛈 MD5304a0db0d8e6b293c5d43fb19fdd029c | 7.6.0-devel-202602+build.17 | 2026/02/03 | 239.06 MiB |
Verdin AM62P🛈 MD56180bca4fa2b2e4c45dd0b8f30f814fd | 7.6.0-devel-202602+build.17 | 2026/02/03 | 248.79 MiB |
Verdin iMX8M Mini🛈 MD53deda8833e79702a82731571a9935574 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 228.62 MiB |
Verdin iMX8M Plus🛈 MD5099f3d2b3f2f86f8e8be88235851e14d | 7.6.0-devel-202602+build.17 | 2026/02/03 | 220.13 MiB |
Verdin iMX95🛈 MD57929920fbc127d33fb94d7d63ed1620d | 7.6.0-devel-202602+build.17 | 2026/02/03 | 258.48 MiB |
Using a Linux kernel with PREEMPT_RT real-time patch applied.
Apalis iMX6🛈 MD50d14fa9f903861c24aa3848002b67da8 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 193.97 MiB |
Apalis iMX8🛈 MD5924289c476fed53638d8f7f0dbb0b682 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 211.40 MiB |
Aquila AM69🛈 MD5e83689ec24d77a0e8a9d4f2c2b3e7679 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 284.30 MiB |
Aquila iMX95🛈 MD542e2b032a814e11ae407542b6d47760e | 7.6.0-devel-202602+build.17 | 2026/02/03 | 242.13 MiB |
Colibri iMX6🛈 MD5b6e962c76fa87840b9c705a0ffb1385d | 7.6.0-devel-202602+build.17 | 2026/02/03 | 193.45 MiB |
Colibri iMX6ULL eMMC🛈 MD5f29698b5e201316e25b9d15fef0fc497 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 199.52 MiB |
Colibri iMX7 eMMC🛈 MD5e5024f549c71ea740214d025c51b17e7 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 193.30 MiB |
Colibri iMX8X🛈 MD5af50c562c10aa1764b319d2a92ca16b8 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 211.51 MiB |
SMARC iMX8M Plus🛈 MD510a9b01d04709ef357e445afe462b695 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 211.35 MiB |
SMARC iMX95🛈 MD524d0779fa84af742031f83878c4b2f56 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 250.20 MiB |
Verdin AM62🛈 MD5204b2fe9a5d7b85d1366bed52718aede | 7.6.0-devel-202602+build.17 | 2026/02/03 | 238.53 MiB |
Verdin AM62P🛈 MD5e72cf0a6e42707947174e8ae8a8073dd | 7.6.0-devel-202602+build.17 | 2026/02/03 | 247.30 MiB |
Verdin iMX8M Mini🛈 MD5b81a6b8ef1d1fed3e57d031bbd5d7bb6 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 227.31 MiB |
Verdin iMX8M Plus🛈 MD508e1c52125b6782cf3fd4b5d2f51d439 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 211.42 MiB |
Verdin iMX95🛈 MD519579a39752444449923398f61c91b28 | 7.6.0-devel-202602+build.17 | 2026/02/03 | 250.54 MiB |
Apalis iMX6🛈 MD59e233fc2d6a27276974e5b3f1cb6f768 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 369.78 MiB |
Apalis iMX8🛈 MD5aead2871225aaaa832aa3293c216bb6a | 7.6.0-devel-202602+build.17 | 2026/02/04 | 385.48 MiB |
Aquila AM69🛈 MD591f9d7444e857bdb69a89dc22fff9c92 | 7.5.0-devel-202512+build.15 | 2025/12/04 | 450.68 MiB |
Colibri iMX6🛈 MD5fe19d3328b71952043282cd0e3c56f37 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 362.47 MiB |
Colibri iMX6ULL eMMC🛈 MD5597ea326b02b4758afca180d2aca0000 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 368.87 MiB |
Colibri iMX7 eMMC🛈 MD5760e87e5943d9cd3c4f9449922e4318d | 7.5.0-devel-202511+build.14 | 2025/11/05 | 360.89 MiB |
Colibri iMX8X🛈 MD54172417cc6b4c5415461ab5632fa8cb7 | 7.5.0-devel-202512+build.15 | 2025/12/04 | 385.14 MiB |
SMARC iMX8M Plus🛈 MD5dbef67b30836ee203e76199538c4fd53 | 7.5.0-devel-202512+build.15 | 2025/12/04 | 385.45 MiB |
SMARC iMX95🛈 MD5c1effe576d5184ff7d23963d0431e282 | 7.5.0-devel-202512+build.15 | 2025/12/04 | 424.43 MiB |
Verdin AM62🛈 MD5a38331f0f0079e3c13c3c4c739e0dd2d | 7.5.0-devel-202512+build.15 | 2025/12/04 | 412.59 MiB |
Verdin AM62P🛈 MD5e44fdb7b96ccedd2757f61ac0aed9474 | 7.5.0-devel-202512+build.15 | 2025/12/04 | 414.74 MiB |
Verdin iMX8M Mini🛈 MD540b18467809c450b898fb8b32ef22b27 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 393.84 MiB |
Verdin iMX8M Plus🛈 MD58a6798cba15c828bc9035997ebf00b14 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 385.64 MiB |
Verdin iMX95🛈 MD54fbf43634f98e87ff6dc9e54f263c5ea | 7.6.0-devel-202602+build.17 | 2026/02/04 | 424.70 MiB |
Apalis iMX6🛈 MD569ab0c16a2be06ef0a4d75970c4535ba | 7.5.0-devel-202512+build.15 | 2025/12/04 | 360.64 MiB |
Apalis iMX8🛈 MD515377eed73a29c48219de70fe94ae75b | 7.6.0-devel-202602+build.17 | 2026/02/04 | 392.17 MiB |
Aquila AM69🛈 MD5c149ece2edc483d2a6665f3f1e116c0e | 7.6.0-devel-202602+build.17 | 2026/02/04 | 450.03 MiB |
Aquila iMX95🛈 MD5f12b51f5f7cd7bdf7e55a60f50af3d87 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 415.54 MiB |
Colibri iMX6🛈 MD53f677b93d415fc7cf862ef338df7168c | 7.5.0-devel-202512+build.15 | 2025/12/04 | 366.61 MiB |
Colibri iMX6ULL eMMC🛈 MD515a8cb4f93cd6204a00bc210679d65f7 | 7.5.0-devel-202512+build.15 | 2025/12/04 | 366.07 MiB |
Colibri iMX7 eMMC🛈 MD5e71da4e87afead78a917da07ac410277 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 360.81 MiB |
Colibri iMX8X🛈 MD5d758362f1ce53dc151dfb09026f9b4fa | 7.6.0-devel-202602+build.17 | 2026/02/04 | 384.30 MiB |
SMARC iMX8M Plus🛈 MD5a7e9a8d43e01c1bbb636b8fa2b085279 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 384.69 MiB |
SMARC iMX95🛈 MD5474816cceb22628c6427312c93eb5dc9 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 423.48 MiB |
Verdin AM62🛈 MD5faf44024135a64072b8a2013015446e5 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 411.00 MiB |
Verdin AM62P🛈 MD5f84a6b4adf823ea1d59e326eae451ee3 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 413.72 MiB |
Verdin iMX8M Mini🛈 MD55454033c6e9acaca55e69e9c677f0f05 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 392.97 MiB |
Verdin iMX8M Plus🛈 MD540391127f90a91e4d4e0cf95f9313b34 | 7.5.0-devel-202512+build.15 | 2025/12/04 | 384.66 MiB |
Verdin iMX95🛈 MD5ad0882a508dff3913875312fdb5f4a24 | 7.6.0-devel-202602+build.17 | 2026/02/04 | 423.51 MiB |
- Torizon OS 7.5.0-devel-202512+build.16
- Torizon OS 7.5.0-devel-202512+build.15
- Torizon OS 7.5.0-devel-202511+build.14
- Torizon OS 7.4.0-devel-202509+build.13
- Torizon OS 7.4.0-devel-202508+build.12
- Torizon OS 7.3.0-devel-202506+build.9
- Torizon OS 7.3.0-devel-202505+build.8
- Torizon OS 7.2.0-devel-202503+build.7
- Torizon OS 7.2.0-devel-202503+build.6
- Torizon OS 7.2.0-devel-202502+build.5
- Torizon OS 7.1.0-devel-202412+build.4
- Torizon OS 7.1.0-devel-202412+build.3
- Torizon OS 7.1.0-devel-202411+build.2
- Torizon OS 7.0.0-devel-202409+build.1
Torizon OS 6
- Torizon OS 6
- Torizon OS 6 PREEMPT_RT
- Torizon OS 6 PREEMPT_RT Easy Pairing
- Torizon OS 6 older monthly releases
Apalis iMX6🛈 MD56cb771c2938efa66e079d41a379fe838 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 182.57 MiB |
Apalis iMX8🛈 MD5b346c0098b8a5bc381dca19f4b966d5c | 6.8.0-devel-202409+build.26 | 2024/09/11 | 197.18 MiB |
Colibri iMX6🛈 MD5443d765ccc5b39c9d7e2d80cb46556f4 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 188.42 MiB |
Colibri iMX6ULL eMMC🛈 MD53ab37c47bf63f5b23c36b71b41de85bd | 6.8.0-devel-202409+build.26 | 2024/09/11 | 181.56 MiB |
Colibri iMX7 eMMC🛈 MD51700b896bdcc1dcb4025753a63270ae6 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 181.77 MiB |
Colibri iMX8X🛈 MD5ceeae9892c6954e793507a13b7d02039 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 204.07 MiB |
Verdin AM62🛈 MD5f881f1c6a2ca7aa6716538737e6b85f3 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 238.97 MiB |
Verdin iMX8M Mini🛈 MD5602f5c59650e036a9e80fc9896753836 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 205.48 MiB |
Verdin iMX8M Plus🛈 MD5678a6bb6b2d0622a5901f397f5d92792 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 204.08 MiB |
Apalis iMX6🛈 MD50bbd9eac0e66445b67f121e8fb1cf5af | 6.8.0-devel-202409+build.26 | 2024/09/11 | 187.63 MiB |
Apalis iMX8🛈 MD51f02e13d1646ba2b0610635551318a7b | 6.8.0-devel-202409+build.26 | 2024/09/11 | 202.24 MiB |
Colibri iMX6🛈 MD5f64df91231f845f3f762043bc7294914 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 181.17 MiB |
Colibri iMX6ULL eMMC🛈 MD5c3cd45669cdb9ec41baa7e37bf7f29ce | 6.8.0-devel-202409+build.26 | 2024/09/11 | 180.83 MiB |
Colibri iMX7 eMMC🛈 MD5fe41cd5451983593504fe4d3a93c400d | 6.8.0-devel-202409+build.26 | 2024/09/11 | 180.62 MiB |
Colibri iMX8X🛈 MD55f1956cebb984cd123fbeea588d255f5 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 202.03 MiB |
Verdin iMX8M Mini🛈 MD54e707fd3f4d42d57120f9c7f23df45f6 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 203.52 MiB |
Verdin iMX8M Plus🛈 MD503c020a1aebac7945f8ce4a20392fb86 | 6.8.0-devel-202409+build.26 | 2024/09/11 | 195.19 MiB |
Torizon OS Linux with Easy Pairing appication.
