Search by Tags
WEC iMX6 BSP Release
Clear Filter
1.3b4 (Release date: 2018-01-10)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 4 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until November 2017
You need to update the image and the eboot bootloader to run this version.
If you plan to update the image using update tool you will need to use the version of update tool that is included in the image download. Compressed image format has been changed and old update tool can't flash it. If you want to flash from bootloader you'll need to update bootloader first, reboot and then update the image.
WC-526New FeatureAdd support for MIPI CSI camera interfaceApalis iMX6CSIWEC7, WEC2013
Description: Support the CSI camera interface.
Workaround: Use USB cameras or use Apalis T30 which supports CSI.
