Search by Tags
WEC iMX6 BSP Release
Clear Filter
1.4b2 (Release date: 2018-06-20)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed and this image can't load registry images saved using previous versions. Please export and re-import your registry settings using reg files when you update the OS image.
WC-218FixedRegistry format changed and isn't compatible with previous BSP versions anymoreApalis iMX6, Colibri iMX6WinCE FeatureWEC7, WEC2013
Description: Registry format has been changed in release 1.4b2 to improve boot time and to solve issue #28896 (Deleting default registry entries does not work). Unfortunately, it's not possible for the new image to load a copy of registry stored by old releases.
Workaround: You can export registry keys using the registry editor and use the same tool to re-import those changes in new images.