Apalis iMX6🛈 MD587f1240f11ad68d337860d3f6d033e71 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 272.96 MiB |
Apalis iMX8🛈 MD5d8fac1c5c40dd8a5c6f9b7796e2adf65 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 290.15 MiB |
Colibri iMX6🛈 MD542290cbcfc8316a6167d4bbc1ce22a42 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 272.59 MiB |
Colibri iMX6ULL eMMC🛈 MD512267c0eb3ac442b07c043775a869c62 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 271.73 MiB |
Colibri iMX7 eMMC🛈 MD51a96109facec66bd310bdbe32f5f1924 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 272.53 MiB |
Colibri iMX8X🛈 MD583fccbaca2c01fcd655305a2a47a940b | 6.8.0-devel-202409+build.26 | 2024/09/12 | 289.79 MiB |
Verdin AM62🛈 MD53f0e1458105b1ba8af2354b56dcf8f41 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 325.48 MiB |
Verdin iMX8M Mini🛈 MD5393d45dcf848f43c8e4d4995cbfec00e | 6.8.0-devel-202409+build.26 | 2024/09/12 | 299.05 MiB |
Verdin iMX8M Plus🛈 MD5de1f68455e4962e7459121ed50cda882 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 290.44 MiB |
Apalis iMX6🛈 MD5f8eed7a635fb27db1c3a788a8bb39c10 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 271.69 MiB |
Apalis iMX8🛈 MD520ce7df84f80eacfda7d4cdda3da42db | 6.8.0-devel-202409+build.26 | 2024/09/12 | 288.21 MiB |
Colibri iMX6🛈 MD5236383561910384f23534d48d0222ac0 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 271.55 MiB |
Colibri iMX6ULL eMMC🛈 MD5bf2ae88db8556d20a8fa07746c311492 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 271.19 MiB |
Colibri iMX7 eMMC🛈 MD582025b44e6b617aa686aaeec68d173fe | 6.8.0-devel-202409+build.26 | 2024/09/12 | 271.20 MiB |
Colibri iMX8X🛈 MD5375100afa6bf2f3bad1493e99c2f21da | 6.8.0-devel-202409+build.26 | 2024/09/12 | 287.98 MiB |
Verdin iMX8M Mini🛈 MD52cc9728ef930b1b67d8ea20eecd336e3 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 296.97 MiB |
Verdin iMX8M Plus🛈 MD5faba0ab7ecca90f6f909265a0e390b15 | 6.8.0-devel-202409+build.26 | 2024/09/12 | 288.68 MiB |
- Torizon OS 6.8.0-devel-202408+build.25
- Torizon OS 6.7.0-devel-202406+build.24
- Torizon OS 6.7.0-devel-202405+build.23
- Torizon OS 6.6.0-devel-202403+build.22
- Torizon OS 6.6.0-devel-202402+build.21
- Torizon OS 6.5.0-devel-202312+build.20
- Torizon OS 6.5.0-devel-202311+build.14
- Torizon OS 6.4.0-devel-202309+build.13
- Torizon OS 6.4.0-devel-202309+build.12
- Torizon OS 6.4.0-devel-202308+build.9
- Torizon OS 6.3.0-devel-202306+build.8
- Torizon OS 6.2.0-devel-202303+build.6
- Torizon OS 6.2.0-devel-202302+build.5
- Torizon OS 6.1.0-devel-202212+build.4
- Torizon OS 6.1.0-devel-202211+build.3
- Torizon OS 6.0.0-devel-202210+build.2
- Torizon OS 6.0.0-devel-202209+build.1
TorizonCore 5
TorizonCore 5 Monthly release is no longer built.
- TorizonCore 5.7.0-devel-202206
- TorizonCore 5.7.0-devel-202205
- TorizonCore 5.6.0-devel-202203
- TorizonCore 5.6.0-devel-202202
- TorizonCore 5.5.0-devel-202112
- TorizonCore 5.5.0-devel-202111
- TorizonCore 5.4.0-devel-202109
- TorizonCore 5.4.0-devel-202108
- TorizonCore 5.3.0-devel-202106
- TorizonCore 5.3.0-devel-202105
Torizon OS Nightly and Experimental Releases
Nightly releases are pre-production releases without testing, and may not boot. Typically they are only used in development to focus on a feature or bug fix coming up in a monthly release.
Torizon OS 7
Apalis iMX6🛈 MD5ab51115f3dda9e17ae8e8fa3c0652a39 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 201.77 MiB |
Apalis iMX8🛈 MD54e89183c85fbeed7fcc3143b9e6caa59 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 220.02 MiB |
Aquila AM69🛈 MD55c8649e06439c733fce1da8c814c5cb2 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 285.59 MiB |
Aquila iMX95🛈 MD5ab716d9b359d26ae77bae30208311f64 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 235.63 MiB |
Colibri iMX6🛈 MD58cd28f8f648ac2e714b3be0f0b060d6c | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 201.39 MiB |
Colibri iMX6ULL eMMC🛈 MD51c6b8486e891fe8e6f0697d0e2c3eda4 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 193.85 MiB |
Colibri iMX7 eMMC🛈 MD557fdf8ba9dca572ee181b355778c76ff | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 194.07 MiB |
Colibri iMX8X🛈 MD591ffafb8eaf91ac5ae102b9648352b2b | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 219.80 MiB |
SMARC iMX8M Plus🛈 MD56d022eac15fb82b51d5e1fb9d5cb2581 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 219.97 MiB |
SMARC iMX95🛈 MD598d5f891e8d80ac0d68ab736230fec78 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 251.33 MiB |
Verdin AM62🛈 MD59bca9b1771c3164eaded7243e09d3a6f | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 238.99 MiB |
Verdin AM62P🛈 MD5a4b7239f180bf2eb564ebd04514a6d9a | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 248.83 MiB |
Verdin iMX8M Mini🛈 MD590f88870d69c4b770954b5a33126cfc5 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 228.66 MiB |
Verdin iMX8M Plus🛈 MD5a9e227c02e53edcbcfbdbf4e59270da2 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 212.74 MiB |
Verdin iMX95🛈 MD5378fabf35ef89c29d01493626d8e058d | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 251.33 MiB |
Apalis iMX6🛈 MD5247b7b0f876c0c583043c8fc6b9d414b | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 193.94 MiB |
Apalis iMX8🛈 MD5207a58434b2d6c07de63bea0df43448f | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 219.31 MiB |
Aquila AM69🛈 MD5cb5c0ede5565d644d2e7a48a3602c910 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 276.35 MiB |
Aquila iMX95🛈 MD5ebe7d9d6c385572065c3176f3d02830b | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 234.40 MiB |
Colibri iMX6🛈 MD556812d279b0a74390a3a6aa77890ca1d | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 200.06 MiB |
Colibri iMX6ULL eMMC🛈 MD50ad5b6c5016f591d130d0b8e94236f2f | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 199.43 MiB |
Colibri iMX7 eMMC🛈 MD5b1eda4edb12e8783017f60ac856621b7 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 193.29 MiB |
Colibri iMX8X🛈 MD5df94a840c4f4b6ef4344c7e5b7144764 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 218.45 MiB |
SMARC iMX8M Plus🛈 MD57adcb8e06f2d947821089294554e46a1 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 218.57 MiB |
SMARC iMX95🛈 MD5868a61d87254c6742e4e2e9536c118c2 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 250.38 MiB |
Verdin AM62🛈 MD55bb3628beab0715ee4c3202d7cd17823 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 244.96 MiB |
Verdin AM62P🛈 MD5265d3e778d1b7f39b12c7251b2717f11 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 240.31 MiB |
Verdin iMX8M Mini🛈 MD52db0826e53575e0dfc3410c923f02a10 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 227.85 MiB |
Verdin iMX8M Plus🛈 MD5594ac3977c4c93e2a5e87e0f88dbf14e | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 218.89 MiB |
Verdin iMX95🛈 MD50f859ba0f4638e66642bfd3ef97796b8 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 257.38 MiB |
Apalis iMX6🛈 MD5906f3caa086b0c1c76c368a948aa91a8 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 264.22 MiB |
Apalis iMX8🛈 MD5929e1345d1447d44f1e837d9a103692b | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 283.36 MiB |
Aquila AM69🛈 MD5e921801711799b386cbcb63faf15a561 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 349.36 MiB |
Aquila iMX95🛈 MD50c74d25a60f2b3411fa3a2f441c5b1d2 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 306.91 MiB |
Colibri iMX6🛈 MD5a737729d3df1acdf811209a8028a3b07 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 263.60 MiB |
Colibri iMX6ULL eMMC🛈 MD5e6059d0df3e6acca632976741dd90cfc | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 262.83 MiB |
Colibri iMX7 eMMC🛈 MD5ac0c01a4fad6f362b122387ca7409a89 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 263.37 MiB |
Colibri iMX8X🛈 MD5328119069392e79c164cfbff060c2fb2 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 283.41 MiB |
SMARC iMX8M Plus🛈 MD5a364995e6f55d238d5cb743c2861275f | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 291.61 MiB |
SMARC iMX95🛈 MD506fac6bbe99c58dfe610184dff6b2d69 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 322.92 MiB |
Verdin AM62🛈 MD5e1555a03f4784bc341b1f5cc4bc7f988 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 310.04 MiB |
Verdin AM62P🛈 MD5a1783a716110d08e6eb92d3b00bec643 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 312.32 MiB |
Verdin iMX8M Mini🛈 MD5f2c34d82300829f3cbe40751648d2485 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 291.60 MiB |
Verdin iMX8M Plus🛈 MD59d526fbfde5fbfc81ded3ad9f1884ed4 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 283.71 MiB |
Verdin iMX95🛈 MD58675e57a72c50335c15f0d91bcd6a9d4 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 322.22 MiB |
Apalis iMX6🛈 MD5b7cb21007f03eb271689f0794ebcbb8d | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 262.89 MiB |
