Search by Tags
WEC iMX6 BSP Release
Clear Filter
V1.1 (Release date: 2017-01-10)
- WEC 7 Updates: Installed Microsoft CE7 Updates until September 2016
- WEC 2013 Updates: Installed Microsoft CE8 Updates until September 2016
WC-573New FeatureAllow usage of the NOP display driver for headless devicesApalis iMX6, Colibri iMX6GraphicsWEC7, WEC2013
Description: Defining BSP_NODISPLAY will exclude display support from the image, undefining BSP_DISPLAY in the BSP batch file will just exclude the display driver, letting customers replace it with a different one, the NOP driver, for example. This should allow users to connect with the remote display tool even if no display is physically connected to the module. NOP driver still uses some memory for its internal frame buffer.
Workaround: Issue has been fixed in release 1.1
