Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
V1.1beta4 (Release date: 2016-11-25)
- WEC 7 Updates: Installed Microsoft CE7 Updates until September 2016
- WEC 2013 Updates: Installed Microsoft CE8 Updates until September 2016
WC-657New FeatureI2C does not keep different frequencies for different apps invoking the driverApalis iMX6, Colibri iMX6I2CWEC7, WEC2013
Description: When multiple applications access the I2C driver (directly or using libs) they can change bus frequency. This change is global and affects all the communication operations performed by the driver after the change. Since there is no way for apps to be aware of frequency changes and those cannot be performed in an atomic way together with transfers, we changed the driver to support different frequencies for each instance (each app that calls "open"). Applications using the libs can do multiple I2C_Init calls to use different transfer speed. Of course using different speeds for devices connected to the same bus is not the best thing to do from an HW point of view, but this solution can allow better performances for drivers requiring fast transactions or significant data transfers.
Workaround: Issue has been fixed in rev. 1.1B4. No changes are required for applications and libraries.