Apalis iMX8🛈 MD56840656680f6c3f425bd482026f4dd09 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 282.47 MiB |
Aquila AM69🛈 MD568b06c4dc4a28d020b9ac549dce0be2f | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 347.40 MiB |
Aquila iMX95🛈 MD596d1d054b77d276a767e634d9140978d | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 305.77 MiB |
Colibri iMX6🛈 MD57f8b4c2674dc38b570ee45312d2861f4 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 262.04 MiB |
Colibri iMX6ULL eMMC🛈 MD53a566ba5e3d3c84e9694621a98bb80a9 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 261.76 MiB |
Colibri iMX7 eMMC🛈 MD5a3d48adc1640c03bc2a8514e3f89d2d3 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 268.38 MiB |
Colibri iMX8X🛈 MD5c93161c59c9bed3f20ad50f0cfe2a4a7 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 290.27 MiB |
SMARC iMX8M Plus🛈 MD59cd45a500d7bf01953d86e5023d32b1f | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 282.85 MiB |
SMARC iMX95🛈 MD5dd84a2233ed5041a9c7737f32f5ce0db | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 321.77 MiB |
Verdin AM62🛈 MD58b5f4c5ca58d5910680395898c825e5c | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 309.02 MiB |
Verdin AM62P🛈 MD58d6f7109052e24d51054017891948f7d | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 311.60 MiB |
Verdin iMX8M Mini🛈 MD54375d613bdcde1f45b90fb0aef6e9eed | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 290.27 MiB |
Verdin iMX8M Plus🛈 MD5a586247a3a1edafb9d09aaa97ed2968d | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 282.68 MiB |
Verdin iMX95🛈 MD51124e54b04ab3d2d6e45fe3324a65a64 | 7.6.0-devel-20260306+build.413 | 2026/03/06 | 321.64 MiB |
Torizon OS 6
- Torizon OS 6
- Torizon OS 6 PREEMPT_RT Torizon OS 6 Easy Pairing
Apalis iMX6🛈 MD51517d1b62572f674162bb5b2c1f5f9dd | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 183.58 MiB |
Apalis iMX8🛈 MD5814eb592448062611ea03030314c6819 | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 206.06 MiB |
Colibri iMX6🛈 MD592e2f4a0fa363971ff0bdea50133b48c | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 189.63 MiB |
Colibri iMX6ULL eMMC🛈 MD582a4422715d2ff60c494416e063a241b | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 188.86 MiB |
Colibri iMX7 eMMC🛈 MD5ba71043ff33c35dda304d628207e82fa | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 189.10 MiB |
Colibri iMX8X🛈 MD5a8ea310757ba93a739185adabb639651 | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 205.63 MiB |
Verdin AM62🛈 MD5db868ea54c136a4e63dd1350dfd6c32e | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 222.92 MiB |
Verdin iMX8M Mini🛈 MD5aa74a7c09913fcd947a1e7c726b2785b | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 214.97 MiB |
Verdin iMX8M Plus🛈 MD5fcb60f1cd6cbc0bfb506841731270dc3 | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 205.65 MiB |
Apalis iMX6🛈 MD5d7979ddd3c90caf28726a4b2ed0c64af | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 182.34 MiB |
Apalis iMX8🛈 MD525a70d7bdfb2dca24fb6b1cbdee561bc | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 203.91 MiB |
Colibri iMX6🛈 MD55ef4ab8d8856f729fb6417fed12d201e | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 182.16 MiB |
Colibri iMX6ULL eMMC🛈 MD5b5dc86035ce00d4b2e530c6f53e37074 | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 181.80 MiB |
Colibri iMX7 eMMC🛈 MD5b160722eba5c33c1d3c65d834729ae91 | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 187.98 MiB |
Colibri iMX8X🛈 MD551e45bd7507d941fd0ff4aa08255ca14 | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 196.30 MiB |
Verdin AM62🛈 MD52d2bb2b0641dbb2cc22a2dd6c168b226 | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 227.99 MiB |
Verdin iMX8M Mini🛈 MD59c738845cb8e861a0f043ded19bfa740 | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 213.03 MiB |
Verdin iMX8M Plus🛈 MD58114c855b4b828323ab5684403ab2712 | 6.8.6-devel-20260302+build.1027 | 2026/03/02 | 197.22 MiB |
Torizon OS on Non-Toradex Hardware
Quarterly Releases
Torizon OS for TI Machines
TI AM62Lx EVM🛈 MD5f8abf3170cbde64c3f2d40c401c25be8 | 7.5.0+build.6 | 2026/01/21 | 1712.64 MiB |
TI AM62Px EVM🛈 MD5115a3761372a40bf19eef8f17d2bc678 | 7.5.0+build.6 | 2026/01/21 | 1878.85 MiB |
TI AM62x EVM🛈 MD5ba7683a5dc4e13392d3696b7d5b82f25 | 7.5.0+build.6 | 2026/01/21 | 1880.91 MiB |
BeagleY-AI🛈 MD584051dbe715c8faa8cf80eee9dbce168 | 7.5.0+build.6 | 2026/01/21 | 1997.27 MiB |
Refer to the test setup guide for detailed instructions on testing Torizon on Texas Instruments machines.
Torizon OS for x86 Machines
x86 Intel Core i7🛈 MD57a990a467f88804148b7badfce75e922 | 7.5.0+build.7 | 2026/01/20 | 1776.02 MiB |
Refer to the test setup guide for detailed instructions on testing Torizon on x86 machines.
Engineering Pre-Releases
Torizon OS for NXP Machines
| FRDM i.MX 93 Development Board | 7.5.0 | 2025/12/17 | 197.41 MiB |
Refer to the test setup guide for detailed instructions on testing Torizon on NXP machines.
Torizon OS for Synaptics Machines
| Astra SL1680 Development Board | 7.0.0 | 2025/12/17 | 197.41 MiB |
| Toradex Luna SL1680 SBC | 7.0.0 | 2025/12/17 | 197.41 MiB |
Refer to the test setup guide for detailed instructions on testing Torizon on Synaptics machines.
Toradex Embedded Linux - Yocto Project Reference Images
Toradex provides Reference Images for Yocto Project built from the Toradex BSP Layers for Yocto Project. For further details, please visit the Linux software cover page. The list of images available from Toradex Easy Installer is provided below:
Reference Images are good for evaluation. They are not Linux distributions. Torizon OS is the Embedded Linux distribution provided by Toradex.
Our LTS BSP Layers for Yocto Project are production-grade and ready to be integrated with your own Yocto Built Linux distribution.
BSP Quarterly Releases
These images are based on production releases of Toradex BSP, which are good for development but also for deployment on the field. They get replaced with a newer quarterly every 3 months. Learn more about the different image options on BSP Layers and Reference Images for Yocto Project Software.
BSP 7
- BSP 7 Downstream Linux Reference Minimal
- BSP 7 Mainline Linux Reference Minimal
- BSP 7 Downstream Linux Reference Multimedia
- BSP 7 Mainline Linux Reference Multimedia
- BSP 7 older releases
Minimal Embedded Linux Image Without a Graphical User Interface, downstream SoC vendor-based kernel.
Wayland/XWayland graphics back-end supported but not included.
Apalis iMX8🛈 MD5612c01529d42f4c7f7b7f958ad932750 | 7.5.0+build.11 | 2026/01/06 | 46.86 MiB |
Aquila AM69🛈 MD50ed0f945abcffe828aed914b34917743 | 7.5.0+build.11 | 2026/01/06 | 72.98 MiB |
Aquila iMX95🛈 MD58ce03aec49d7bde3cadf8a0a4cfc41f1 | 7.5.0+build.11 | 2026/01/06 | 62.33 MiB |
Colibri iMX8X🛈 MD5116ec522d710ae0cc6207d3b510e5cd1 | 7.5.0+build.11 | 2026/01/06 | 46.64 MiB |
SMARC iMX8M Plus🛈 MD5c2e0c6f2a53dccac991aa6b78c2fd84b | 7.5.0+build.11 | 2026/01/06 | 47.27 MiB |
SMARC iMX95🛈 MD5dbc9fc333a84c227070489c9b73bd1cc | 7.5.0+build.11 | 2026/01/06 | 58.30 MiB |
Verdin AM62🛈 MD598c04043f3fa779e3680b8340a152402 | 7.5.0+build.11 | 2026/01/06 | 47.73 MiB |
Verdin AM62P🛈 MD57f361d81c97bc911df8d046abb0bfb68 | 7.5.0+build.11 | 2026/01/06 | 50.35 MiB |
Verdin iMX8M Mini🛈 MD565e752fe062a0c32c99d488e144ae69c | 7.5.0+build.11 | 2026/01/06 | 46.79 MiB |
Verdin iMX8M Plus🛈 MD5e7af764dab724fe090cd3d1631c52f14 | 7.5.0+build.11 | 2026/01/06 | 47.29 MiB |
Verdin iMX95🛈 MD554fd3fddd9370460aa6c9da99dce649b | 7.5.0+build.11 | 2026/01/06 | 58.29 MiB |
Minimal Embedded Linux Image Without a Graphical User Interface, mainline-based kernel.
Apalis iMX6🛈 MD5674085b6d7a76d8918d4c3f9202ea05b | 7.5.0+build.11 | 2026/01/06 | 41.15 MiB |
Colibri iMX6🛈 MD5ae7b2a458f5485a5e600567a4a9ba448 | 7.5.0+build.11 | 2026/01/06 | 40.73 MiB |
Colibri iMX6ULL🛈 MD547fc16806a921a7d41ffc6670fe2a352 | 7.5.0+build.11 | 2026/01/06 | 42.53 MiB |
Colibri iMX6ULL eMMC🛈 MD58bf0ee1ecd7808ab3488a3ac4d0c6cb3 | 7.5.0+build.11 | 2026/01/06 | 40.67 MiB |
Colibri iMX7🛈 MD514a00846e5408930b61b7b9d048c4e0b | 7.5.0+build.11 | 2026/01/06 | 42.63 MiB |
Colibri iMX7 eMMC🛈 MD5ced87dbbbb5882965b63d009ac53dc51 | 7.5.0+build.11 | 2026/01/06 | 40.59 MiB |
SMARC iMX8M Plus🛈 MD561fe2d8944c8866f9ffc8c8fe8a572ff | 7.5.0+build.11 | 2026/01/06 | 46.85 MiB |
Verdin AM62🛈 MD566ccd4892e1468843b988a290c78219b | 7.5.0+build.11 | 2026/01/06 | 48.18 MiB |
Verdin iMX8M Mini🛈 MD541878bf5a83f45961aacff708654583c | 7.5.0+build.11 | 2026/01/06 | 45.74 MiB |
Verdin iMX8M Plus🛈 MD54c9388890cdfcd6f56b8f732514ed1eb | 7.5.0+build.11 | 2026/01/06 | 46.88 MiB |
Reference Embedded Linux Image with Multimedia Capabilities, downstream SoC vendor-based kernel.
Wayland/XWayland graphics back-end included.
