Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b4 (Release date: 2018-10-05)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed between 1.3 and 1.4 releases and this image can't load registry images saved using versions earlier than 1.4b2. Please export and re-import your registry settings using reg files when you update the OS image.
WC-430FixedSDBUS patch for SDIO8787 WiFi and BT functions.Apalis iMX6, Colibri iMX6SDIO/SD/MMCWEC7, WEC2013
Description: SDBUS patch needed in order to support both WiFi and BT functions on the SDIO8787 card.
Workaround: The issue has been fixed in release 1.4b4
