Search by Tags
WEC iMX6 BSP Release
Clear Filter
1.4b2 (Release date: 2018-06-20)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed and this image can't load registry images saved using previous versions. Please export and re-import your registry settings using reg files when you update the OS image.
WC-390FixedSGTL5000: DC offset for Headphone-out and Line-out is too lowColibri iMX6Analog AudioWEC7, WEC2013
Description: The DC level for outgoing audio signals is too low. This has no impact if audio is played on low to medium level, but at high volume, this leads to audio distortion.