Apalis iMX8🛈 MD57d76b78e3a565d60b810b580b35442ee | 7.5.0+build.11 | 2026/01/06 | 196.83 MiB |
Aquila AM69🛈 MD5e6e8ddf80384e3e85c54c0f886228569 | 7.5.0+build.11 | 2026/01/06 | 225.70 MiB |
Aquila iMX95🛈 MD5ee62eae27520db3bade568a75906147f | 7.5.0+build.11 | 2026/01/06 | 213.17 MiB |
Colibri iMX8X🛈 MD5aa3cc14adefe6584641776ad129f2afb | 7.5.0+build.11 | 2026/01/06 | 187.21 MiB |
SMARC iMX8M Plus🛈 MD5a342e846184013f0f907d0bb92d8b2d6 | 7.5.0+build.11 | 2026/01/06 | 189.09 MiB |
SMARC iMX95🛈 MD526fe6d94ef95c8b36d75e86967affec3 | 7.5.0+build.11 | 2026/01/06 | 208.54 MiB |
Verdin AM62🛈 MD55a4df22ba2e6b31bf4e51bed5fe5dd77 | 7.5.0+build.11 | 2026/01/06 | 205.49 MiB |
Verdin AM62P🛈 MD55dd4ac50c39aea4920e9408d941ee841 | 7.5.0+build.11 | 2026/01/06 | 203.59 MiB |
Verdin iMX8M Mini🛈 MD5bcc782e3f315da019c9b41a0b38293b3 | 7.5.0+build.11 | 2026/01/06 | 185.47 MiB |
Verdin iMX8M Plus🛈 MD57e17c29f31bfd12b670f9cf0620a3678 | 7.5.0+build.11 | 2026/01/06 | 189.13 MiB |
Verdin iMX95🛈 MD537a115e92b34e448a5db994c43b13e00 | 7.5.0+build.11 | 2026/01/06 | 208.54 MiB |
Reference Embedded Linux Image with Multimedia Capabilities, mainline-based kernel.
Apalis iMX6🛈 MD550aa96ef9604f83d520c2f11840241fc | 7.5.0+build.11 | 2026/01/06 | 173.82 MiB |
Colibri iMX6🛈 MD5e526a9f4c1c49116f9dd35178eb73ef1 | 7.5.0+build.11 | 2026/01/06 | 173.80 MiB |
Colibri iMX6ULL🛈 MD5a3c291565d93b32d32993ff0cc7809c8 | 7.5.0+build.11 | 2026/01/06 | 130.84 MiB |
Colibri iMX6ULL eMMC🛈 MD582b38fadb857bce687eac25a215ff4b2 | 7.5.0+build.11 | 2026/01/06 | 128.97 MiB |
Colibri iMX7🛈 MD57d6cfa5ca2be3a85251a9ae362c6887e | 7.5.0+build.11 | 2026/01/06 | 147.88 MiB |
Colibri iMX7 eMMC🛈 MD5216faa7ba14614ba76b061b8a9f62ca0 | 7.5.0+build.11 | 2026/01/06 | 177.73 MiB |
SMARC iMX8M Plus🛈 MD52b3ddea44d0dbb0dd61adbae3a450961 | 7.5.0+build.11 | 2026/01/06 | 185.56 MiB |
Verdin AM62🛈 MD5a57ff383fb6b72f590f482eaa7c8e011 | 7.5.0+build.11 | 2026/01/06 | 190.34 MiB |
Verdin iMX8M Mini🛈 MD51e1affd78a9de8918b645dfcf57469e5 | 7.5.0+build.11 | 2026/01/06 | 184.40 MiB |
Verdin iMX8M Plus🛈 MD5517ca86b1dbc3ae76e89625927604ed8 | 7.5.0+build.11 | 2026/01/06 | 185.67 MiB |
BSP 6
- BSP 6 Downstream Linux Reference Minimal
- BSP 6 Mainline Linux Reference Minimal
- BSP 6 Downstream Linux Reference Multimedia
- BSP 6 Mainline Linux Reference Multimedia
- BSP 6 older releases
Minimal Embedded Linux Image Without a Graphical User Interface, downstream SoC vendor based kernel.
Apalis iMX8🛈 MD53c2a2711b74b1c691be36dc531297d37 | 6.8.5+build.19 | 2026/01/06 | 45.67 MiB |
Aquila AM69🛈 MD5ab72657ec94ca24e56c762ab8fa837e2 | 6.8.4+build.18 | 2025/10/03 | 44.74 MiB |
Colibri iMX8X🛈 MD5fb25a6cd429d4e716a5a419ad4e26077 | 6.8.5+build.19 | 2026/01/06 | 45.51 MiB |
Verdin AM62🛈 MD5cf5cafce8d08086b5b0fe9841a3220a8 | 6.8.5+build.19 | 2026/01/06 | 44.47 MiB |
Verdin iMX8M Mini🛈 MD5618e84a2bf5452279b606ae8ba05977b | 6.8.5+build.19 | 2026/01/06 | 45.93 MiB |
Verdin iMX8M Plus🛈 MD5131b926f4e294a37b17b7be2732efa4e | 6.8.5+build.19 | 2026/01/06 | 45.93 MiB |
Minimal Embedded Linux Image Without a Graphical User Interface, mainline based kernel.
Apalis iMX6🛈 MD52fabbf65125adb333a5060c6bf585b4b | 6.8.5+build.19 | 2026/01/06 | 38.55 MiB |
Colibri iMX6🛈 MD5d5ab0bfe537ed3b2af69f546f07e4f8e | 6.8.5+build.19 | 2026/01/06 | 38.21 MiB |
Colibri iMX6ULL🛈 MD583a754d5296a907aa1d6ba720d879408 | 6.8.5+build.19 | 2026/01/06 | 40.40 MiB |
Colibri iMX6ULL eMMC🛈 MD5d9e6ffc613cb4c8d6b956b3c81119293 | 6.8.5+build.19 | 2026/01/06 | 38.15 MiB |
Colibri iMX7🛈 MD5e44fe085d2b3b0a5a8115e2d71ec6b00 | 6.8.5+build.19 | 2026/01/06 | 40.46 MiB |
Colibri iMX7 eMMC🛈 MD52f0d3c5c4affa00fe5304cdbd4e170c4 | 6.8.5+build.19 | 2026/01/06 | 38.09 MiB |
Verdin iMX8M Mini🛈 MD58c688e3f8907250e76fa71a3704f5c4c | 6.8.5+build.19 | 2026/01/06 | 52.11 MiB |
Verdin iMX8M Plus🛈 MD56f55392dd54cef6c78d7e3b439df4516 | 6.8.5+build.19 | 2026/01/06 | 52.12 MiB |
Reference Embedded Linux Image with Multimedia Capabilities, downstream SoC vendor based kernel.
Apalis iMX8🛈 MD595b7524525668a4dfc7da7c336fabe11 | 6.8.5+build.19 | 2026/01/06 | 193.42 MiB |
Aquila AM69🛈 MD51c98b4c7f36ce7f575c232c8cbc0c2b0 | 6.8.4+build.18 | 2025/10/03 | 204.04 MiB |
Colibri iMX8X🛈 MD56427245620cbc379039e45f90427b7a8 | 6.8.5+build.19 | 2026/01/06 | 191.03 MiB |
Verdin AM62🛈 MD5c3f4632b0a52b7bdc6e14dd5f1345d31 | 6.8.5+build.19 | 2026/01/06 | 207.96 MiB |
Verdin iMX8M Mini🛈 MD53db4ffe9ba2639bafcb4444efe5d0cc1 | 6.8.5+build.19 | 2026/01/06 | 190.85 MiB |
Verdin iMX8M Plus🛈 MD545d94707ea4a3c43215a52a2bb3f3142 | 6.8.5+build.19 | 2026/01/06 | 210.66 MiB |
Reference Embedded Linux Image with Multimedia Capabilities, mainline based kernel.
