Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b2 (Release date: 2018-06-20)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed and this image can't load registry images saved using previous versions. Please export and re-import your registry settings using reg files when you update the OS image.
WC-226New FeatureEnable 2D accelerationApalis iMX6, Colibri iMX6GraphicsWEC7, WEC2013
Description: Currently 2D acceleration has issues with the new driver with multi-display support and it's disabled. This may impact performances of some graphic operations like transparent blits.
Workaround: On some use cases DirectDraw overlays may provide an alternative implementation of the features that are currently not accelerated on GDI.
