Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
V1.1beta4 (Release date: 2016-11-25)
- WEC 7 Updates: Installed Microsoft CE7 Updates until September 2016
- WEC 2013 Updates: Installed Microsoft CE8 Updates until September 2016
WC-664FixedUSB serial not working after plug/unplugApalis iMX6, Colibri iMX6USBWEC7, WEC2013
Description: Using the USB serial driver as described here: http://developer.toradex.com/knowledge-base/serial-over-usb The connection is not re-activated if the network cable is unplugged and re-plugged
Workaround: Configure the USB controller to work as client only and not as on-the-go: http://developer.toradex.com/knowledge-base/usb-on-the-go