Apalis iMX6🛈 MD529dd929cc72deb0673c51cf93afdc827 | 6.8.5+build.19 | 2026/01/06 | 178.40 MiB |
Colibri iMX6🛈 MD567e2ea2974e21fb7a52d30a0e8f1c31b | 6.8.5+build.19 | 2026/01/06 | 178.38 MiB |
Colibri iMX6ULL🛈 MD5351c7bf65daf6e9af28cd25f9ee7fe19 | 6.8.5+build.19 | 2026/01/06 | 135.73 MiB |
Colibri iMX6ULL eMMC🛈 MD5b7c2c4ded85d50eb4c00febf47eb9de3 | 6.8.5+build.19 | 2026/01/06 | 133.51 MiB |
Colibri iMX7🛈 MD540bf2e264eb3678064ca62ea1b86f717 | 6.8.5+build.19 | 2026/01/06 | 152.43 MiB |
Colibri iMX7 eMMC🛈 MD5e5d4ee11dad7c9f9ee669f72b2577609 | 6.8.5+build.19 | 2026/01/06 | 182.29 MiB |
Verdin iMX8M Mini🛈 MD5ef820146d9d6b8e406aab0978ec5aa7f | 6.8.5+build.19 | 2026/01/06 | 197.29 MiB |
Verdin iMX8M Plus🛈 MD5563982e687e357a4fd7e99c1ff9cb6b5 | 6.8.5+build.19 | 2026/01/06 | 197.27 MiB |
- Reference Images - BSP 6.8.4+build.18
- Reference Images - BSP 6.8.3+build.17
- Reference Images - BSP 6.8.2+build.16
- Reference Images - BSP 6.8.1+build.15
- Reference Images - BSP 6.8.0+build.14
- Reference Images - BSP 6.7.0+build.13
- Reference Images - BSP 6.6.0+build.12
- Reference Images - BSP 6.5.0+build.9
- Reference Images - BSP 6.4.0+build.8
- Reference Images - BSP 6.3.0+build.7
- Reference Images - BSP 6.2.0+build.6
- Reference Images - BSP 6.1.0+build.5
- Reference Images - BSP 6.0.0+build.1
BSP 5
- BSP 5 maintenance releases Downstream Linux Reference Minimal
- BSP 5 maintenance releases Mainline Linux Reference Minimal
- BSP 5 maintenance releases Downstream Linux Reference Multimedia
- BSP 5 maintenance releases Mainline Linux Reference Multimedia
- BSP 5 older releases
Apalis iMX6🛈 MD5909dc141e39db9b93a6ef16167458ff0 | 5.7.6+build.29 | 2024/03/27 | 35.63 MiB |
Apalis iMX8🛈 MD59083e56a083ee705075a964dc342ff2e | 5.7.6+build.29 | 2024/03/27 | 43.24 MiB |
Apalis TK1🛈 MD5cf7f4cbf37252aa3fea16e886bb0f781 | 5.7.6+build.29 | 2024/03/27 | 36.19 MiB |
Colibri iMX6🛈 MD5c312ebec37b19e6c6b79094fbc5064cc | 5.7.6+build.29 | 2024/03/27 | 34.72 MiB |
Colibri iMX6ULL🛈 MD54b8347ce09712455f1575a93d9bc1359 | 5.7.6+build.29 | 2024/03/27 | 35.87 MiB |
Colibri iMX6ULL eMMC🛈 MD5b6a5cb7eb887f99b0364e6f10e2e5e8c | 5.7.6+build.29 | 2024/03/27 | 34.52 MiB |
Colibri iMX7🛈 MD56d2f7855489fe726d528aff39caa559f | 5.7.6+build.29 | 2024/03/27 | 36.08 MiB |
Colibri iMX7 eMMC🛈 MD531215044ea4322ab808b90f86ae43516 | 5.7.6+build.29 | 2024/03/27 | 34.68 MiB |
Colibri iMX8X🛈 MD52a7a62d72af889af01045133b89d7669 | 5.7.6+build.29 | 2024/03/27 | 42.99 MiB |
Verdin iMX8M Mini🛈 MD5713b8624d8a0bad150ff73dc1a6d9ab0 | 5.7.6+build.29 | 2024/03/27 | 43.36 MiB |
Verdin iMX8M Plus🛈 MD5e57d987c6fdea23cbe2088da2f86f133 | 5.7.6+build.29 | 2024/03/27 | 43.25 MiB |
Apalis iMX6🛈 MD506050d8ab13a1e9073d3968cd24ba1d5 | 5.7.6+build.29 | 2024/03/27 | 41.33 MiB |
Apalis TK1🛈 MD53838b1862e7493a936a133bcd942cdf3 | 5.7.6+build.29 | 2024/03/27 | 36.20 MiB |
Colibri iMX6🛈 MD5d8c50bc5b5fb1706350cdb078f5dc50e | 5.7.6+build.29 | 2024/03/27 | 41.00 MiB |
Colibri iMX6ULL🛈 MD5bad46f0e69cb048f6bf41105dd7d8cbd | 5.7.6+build.29 | 2024/03/27 | 42.12 MiB |
Colibri iMX6ULL eMMC🛈 MD570a8bec914c0b4c651e3b5c1e86555b6 | 5.7.6+build.29 | 2024/03/27 | 40.93 MiB |
Colibri iMX7🛈 MD5bd20b8e4fc15dd9e658e8a29d2df9b62 | 5.7.6+build.29 | 2024/03/27 | 42.23 MiB |
Colibri iMX7 eMMC🛈 MD5a5247414ae7ca6878b84e6db95fe4625 | 5.7.6+build.29 | 2024/03/27 | 40.88 MiB |
Apalis iMX6🛈 MD5f9580d29c79734f73b91470c16827657 | 5.7.6+build.29 | 2024/03/27 | 180.86 MiB |
Apalis iMX8🛈 MD5d1dcad4762b86af2495e0834766ce183 | 5.7.6+build.29 | 2024/03/27 | 196.00 MiB |
Apalis TK1🛈 MD5a3b24ceeebc50615155655e886580428 | 5.7.6+build.29 | 2024/03/27 | 179.10 MiB |
Colibri iMX6🛈 MD584e5e4b1955fb671d96783c88788b5cf | 5.7.6+build.29 | 2024/03/27 | 179.43 MiB |
Colibri iMX6ULL🛈 MD507e3eb0aba195ecf17d1cb50fd0d75dd | 5.7.6+build.29 | 2024/03/27 | 127.04 MiB |
Colibri iMX6ULL eMMC🛈 MD5bff977f9a476768fbb9da39ba76b84de | 5.7.6+build.29 | 2024/03/27 | 125.68 MiB |
Colibri iMX7🛈 MD53b18c3b282924d06bcbcd90318ec3f61 | 5.7.6+build.29 | 2024/03/27 | 141.40 MiB |
Colibri iMX7 eMMC🛈 MD5fb9a361195a3054b70b46343cf4a3f2c | 5.7.6+build.29 | 2024/03/27 | 181.97 MiB |
Colibri iMX8X🛈 MD501752d12bb5c16069cbdcf1492a39e4a | 5.7.6+build.29 | 2024/03/27 | 192.94 MiB |
Verdin iMX8M Mini🛈 MD58df48c0d2b9a27d325cfcd0071be10ab | 5.7.6+build.29 | 2024/03/27 | 191.82 MiB |
Verdin iMX8M Plus🛈 MD5ae963404526d6a164b612c8e11b4ded2 | 5.7.6+build.29 | 2024/03/27 | 193.87 MiB |
Apalis iMX6🛈 MD5918038e4679ccc2819a6d64f32d2ba5d | 5.7.6+build.29 | 2024/03/27 | 183.95 MiB |
Apalis TK1🛈 MD53294de60039019c53509780f0a959c97 | 5.7.6+build.29 | 2024/03/27 | 179.23 MiB |
Colibri iMX6🛈 MD53a043cd366bb18bb330db878d4194f4a | 5.7.6+build.29 | 2024/03/27 | 183.92 MiB |
Colibri iMX6ULL🛈 MD5d9fcd2386d5e9dae5dade508e6c90467 | 5.7.6+build.29 | 2024/03/27 | 133.96 MiB |
Colibri iMX6ULL eMMC🛈 MD59bd87e30e8f7679bb5962785d37946ed | 5.7.6+build.29 | 2024/03/27 | 132.71 MiB |
Colibri iMX7🛈 MD5b824da609354b8d254fea27aa1147fc4 | 5.7.6+build.29 | 2024/03/27 | 147.07 MiB |
Colibri iMX7 eMMC🛈 MD590d4b95fdf86f5e0fa3bedce82173faf | 5.7.6+build.29 | 2024/03/27 | 187.80 MiB |
BSP 5 last quarterly releases
| OS Image | Supported Modules/Download Link | |
![]() | Linux Reference Minimal BSP 5.7.0 LTS Downstream SoC vendor based kernel Wayland/XWayland graphics back-end supported but not included Minimal Embedded Linux Image Without a Graphical User Interface | Apalis iMX6 Apalis iMX8 Colibri iMX6 Colibri iMX6ULL 512MB Colibri iMX6ULL 1GB (eMMC) Colibri iMX7 256MB/512MB Colibri iMX7 1GB (eMMC) Colibri iMX8X Verdin iMX8M Mini Verdin iMX8M Plus (non-LTS) |
![]() | Linux Reference Minimal BSP 5.7.0 LTS Mainline based kernel Wayland/XWayland graphics back-end supported but not included Minimal Embedded Linux Image Without a Graphical User Interface | Apalis iMX6 Apalis TK1 Colibri iMX6 Colibri iMX6ULL 512MB Colibri iMX6ULL 1GB (eMMC) Colibri iMX7 256MB/512MB Colibri iMX7 1GB (eMMC) |
![]() | Linux Reference Multimedia BSP 5.7.0 LTS Downstream SoC vendor based kernel Wayland/XWayland graphics back-end included Reference Embedded Linux Image with Multimedia Capabilities | Apalis iMX6 Apalis iMX8 Colibri iMX6 Colibri iMX6ULL 512MB Colibri iMX6ULL 1GB (eMMC) Colibri iMX7 256MB/512MB Colibri iMX7 1GB (eMMC) Colibri iMX8X Verdin iMX8M Mini Verdin iMX8M Plus (non-LTS) |
![]() | Linux Reference Multimedia BSP 5.7.0 LTS Mainline based kernel Wayland/XWayland graphics back-end included Reference Embedded Linux Image with Multimedia Capabilities | Apalis iMX6 Apalis TK1 Colibri iMX6 Colibri iMX6ULL 512MB Colibri iMX6ULL 1GB (eMMC) Colibri iMX7 256MB/512MB Colibri iMX7 1GB (eMMC) |
BSP 5 old quarterly releases
BSP 5 Quarterly releases are no longer built.
Older Releases
BSP 2.7, 2.8, 3.0 LTS
![]() | Linux Console Image 3.0 Minimal Embedded Linux Image Without Graphical User Interface | Apalis TK1 Apalis TK1 Mainline Apalis iMX6 Colibri iMX6 Colibri iMX6ULL Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) |
![]() | Linux LXDE Image 2.8 Ångström LXDE Desktop Environment Image | Apalis TK1 Apalis TK1 Mainline Apalis T30 Apalis iMX6 Colibri iMX6 Colibri iMX6ULL (only for devices with 512MB NAND flash) Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) |
![]() | Linux LXDE Image 2.7 Ångström LXDE Desktop Environment Image | Apalis T30 Apalis iMX6 Colibri iMX6 Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) |
BSP 2.7, 2.8, 3.0 older releases
| OS Image | Supported Modules/Download Link | Summary Overview | |
![]() | Linux Console Image 3.0b3 | Apalis TK1 Apalis TK1 Mainline Apalis iMX6 Colibri iMX6 Colibri iMX6ULL (only for devices with 512MB NAND flash) Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) | Toradex Console Image based on Poky |
![]() | Linux Console Image 3.0b2 | Apalis TK1 Apalis TK1 Mainline Apalis iMX6 Apalis iMX8 Colibri iMX6 Colibri iMX6ULL (only for devices with 512MB NAND flash) Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) Colibri iMX8X | Linux Image without graphical user interface |
![]() | Linux Console Image 3.0b1 | Apalis iMX8 | Linux Image without graphical user interface |
![]() | Linux LXDE Image 2.8b6 | Apalis TK1 Apalis TK1 Mainline Apalis T30 Apalis iMX6 Colibri iMX6 Colibri iMX6ULL (only for devices with 512MB NAND flash) Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) | Ångström LXDE Desktop Environment Image |
![]() | Linux Console Image 2.8b6 | Colibri iMX6ULL | Linux Image without graphical user interface |
![]() | Linux LXDE Image 2.8b5 | Apalis TK1 Apalis TK1 Mainline Apalis T30 Apalis iMX6 Colibri iMX6 Colibri iMX6ULL (only for devices with 512MB NAND flash) Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) | Ångström LXDE Desktop Environment Image |
![]() | Linux Console Image 2.8b5 | Colibri iMX6ULL | Linux Image without graphical user interface |
![]() | Linux LXDE Image 2.8b4 | Apalis TK1 Apalis TK1 Mainline Apalis T30 Apalis iMX6 Colibri iMX6 Colibri iMX6ULL (only for devices with 512MB NAND flash) Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) | Ångström LXDE Desktop Environment Image |
![]() | Linux Console Image 2.8b4 | Colibri iMX6ULL | Linux Image without graphical user interface |
![]() | Linux LXDE Image 2.8b3 | Apalis TK1 Apalis T30 Apalis iMX6 Colibri iMX6 Colibri iMX6ULL (only for devices with 512MB NAND flash) Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) | Ångström LXDE Desktop Environment Image |
![]() | Linux Console Image 2.8b3 | Colibri iMX6ULL | Linux Image without graphical user interface |
![]() | Linux LXDE Image 2.8b2 | Apalis TK1 Apalis iMX6 Colibri iMX6 Colibri iMX6ULL (only for devices with 512MB NAND flash) Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) | Ångström LXDE Desktop Environment Image |
![]() | Linux Console Image 2.8b2 | Colibri iMX6ULL | Linux Image without graphical user interface |
![]() | Linux LXDE Image 2.8b1 | Apalis TK1 Apalis iMX6 Colibri iMX6 Colibri iMX6ULL (only for devices with 512MB NAND flash) Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) | Ångström LXDE Desktop Environment Image |
![]() | Linux Console Image 2.8b1 | Colibri iMX6ULL | Linux Image without graphical user interface |
![]() | Linux LXDE Image 2.7b5 | Apalis TK1 Colibri iMX6ULL (only for devices with 512MB NAND flash) | Ångström LXDE Desktop Environment Image |
![]() | Linux Console Image 2.7b5 | Colibri iMX6ULL | Linux Image without graphical user interface |
![]() | Linux LXDE Image 2.7b4 | Apalis iMX6 Colibri iMX6 Colibri iMX7 Solo 256MB/Dual 512MB Colibri iMX7 Dual 1GB (eMMC) | Ångström LXDE Desktop Environment Image |
![]() | Linux Console Image 2.7b4 | Colibri iMX6ULL | Linux Image without graphical user interface |
![]() | Linux LXDE Image 2.7b3 | Apalis iMX6 Colibri iMX6 Colibri iMX7 Solo 256MB/Dual 512MB | Ångström LXDE Desktop Environment Image |
![]() | Linux LXDE Image 2.7b3 | Apalis iMX6 Colibri iMX6 | Ångström LXDE Desktop Environment Image |
![]() | Linux LXDE Image 2.7b2 | Apalis iMX6 Colibri iMX6 | Ångström LXDE Desktop Environment Image |
![]() | Linux LXDE Image 2.7b1.1 | Colibri iMX6 | Ångström LXDE Desktop Environment Image |
![]() | Linux LXDE Image 2.7b1 | Apalis iMX6 Colibri iMX6 | Ångström LXDE Desktop Environment Image |
BSP Monthly Releases
These images are based on pre-production releases of Toradex BSP, which are good for development as you keep up-to-date with the latest features and bugfixes. Learn more about the different image options on BSP Layers and Reference Images for Yocto Project Software.
