Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.3b4 (Release date: 2018-01-10)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 4 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until November 2017
You need to update the image and the eboot bootloader to run this version.
If you plan to update the image using update tool you will need to use the version of update tool that is included in the image download. Compressed image format has been changed and old update tool can't flash it. If you want to flash from bootloader you'll need to update bootloader first, reboot and then update the image.
WC-274New FeatureAdd option to disable video sync signalsApalis iMX6, Colibri iMX6HDMIWEC7, WEC2013
Description: Implement a feature to disable the data enable (DE) or sync (VSYNC and HSYNC) signals form the display controller in order to use them as GPIOs.
