Search by Tags
WEC iMX6 BSP Release
Clear Filter
1.3 (Release date: 2018-03-19)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 4 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until November 2017
You need to update the image and the eboot bootloader to run this version. If you plan to update the image using update tool you will need to use the version of update tool that is included in the image download. Compressed image format has been changed and old update tool can't flash it. If you want to flash from bootloader you'll need to update bootloader first, reboot and then update the image.
WC-590FixedSoftware reboot sometimes does not workApalis iMX6, Colibri iMX6Bootloader, KernelWEC7, WEC2013
Description: Calling reboot via IOCTL sometimes just hangs the system while rebooting. This issue is fixed on Windows Embedded Compact 7 for Colibri and Apalis modules and on WEC 2013 for Apalis modules. The issue can still be seen on Colibri iMX6 on WEC 2013, see issue #34234.