BSP 7
Apalis iMX8🛈 MD552301a87bbe66e5ad27a235aa897236e | 7.6.0-devel-202603+build.19 | 2026/03/03 | 46.86 MiB |
Aquila AM69🛈 MD52597ba04e00d0c1090f1d1b3e95d2700 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 72.98 MiB |
Aquila iMX95🛈 MD5d61cd9ed88faf11f1b95b085a12e40bb | 7.6.0-devel-202603+build.19 | 2026/03/03 | 62.35 MiB |
Colibri iMX8X🛈 MD56959439172a9394481e0e1eb73cbf95b | 7.6.0-devel-202603+build.19 | 2026/03/03 | 46.68 MiB |
lino-imx93🛈 MD5942b32dfb9d45c97cf23a618d2f485ff | 7.6.0-devel-202603+build.19 | 2026/03/03 | 46.92 MiB |
toradex-osm-imx93🛈 MD5800fc6fb167f2296253b4265615aff02 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 46.93 MiB |
SMARC iMX8M Plus🛈 MD50f2c4456bc0e94482a807a471ec0eb4a | 7.6.0-devel-202603+build.19 | 2026/03/03 | 47.28 MiB |
SMARC iMX95🛈 MD5d968d2302bed281b9ed99f16f3e85945 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 58.32 MiB |
Verdin AM62🛈 MD553b9ddd21372f59beb98b99251c3fe98 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 47.73 MiB |
Verdin AM62P🛈 MD5ef66ccc78ee2dcff8b36fba8ed52f213 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 50.36 MiB |
Verdin iMX8M Mini🛈 MD597e888cb59af9382416c911001a63037 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 46.81 MiB |
Verdin iMX8M Plus🛈 MD582f8139b5e950eecda12ab00219411ba | 7.6.0-devel-202603+build.19 | 2026/03/03 | 47.30 MiB |
Verdin iMX95🛈 MD51e3a6465ba897755097679fe43564d83 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 58.30 MiB |
Apalis iMX6🛈 MD594c17aafa821e93cbfe6a3756f09f7ad | 7.6.0-devel-202603+build.19 | 2026/03/03 | 41.16 MiB |
Colibri iMX6🛈 MD528f75119492290ffb6ea6f9f844086d2 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 40.75 MiB |
Colibri iMX6ULL🛈 MD58a7fabe4d5ee6f6be19a284412dac093 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 42.55 MiB |
Colibri iMX6ULL eMMC🛈 MD567c1568daed2df3547fd37a01a9300ae | 7.6.0-devel-202603+build.19 | 2026/03/03 | 40.69 MiB |
Colibri iMX7🛈 MD509321662f9fe2fa983c3d45db2135470 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 42.64 MiB |
Colibri iMX7 eMMC🛈 MD506705f4545d7c920dacf49d9a5d1d7f8 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 40.60 MiB |
SMARC iMX8M Plus🛈 MD5f99938f7803fb7167e5e6e3e7b50b2e6 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 46.88 MiB |
Verdin AM62🛈 MD5e6f0a533d941d9b3e0f5bc8e665d5330 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 48.20 MiB |
Verdin iMX8M Mini🛈 MD586933a477e0e52ffab97f20969693da7 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 45.75 MiB |
Verdin iMX8M Plus🛈 MD535ff0e24e1c4ec86b264ff634e3f240f | 7.6.0-devel-202603+build.19 | 2026/03/03 | 46.89 MiB |
Apalis iMX8🛈 MD5ef27dc1a46d7c5b3fec9331aea0cc3ba | 7.6.0-devel-202603+build.19 | 2026/03/03 | 196.72 MiB |
Aquila AM69🛈 MD53b26262b5e92e5f2d1a0ea7d97b4cc2c | 7.6.0-devel-202603+build.19 | 2026/03/03 | 225.63 MiB |
Aquila iMX95🛈 MD5012422fd1b01f3f2a4f6ca423150e28e | 7.6.0-devel-202603+build.19 | 2026/03/03 | 213.18 MiB |
Colibri iMX8X🛈 MD5974909da0943036b5d1c05f70f602c05 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 187.17 MiB |
lino-imx93🛈 MD5dff0937bd8ec8050f98ebf3ebf5fe9df | 7.6.0-devel-202603+build.19 | 2026/03/03 | 187.90 MiB |
toradex-osm-imx93🛈 MD55cea236bf2762d608af652e98c17056b | 7.6.0-devel-202603+build.19 | 2026/03/03 | 187.98 MiB |
SMARC iMX8M Plus🛈 MD56d0987e787181bdd6e4c6b79752d64ed | 7.6.0-devel-202603+build.19 | 2026/03/03 | 189.12 MiB |
SMARC iMX95🛈 MD5f790ed7008388dc8f4c9db7fbee0d004 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 208.54 MiB |
Verdin AM62🛈 MD50fa9d25fca1e4cb35f43c7d8119730bd | 7.6.0-devel-202603+build.19 | 2026/03/03 | 205.50 MiB |
Verdin AM62P🛈 MD510ae3b75d11e5e27943a346c42bc7b7a | 7.6.0-devel-202603+build.19 | 2026/03/03 | 203.57 MiB |
Verdin iMX8M Mini🛈 MD571ed804e976725c6b4a4b94b53a9fb03 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 185.53 MiB |
Verdin iMX8M Plus🛈 MD5c1aad63dba60743e756df75983e0eda1 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 189.18 MiB |
Verdin iMX95🛈 MD5308f3376b9dfce09eb0a030e3a51b51f | 7.6.0-devel-202603+build.19 | 2026/03/03 | 208.54 MiB |
Apalis iMX6🛈 MD5f5a9b812c93efe56442c8ab2f0b7b376 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 173.83 MiB |
Colibri iMX6🛈 MD50bb694de2e74ce1703b46b35626ddc10 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 173.81 MiB |
Colibri iMX6ULL🛈 MD5d0bbd69d56e7ce1a8395f8339ab2dae4 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 130.85 MiB |
Colibri iMX6ULL eMMC🛈 MD51dac14c1abe46b3420f87f849bba663f | 7.6.0-devel-202603+build.19 | 2026/03/03 | 128.98 MiB |
Colibri iMX7🛈 MD52d0af9e8597d75a25393c771c0a1ab69 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 147.93 MiB |
Colibri iMX7 eMMC🛈 MD59b7810c1989f91b71666eee0cca0600b | 7.6.0-devel-202603+build.19 | 2026/03/03 | 177.72 MiB |
SMARC iMX8M Plus🛈 MD5c513293de5e2ea923159a8d1d631a36f | 7.6.0-devel-202603+build.19 | 2026/03/03 | 185.58 MiB |
Verdin AM62🛈 MD5e19def00a004a04875727f5505017411 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 190.38 MiB |
Verdin iMX8M Mini🛈 MD5daf31f8339008695a05c999887e904a2 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 184.47 MiB |
Verdin iMX8M Plus🛈 MD51d4e402f849aa85a0355648f60676a39 | 7.6.0-devel-202603+build.19 | 2026/03/03 | 185.65 MiB |
- Reference Images - BSP 7.6.0-devel-202602+build.18
- Reference Images - BSP 7.5.0-devel-202512+build.17
- Reference Images - BSP 7.5.0-devel-202512+build.16
- Reference Images - BSP 7.5.0-devel-202511+build.15
- Reference Images - BSP 7.4.0-devel-202509+build.14
- Reference Images - BSP 7.4.0-devel-202509+build.13
- Reference Images - BSP 7.4.0-devel-202509+build.12
- Reference Images - BSP 7.4.0-devel-202508+build.11
- Reference Images - BSP 7.3.0-devel-202506+build.8
- Reference Images - BSP 7.3.0-devel-202505+build.7
- Reference Images - BSP 7.2.0-devel-202503+build.6
- Reference Images - BSP 7.2.0-devel-202502+build.5
- Reference Images - BSP 7.1.0-devel-202412+build.4
- Reference Images - BSP 7.1.0-devel-202411+build.3
- Reference Images - BSP 7.0.0-devel-202409+build.2
- Reference Images - BSP 7.0.0-devel-202408+build.1
BSP 6/5
Apalis iMX8🛈 MD50d4e4088695d150eeedb34aede22cdbf | 6.9.0-devel-202411+build.25 | 2024/11/06 | 45.61 MiB |
Aquila AM69🛈 MD59088a53fa485d5d0a8748ad021071713 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 50.39 MiB |
Colibri iMX8X🛈 MD58598a91abb0c58b013bb2689618b8412 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 45.43 MiB |
Verdin AM62🛈 MD5e7f86d490fa8f35d81d753eb7b71b9d0 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 50.12 MiB |
Verdin iMX8M Mini🛈 MD5b3d3d862e70ad2ee14f98d71450cb01e | 6.9.0-devel-202411+build.25 | 2024/11/06 | 45.85 MiB |
Verdin iMX8M Plus🛈 MD51b21922d644afe0ffa45c5f8e10569af | 6.9.0-devel-202411+build.25 | 2024/11/06 | 45.87 MiB |
Apalis iMX6🛈 MD55a5435126c9e376ca5677a0e76b7f588 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 38.53 MiB |
Colibri iMX6🛈 MD56e2a0ab283823a2b9dcdf0e0b76af236 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 38.18 MiB |
Colibri iMX6ULL🛈 MD58b3f5a71fb79ce7e0394d775819117c5 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 40.38 MiB |
Colibri iMX6ULL eMMC🛈 MD5a2f1a9a3fbedaee1f6f51a8141530805 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 38.13 MiB |
Colibri iMX7🛈 MD51d5956ea1cef8ba59cc50b4118e44f9f | 6.9.0-devel-202411+build.25 | 2024/11/06 | 40.45 MiB |
Colibri iMX7 eMMC🛈 MD58b80e182ebc407ac17a84a907f4d74a1 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 38.08 MiB |
Verdin iMX8M Mini🛈 MD576c3a64604d2cdbdfe4740aa70905948 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 52.05 MiB |
Verdin iMX8M Plus🛈 MD5d00c9de3bcc05a6a73d053671bb0045b | 6.9.0-devel-202411+build.25 | 2024/11/06 | 52.07 MiB |
Apalis iMX8🛈 MD571132d6ae22e61accbc3497a1aee0010 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 192.63 MiB |
Aquila AM69🛈 MD59123afe9ee994d84985f20c81e270b7d | 6.9.0-devel-202411+build.25 | 2024/11/06 | 208.85 MiB |
Colibri iMX8X🛈 MD572541c315d376174f5b7f7dbc5f177aa | 6.9.0-devel-202411+build.25 | 2024/11/06 | 190.23 MiB |
Verdin AM62🛈 MD53efa9c7623fe98e9d233782b3dd736d2 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 212.71 MiB |
Verdin iMX8M Mini🛈 MD54bda79818e2a2d8cb8ef36f96c3431d5 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 189.79 MiB |
Verdin iMX8M Plus🛈 MD56d36ee3e512202f1b4e18d5e65594c7e | 6.9.0-devel-202411+build.25 | 2024/11/06 | 209.67 MiB |
Apalis iMX6🛈 MD5e812d3013346c318bb3c50cb5c899886 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 177.48 MiB |
Colibri iMX6🛈 MD590fdc900da67717e3bf918c1abce3cee | 6.9.0-devel-202411+build.25 | 2024/11/06 | 177.48 MiB |
