Search by Tags
WEC iMX6 BSP Release
Clear Filter
1.5b2 (Release date: 2019-04-04)
- WEC 7 Updates: Installed until 2018M09
- WEC 2013 Updates: Installed until 2018M10
Various bug fixes on SD, UART, and Easy Installer image
WC-360FixedReading of large contiguous blocks from SD/eMMC may return incorrect dataApalis iMX6, Colibri iMX6SDIO/SD/MMCWEC7, WEC2013
Description: NOTE: This issue is not completely fixed in this release, only much more unlikely to happen. It's fixed in 1.6b2. This issue happens when a large number of sectors is retrieved in a single read operation. This usually happens when verifying an updated OS image or when a large executable/dll is loaded in memory (for example the compact framework runtime).
Workaround: The issue has been fixed in release 1.5b2
