Search by Tags
WEC iMX6 BSP Release
Clear Filter
1.4b4 (Release date: 2018-10-05)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed between 1.3 and 1.4 releases and this image can't load registry images saved using versions earlier than 1.4b2. Please export and re-import your registry settings using reg files when you update the OS image.
WC-404New FeatureProvide image compression tool as part of binary BSPApalis iMX6, Colibri iMX6WinCE FeatureWEC7, WEC2013
Description: Since the compressed format is the only one supported by the easy installer we decided to release the tool for free. It is part of binary BSP and the new sample OS Designs will build nbx file by default (bin is still built to be used for debugging etc.).