Colibri iMX6ULL🛈 MD5d8772bdf4ff5b454ae9ecfe60807d5e8 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 134.88 MiB |
Colibri iMX6ULL eMMC🛈 MD5ecd856ce71efd2f84c8effdb0fbf2a4c | 6.9.0-devel-202411+build.25 | 2024/11/06 | 132.63 MiB |
Colibri iMX7🛈 MD5a4d9200e9d2c027bc5c1b20dde6fea94 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 151.56 MiB |
Colibri iMX7 eMMC🛈 MD522e550bf93d4e67fc8e3115fc0b528b1 | 6.9.0-devel-202411+build.25 | 2024/11/06 | 181.44 MiB |
Verdin iMX8M Mini🛈 MD52731e3476a91b744b8f68a3f182b9f6f | 6.9.0-devel-202411+build.25 | 2024/11/06 | 196.40 MiB |
Verdin iMX8M Plus🛈 MD550028b5609bec7ca578b99290bc4b41c | 6.9.0-devel-202411+build.25 | 2024/11/06 | 196.42 MiB |
BSP 6
- Reference Images - BSP 6.8.0-devel-202409+build.24
- Reference Images - BSP 6.8.0-devel-202408+build.22
- Reference Images - BSP 6.7.0-devel-202406+build.21
- Reference Images - BSP 6.7.0-devel-202405+build.20
- Reference Images - BSP 6.6.0-devel-202403+build.19
- Reference Images - BSP 6.6.0-devel-202402+build.18
- Reference Images - BSP 6.5.0-devel-202312+build.16
- Reference Images - BSP 6.5.0-devel-202311+build.15
- Reference Images - BSP 6.4.0-devel-202309+build.14
- Reference Images - BSP 6.4.0-devel-202308+build.13
- Reference Images - BSP 6.4.0-devel-202308+build.12
- Reference Images - BSP 6.3.0-devel-202306+build.11
- Reference Images - BSP 6.3.0-devel-202305+build.10
- Reference Images - BSP 6.2.0-devel-202303+build.9
- Reference Images - BSP 6.2.0-devel-202302+build.8
- Reference Images - BSP 6.1.0-devel-202212+build.4
- Reference Images - BSP 6.1.0-devel-202211+build.2
- Reference Images - BSP 6.0.0-devel-202209+build.1
BSP 5
BSP 5 Monthly release is no longer built.
- Reference Images - BSP Monthly 5.7.0-devel-202205
- Reference Images - BSP Monthly 5.6.0-devel-202203
- Reference Images - BSP Monthly 5.5.0-devel-202112
- Reference Images - BSP Monthly 5.5.0-devel-202111
- Reference Images - BSP Monthly 5.4.0-devel-202109
- Reference Images - BSP Monthly 5.4.0-devel-202108
- Reference Images - BSP Monthly 5.3.0-devel-202106
- Reference Images - BSP Monthly 5.3.0-devel-202105
- Reference Images - BSP Monthly 5.2.0-devel-202102
- Reference Images - BSP Monthly 5.1.0-devel-202012
- Reference Images - BSP Monthly 5.1.0-devel-202011
- Reference Images - BSP Monthly 5.0.0-devel-202010
- Reference Images - BSP Monthly 5.0.0-devel-202008
BSP Nightly Releases
These images are based on pre-production releases of Toradex BSP without testing, and may not boot. Typically they are only used in development to focus on a feature or bug fix coming up in a monthly release. Learn more about the different image options on BSP Layers and Reference Images for Yocto Project Software.
BSP 7
| OS Image | Version | Date | Size |
Apalis iMX8🛈 MD5ee0a8364995252a33dbb3c225f7357f9 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 46.85 MiB |
Aquila AM69🛈 MD5fb15718a2c87a5ce47d43b5d18b18344 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 72.99 MiB |
Aquila iMX95🛈 MD547eb65f9ef28c8b633a153cd6b061def | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 62.34 MiB |
Colibri iMX8X🛈 MD5f2be8d5c14604475ac23fefc6728f58b | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 46.67 MiB |
lino-imx93🛈 MD5b1e44a262ae3dbf4444243e7e53308fa | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 46.93 MiB |
toradex-osm-imx93🛈 MD50dbb9b018edd47395bfb443afddf5fd3 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 46.92 MiB |
SMARC iMX8M Plus🛈 MD5f559dfc735abbcbf6f20306c12228b5a | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 47.29 MiB |
SMARC iMX95🛈 MD5654dd0cb6c07b0e7dc3f228b79e2618d | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 58.31 MiB |
Verdin AM62🛈 MD57f07607d5b0a5d644d6d8e45e72bf319 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 47.74 MiB |
Verdin AM62P🛈 MD54a69921ce8c3a738dd52cdfe0954c445 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 50.37 MiB |
Verdin iMX8M Mini🛈 MD56252cdde6e5dbbd7056a4f5f467d403a | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 46.81 MiB |
Verdin iMX8M Plus🛈 MD55a3d069127a6ae2f321da2d66e9906ba | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 47.29 MiB |
Verdin iMX95🛈 MD5676b46ae75020b1b8f39ea8188db53bd | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 58.29 MiB |
Apalis iMX6🛈 MD5ebeae37363db96fea9ac238244c8bd05 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 41.15 MiB |
Colibri iMX6🛈 MD5d5977cf9a663966d75788ad71989211e | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 40.74 MiB |
Colibri iMX6ULL🛈 MD5188b97589a87c0330ad9030350c3953e | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 42.56 MiB |
Colibri iMX6ULL eMMC🛈 MD55684aa0d9b06a187b22256dc99926fad | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 40.67 MiB |
Colibri iMX7🛈 MD5ccd740e1f860b40e67495b4b3648edcc | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 42.64 MiB |
Colibri iMX7 eMMC🛈 MD59f47e0d11f191869a7a8df90865c646f | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 40.60 MiB |
SMARC iMX8M Plus🛈 MD5f2c28e08922529295674883357a420af | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 46.89 MiB |
Verdin AM62🛈 MD54b92eab49a00b600d434dbd139bdec93 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 48.21 MiB |
Verdin iMX8M Mini🛈 MD5697b8a8368522e8094590f9fae784b98 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 45.75 MiB |
Verdin iMX8M Plus🛈 MD5262b0d864adf0081e07573447c219678 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 46.91 MiB |
Apalis iMX8🛈 MD535e957a4b247649843eabb40009f160d | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 196.74 MiB |
Aquila AM69🛈 MD51f6744d37c8488c809b3b4a04bc17795 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 225.63 MiB |
Aquila iMX95🛈 MD5449737f54fcba5431c14d793ebca1f1d | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 213.19 MiB |
Colibri iMX8X🛈 MD54caf9a9ee090fd94d673227f4d8ae93c | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 187.18 MiB |
lino-imx93🛈 MD5f5a5833a77f1dc272faf906919c6afa1 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 187.89 MiB |
toradex-osm-imx93🛈 MD58b606765d7f017fa783f76fb121cad64 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 187.89 MiB |
SMARC iMX8M Plus🛈 MD5f250976069d7ffadc205a9de69a65b15 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 189.15 MiB |
SMARC iMX95🛈 MD51cda7617a2b071bd12df0b1666a4c38f | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 208.55 MiB |
Verdin AM62🛈 MD599e2434e7e5a63187dd9f492047a0633 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 205.58 MiB |
Verdin AM62P🛈 MD58a89902712f7930acfe669bb40ab8bff | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 203.66 MiB |
Verdin iMX8M Mini🛈 MD5285be0dadfb03f1850ab6f5a02014968 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 185.47 MiB |
Verdin iMX8M Plus🛈 MD5a717a54767118ac3e7f77cccabb4c4ae | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 189.19 MiB |
Verdin iMX95🛈 MD58faff45f5fc8af2015eb5961de660351 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 208.53 MiB |
Apalis iMX6🛈 MD5e3a189816fa04ed96a14f8d993dc2b6f | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 173.83 MiB |
Colibri iMX6🛈 MD50869fece2bcf2e259a87d06d593f3eec | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 173.81 MiB |
Colibri iMX6ULL🛈 MD51919071c0bb43dd0c75472160eec46f7 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 130.85 MiB |
Colibri iMX6ULL eMMC🛈 MD5c7f19f60fc9d60603d0cd6ee2cde57c2 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 128.99 MiB |
Colibri iMX7🛈 MD5135692ec110081d4497e210997d6fca9 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 147.95 MiB |
Colibri iMX7 eMMC🛈 MD5ba3d93b26a1c108ec02978d69ddfbb31 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 177.73 MiB |
SMARC iMX8M Plus🛈 MD5faef14037824580e0313870a3b44da90 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 185.57 MiB |
Verdin AM62🛈 MD550f2fc6f73748835d6ca6a6839804aa5 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 190.37 MiB |
Verdin iMX8M Mini🛈 MD546f52c7afa67ac49ff8f984596e6d0d3 | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 184.40 MiB |
Verdin iMX8M Plus🛈 MD5e183e9ab3b4e17ef51ef90af80a9fe7f | 7.6.0-devel-20260305+build.586 | 2026/03/05 | 185.62 MiB |
BSP 6
Apalis iMX8🛈 MD56e809856fd1da8a1824900cf2d01d9f1 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 45.68 MiB |
Colibri iMX8X🛈 MD5b6c203bd6f49c50ea645d06f0c1b1a4f | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 45.52 MiB |
Verdin AM62🛈 MD5e23c615e27af4ef3cf1516d9a90a52ec | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 44.49 MiB |
