Search by Tags
WEC iMX6 BSP Release
Clear Filter
Not Planned
WC-219Known IssueOpening binary image with Visual Studio shows empty registryApalis iMX6WEC7, WEC2013
Description: This is a side effect of the changes made to speed-up boot done in version 1.4b2 and newer. The base registry is still stored inside the image, but in a different way, in this way the OS will not load and then discard it when an updated registry is stored in flash.
Workaround: If you need to check registry contents for your image you may use registry editor (on a running image) on check reginit.ini in the flat release directory (immediately after build).
