Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b2 (Release date: 2018-06-20)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed and this image can't load registry images saved using previous versions. Please export and re-import your registry settings using reg files when you update the OS image.
WC-207New FeatureSupport RNDIS on Debugger clientApalis iMX6, Colibri iMX6WinCE FeatureWEC7, WEC2013
Description: Currently application debugging over USB / RNDIS is not supported out of the box in the debugger client. Add support for RNDISFN to the debugger client.
