Search by Tags
WEC iMX6 BSP Release
Clear Filter
1.4b4 (Release date: 2018-10-05)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed between 1.3 and 1.4 releases and this image can't load registry images saved using versions earlier than 1.4b2. Please export and re-import your registry settings using reg files when you update the OS image.
WC-422FixedUSB client interface data corruptionApalis iMX6, Colibri iMX6USBWEC7, WEC2013
Description: Data packets transferred over USB client connection may be corrupted. Issue has been reported using serial class driver on WEC2013 and was not possible to reproduce with different configurations.
Workaround: Issue has been fixed in 1.4b4 release
