Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b2 (Release date: 2018-06-20)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed and this image can't load registry images saved using previous versions. Please export and re-import your registry settings using reg files when you update the OS image.
WC-289FixedTimezone can only be set once in RemoteAdmin interfaceApalis iMX6, Colibri iMX6RTCWEC7
Description: When certain timezones are selected (e.g.: UTC+9:00 Osaka, Sapporo, Tokio) the page allowing to set time on the RemoteAdmin interface does not work.
Workaround: Change the timezone prior to using RemoteAdmin