Verdin iMX8M Mini🛈 MD51b8aaa9b66d10acb6aca2de4279ffc07 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 45.93 MiB |
Verdin iMX8M Plus🛈 MD5083c6da959bd6420a77873d813def8b5 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 45.93 MiB |
Apalis iMX6🛈 MD5bae5d3027b09dad20cea7aeb1d45ec05 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 38.56 MiB |
Colibri iMX6🛈 MD5d4a920909ee2b155d25fc5c53a3f4487 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 38.22 MiB |
Colibri iMX6ULL🛈 MD56c1632bfef916295896a4a1d7a04bc94 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 40.42 MiB |
Colibri iMX6ULL eMMC🛈 MD5c7cf732052034cc9f8a0c9102d43c468 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 38.17 MiB |
Colibri iMX7🛈 MD5cc464ad5472cd029f11f3692ddef8249 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 40.49 MiB |
Colibri iMX7 eMMC🛈 MD5cf5941d0bd62dbb688b988ef64ccae90 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 38.12 MiB |
Verdin iMX8M Mini🛈 MD5195b575298bb7edd3454acec90983122 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 52.13 MiB |
Verdin iMX8M Plus🛈 MD51bc950c09715cf29174d47ef1dacffbe | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 52.14 MiB |
Apalis iMX8🛈 MD55aa00c490e372cbc52da7fb808f07747 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 193.53 MiB |
Colibri iMX8X🛈 MD537fd6175c6a2cd63153f4533f7431147 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 191.12 MiB |
Verdin AM62🛈 MD56aaa84c2b06a5bdb0c65a14d82902ccb | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 207.98 MiB |
Verdin iMX8M Mini🛈 MD5439179c263349dc3e9bfb963c0da8d46 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 190.94 MiB |
Verdin iMX8M Plus🛈 MD509a819b5f480593ed88693c41fba6958 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 210.66 MiB |
Apalis iMX6🛈 MD55c89003dfe755504741bb6962c8217ad | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 178.40 MiB |
Colibri iMX6🛈 MD5b426b905e7fa4640468fa4b83f1b5f1d | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 178.39 MiB |
Colibri iMX6ULL🛈 MD51caf13efc1da5ac92460df512cda0baf | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 135.76 MiB |
Colibri iMX6ULL eMMC🛈 MD5d8b5dcf68b3005ab33b2114633bd8c92 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 133.52 MiB |
Colibri iMX7🛈 MD5d26d40bac275599d6c46d57ec5e72ce7 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 152.46 MiB |
Colibri iMX7 eMMC🛈 MD5c816bf4a0e5744aeab1b467dcd734af0 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 182.31 MiB |
Verdin iMX8M Mini🛈 MD5c0d28afc793572d1407c67d74fd7ce40 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 197.30 MiB |
Verdin iMX8M Plus🛈 MD56ba74bbbc3b28125cbdfd41643a3b887 | 6.8.6-devel-20260305+build.1099 | 2026/03/05 | 197.24 MiB |
BSP 5
- BSP 5 Downstream Linux Reference Minimal
- BSP 5 Mainline Linux Reference Minimal
- BSP 5 Downstream Linux Reference Multimedia
- BSP 5 Mainline Linux Reference Multimedia
Apalis iMX6🛈 MD5bbf7210bd421ef6b104f97d6c8d12b14 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 35.65 MiB |
Apalis iMX8🛈 MD56b5126df5b1b0645a09d20d704bf1aab | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 43.25 MiB |
Apalis TK1🛈 MD5903b09945d488247f7cd587f62a3f3e3 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 36.21 MiB |
Colibri iMX6🛈 MD53128cc0f8eb955b490601baec212dde5 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 34.72 MiB |
Colibri iMX6ULL🛈 MD545cd1e7777db9c75021bbc344d8c315b | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 35.90 MiB |
Colibri iMX6ULL eMMC🛈 MD52de29ae1978c1ed13779b5f64b16364f | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 34.53 MiB |
Colibri iMX7🛈 MD5db9e0fab0b42e381b0464c4dc9794ea3 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 36.11 MiB |
Colibri iMX7 eMMC🛈 MD5fe28485bf04270763c1b219674e56dfd | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 34.68 MiB |
Colibri iMX8X🛈 MD5d6e7055e9a71615a919fe081bee12967 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 43.01 MiB |
Verdin iMX8M Mini🛈 MD5b8b5b373dfb02c0e5c0e5973aac0e439 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 43.34 MiB |
Verdin iMX8M Plus🛈 MD59390cf6c054eb824e98441bee93a5fbe | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 43.25 MiB |
Apalis iMX6🛈 MD57856e2e78981b65aadaea25d916c748a | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 41.34 MiB |
Apalis TK1🛈 MD50e79f1d9b2371084ad1dff93b88312ad | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 36.21 MiB |
Colibri iMX6🛈 MD566a73c720d5987beec9107067b431860 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 41.02 MiB |
Colibri iMX6ULL🛈 MD5a216aa57e579bd0da1122286cea6e7a7 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 42.12 MiB |
Colibri iMX6ULL eMMC🛈 MD581d6c87064e194871b30597455fea28f | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 40.95 MiB |
Colibri iMX7🛈 MD576620babbc4bb085f7a19e522bb47654 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 42.23 MiB |
Colibri iMX7 eMMC🛈 MD535d22f7aa02de0e42cfa3c8fe48a2eff | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 40.89 MiB |
Apalis iMX6🛈 MD52a0d5bf89901564356ab229c4ba305db | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 180.85 MiB |
Apalis iMX8🛈 MD5413b1d0293a6bd372394918510dff227 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 196.03 MiB |
Apalis TK1🛈 MD590a1f1885e8128703ce5290f5bbc1402 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 179.10 MiB |
Colibri iMX6🛈 MD5cafd421653321a85f20c03037710a495 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 179.44 MiB |
Colibri iMX6ULL🛈 MD51f2878e8bfb776c029b1d24fdcfb548f | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 127.03 MiB |
Colibri iMX6ULL eMMC🛈 MD54b9db1ae1024ef4c4c65de93c92cc254 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 125.69 MiB |
Colibri iMX7🛈 MD5159e690f4e5303136f58e1d8241a25ab | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 141.39 MiB |
Colibri iMX7 eMMC🛈 MD5f836be71947ef29df3e54ae52eb333ce | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 181.99 MiB |
Colibri iMX8X🛈 MD59801b8c33c26410e306116c937a51a1a | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 192.94 MiB |
Verdin iMX8M Mini🛈 MD530473aa96e08ba0b88dd64391aa5fbc4 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 191.84 MiB |
Verdin iMX8M Plus🛈 MD570586bb35a1732c4e2faef8d6225d657 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 193.90 MiB |
Apalis iMX6🛈 MD5d2ff1fec25539d35b6a764e3ec55b0e5 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 183.96 MiB |
Apalis TK1🛈 MD528fa3122cbc0c82a61814f0d10829c9b | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 179.23 MiB |
Colibri iMX6🛈 MD52f6210d3633596498e1a0d8de9b8f89d | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 183.93 MiB |
Colibri iMX6ULL🛈 MD5cbaa3f68daf3efa5c5f7af8bcf2ad18e | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 133.96 MiB |
Colibri iMX6ULL eMMC🛈 MD55fe5b2a4d7531590fd678e2be6a94046 | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 132.74 MiB |
Colibri iMX7🛈 MD58c4f02ef80373edc5d92299a84d4bd6e | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 147.10 MiB |
Colibri iMX7 eMMC🛈 MD535f24f1a4fe1400ffa9b8a5d3267e83f | 5.7.7-devel-20250106+build.882 | 2025/01/06 | 187.83 MiB |
BSP Legacy Images
The legacy image format is the only format supported for Colibri VF50/VF61/T20/T30, only used for BSP 2.8. Not available from BSP 3 onwards.
Downloads may be verified using the following SHA256SUMS file.
Toradex Embedded Linux Stable Releases
![]() | Linux LXDE Image | Apalis TK1 (2.8.7 | 2020-06-10) Apalis TK1 Mainline (2.8.7 | 2020-06-10) Apalis T30 (2.8.7 | 2020-06-10) Apalis iMX6 (2.8.7 | 2020-06-10) Colibri T30 (2.8.7 | 2020-06-10) Colibri T20 (2.8.7 | 2020-06-10) Colibri iMX6 (2.8.7 | 2020-06-10) Colibri iMX7 (2.8.7 | 2020-06-10) Colibri VFxx (2.8.7 | 2020-06-10) | Angstrom LXDE desktop environment image |
![]() | Linux Console Image | Colibri VFxx (2.8.7 | 2020-06-10) | Linux Image without graphical user interface |
For older releases, please visit our separate server.
Toradex Windows Embedded Compact Images
Toradex provides a Windows Embedded Compact (WEC) BSP, including OS image releases. For further details, please visit the Windows Embedded Compact (WEC) software cover page. The list of images available from Toradex Easy Installer is provided below:
Toradex WEC Stable Releases
![]() | WEC 7 | Apalis/Colibri iMX6 Colibri iMX7 Solo 256MB/Dual 512MB | Windows Embedded Compact 7 |
![]() | WEC 2013 | Apalis/Colibri iMX6 Colibri iMX7 Solo 256MB/Dual 512MB | Windows Embedded Compact 2013 |
