Search by Tags
WEC iMX6 BSP Release
Clear Filter
Not Planned
WC-608Known IssueSystem time does not behave correctly when DST is not activatedApalis iMX6, Colibri iMX6RTCWEC7, WEC2013
Description: When DST is not active the current date/time reported by the system is not precise and lags few minutes per hours during runtime.
Workaround: If you have issues with DST not running correctly go into registry under HKLM\Time Zones and select your timezone. There is a subkey "Dynamic DST" with entries for each year. To fix it create a new entry for year when you have issues and copy value from previous year.
