Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
V1.0beta6 (Release date: 2016-01-26)
- WEC 7 Updates: Installed Microsoft CE7 Updates November 2015
- WEC 2013 Updates: November 2015
WC-514New FeatureMake SD card card-detect and write-protect pin configurableApalis iMX6, Colibri iMX6SDIO/SD/MMCWEC7, WEC2013
Description: Card detect and write protect pins are optional, by default card detect is enabled using the standard Colibri/Apalis pinout for SD0 on Colibri and SD0 and SD1 on Apalis. The pins can be configured by adding values under the HKLM\Drivers\Builtin\USDHC key, where X is the index of the SD controller to be configured. The "CardDetectPin" can be used to configure the SODIMM-MXM number of the pin that should be used as card detect and "CardDetectPol" can be 0 or 1 to set the polarity to active low or high. Same parameters can be specified for write protect using "WriteProtectPin" and "WriteProtectPol". If no pins are configured the WP signal will be ignored (default).
