Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b2 (Release date: 2018-06-20)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed and this image can't load registry images saved using previous versions. Please export and re-import your registry settings using reg files when you update the OS image.
WC-386FixedSome LVDS displays may not work with 1.3 releaseApalis iMX6LVDSWEC7, WEC2013
Description: Displays using specific pixel clock frequencies will not work on 1.3 release due to an issue with enabling/disabling of PFD0 of 528MHz PLL. Displays that are driven using PLL5 (VIDEO PLL) work.
