Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b2 (Release date: 2018-06-20)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed and this image can't load registry images saved using previous versions. Please export and re-import your registry settings using reg files when you update the OS image.
WC-287FixedDeleting default registry entries does not workApalis iMX6, Colibri iMX6WinCE FeatureWEC7, WEC2013
Description: The registry is stored permanently and changing or adding new keys work as expected. Deleting a key from the default registry (for example to remove desktop icons) does not work and the deleted entry reappears at next reboot.
Workaround: Users can set the entry to the default value explicitly (the value is anyway used when the key is not there) or rename the entry
